General Supercharger Thread
  1. Sep 28, 2023 at 9:28 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @VWTim initially my ECU was thought to be bricked. New ECU couldnt be read either. It was a bad 5v constant line that prevented the obd port from having power. ECU was never bricked. Flashed the ECU numerous times without issues.
    snivilous[OP] and VWTim like this.
  2. Sep 28, 2023 at 9:34 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    That's good to hear, then I've only heard of 1 or maybe 2 others via HPT forum.
    Mdl[QUOTED] likes this.
  3. Sep 28, 2023 at 10:19 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @VWTim Good luck on your move. Would Iike to leave this area. A move to Idaho or Utah would be nice for me...
    snivilous[OP] likes this.
  4. Sep 28, 2023 at 10:31 AM
    Land Bruiser
    Land Bruiser New Member
    2018 Lexus 5.7
    Harrop 2650, 285/70r20
    This should be supported by VFTuner.
    The tuner I am going to use next month uses VF and I don't need to send my ECU off to S. Korea to get "unlocked." He said it's supported and he has a stock file he can re-write. Obviously need a dyno tune with a blower on it.
    I have the 2650 Harrop on my '18 LX570 stage one w/85mm pulley. Since I feel safer getting it tuned figured might as well go stage 2. He recommended Injector Dynamics or Fuel Injector Clinic for injectors. ID smallest was 1,065cc so I went with FIC 775cc and also saved $500.
    Question for the group: I didn't realize XAT had the fuel rails available. Did I overspend by buying the Prospeed "fuel system" which includes that, a Walbro 450 w/SS braided hose and fittings and some other odds and ends in the "install kit?" Prospeeds system is $1560 and the XAT mani is only $900. Not sure what all else it includes that necessitates the extra cost or if that is just markup.
    Saltyhero13 and HulkSmurf14 like this.
  5. Sep 28, 2023 at 10:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I'd be curious on the injectors being plug and play with our harness. I went with the Five-o motorsports no issues. I'm not sure if the fuel system is the same but the fuel rails and lines aren't a concern until much later in power.
    Mdl likes this.
  6. Sep 28, 2023 at 11:28 AM
    Land Bruiser
    2018 Lexus 5.7
    They aren't plug and play and will have to be soldered in. Just following instructions from my tuner to go with these since he has experience with them. So this verbiage from XAT isn't necessarily true? Prospeed said I needed the fuel rail too.
    " While the stock 3UR fuel rails do work just fine- when you start adding HP with a Supercharger or Turbo the fuel demand starts to exceed the flow capabilities of the stock fuel rails. Stock fuel rails are made from pressed and welded steel that have bent crossover and feed ports- these ports are as narrow as 5mm!! To put this measurement into perspective- each injector has a 6mm port on each rail- MEANING the feed port for all 4 injectors on each rail is smaller than just one of the injectors feed ports- WOW - so this is why Tundras approaching 600WHP start to run lean and drop pistons and start welding rings and breaking ring lands- the engine is going seriously lean under these high load situations- this is where we stepped in- "
    In less than 3 weeks I'm making an 11hr drive to Des Moines, IA to get installed and tuned so need to get my crap together so I don't end up disappointed or caught unprepared. Appreciate everyones input and all the knowledge here.
    HulkSmurf14 likes this.
  7. Sep 28, 2023 at 11:49 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    @ViktorG did an extensive fuel test with the stock items. Not sure if its back up on the YouTube yet but not needed.
  8. Sep 28, 2023 at 1:54 PM
    VWTim
    Corvallis, OR
    This is just a temp move for work, did last year in Phoenix, thought we were coming home to OR, then got Shanghai'd to TX for a year. I haven't found anywhere I'd rather live than the Willamette Valley so far.
  9. Sep 28, 2023 at 3:19 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Just saw my buddy say that afe is taking his truck in for the airbox R&D we will see what happens
    M3Tundra-JK, Mdl and Saltyhero13 like this.
  10. Sep 28, 2023 at 3:22 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Are you going to tell who the tuner is or is that some big secret?
    ZPhilip, HulkSmurf14 and reywcms like this.
  11. Sep 28, 2023 at 3:31 PM
    Land Bruiser
    2018 Lexus 5.7
    Ha, no my bad, its @tunedbyloi
  12. Sep 28, 2023 at 3:58 PM
    Land Bruiser
    2018 Lexus 5.7
    Here is some of his recent work. With 37‘s and stock gears the power comes in 1100 RPM sooner, with 37s and 5.29 gears power comes in 800 RPM sooner. These are all NA setups tho.
    E7C27156-EBBE-44A3-BF86-A97F18BDC1FD.png B49893DE-AD27-486E-A96A-CD64D9B92B9A.png 0D989077-FEFF-40E0-B314-E1611DB84DA5.png 140B0F09-4BCB-4637-B4D4-25657A505268.png
    e30cabrio likes this.
  13. Sep 28, 2023 at 5:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Also suggested by Matt Smith and firemandan open up the bevel on the fuel rail opening removes about 1.5mm of restriction. I plan on doing this when I get the Denso 750s from fiveO.
  14. Sep 28, 2023 at 8:45 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    About to put this little guy on this weekend, wish me luck! My neighbors will be so excited. (ARH 1-7/8”, 2x200 cell cats, DD full 3” catback with 26” straight through mufflers).
  15. Sep 28, 2023 at 9:19 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Ponderosa_Pine You will love it! Similar set up except JBA's with duals at each wheel. Let it flow... I lost 1-2psi of boost but no power loss. I still have about 10.1 psi.
    Ponderosa_Pine likes this.
  16. Sep 29, 2023 at 1:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I want that..
  17. Sep 29, 2023 at 4:08 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Saltyhero13, PolishedTRD, Mdl and 3 others like this.
  18. Sep 29, 2023 at 5:51 AM
    nags
    nags New Member
    nobodyintexas likes this.
  19. Sep 29, 2023 at 5:56 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Back in the Tundra after 3 weeks of driving a rental highlander.
    there is something wonderfully visceral about a S/C'd truck.
    the exhaust sound, the acceleration, the caveman simplicity of it all, the absolute middle finger to the greenies.
    I love it.
    putting on the TRD airbox soon.
    Waiting on the 77.5mm pulley.
    SG3 mount comes soon.
    life is good.
  20. Sep 29, 2023 at 5:58 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Mdl likes this.
  21. Sep 29, 2023 at 5:58 AM
    nags
    nags New Member
    10-4. Gonna get it ordered. Don't know why I waited so long.
    Mdl likes this.
  22. Sep 29, 2023 at 5:59 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    What mount are you using for the sg3
  23. Sep 29, 2023 at 6:00 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    cravenspeed has a new one.
  24. Sep 29, 2023 at 6:03 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
  25. Sep 29, 2023 at 6:10 AM
    19PlatinumCrew
    Dave
  26. Sep 29, 2023 at 6:12 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    yup...do the drop down.
  27. Sep 29, 2023 at 7:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Mentions a few good points on the twin screw vs roots also.
    Mdl and nobodyintexas[QUOTED] like this.
  28. Sep 29, 2023 at 8:37 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I have talking to Magnusson about a 2650 but after more and more reading about superchargers on this platform, there is just not enough positive info about long engine life and that is the primary reason I bought a used 2021 to get the last of the ole reliable.
    Not saying anything bad about supercharging because there aren't really any horror stories like Subaru's, but I'm really counting on 300-400K on this drivetrain
  29. Sep 29, 2023 at 8:41 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    lol @snivilous has 200k+ miles on his supercharged rig I believe and tows.
  30. Sep 29, 2023 at 8:49 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    And that's is 1 response out of many folks asking about long term use and a ton of people showing up saying they have 15-20K with no issues. And that is looking across multiple online platforms.
    Again, not a single negative thing to say about Magnusson as I believe they are extremely dependable. I was just hoping to see some common trend.
    Also keep in mind that I come from the fragile Subaru EJ25 world, for what it's worth. I've spent 30-40K on engine mods and rebuilds on that platform and finally walked away.
    If the Tundra was a toy for me, I'd move without concern. But I just spent 60K cash on a truck I told my wife is going to last like my 17 year old Tacoma.
