Brake issue
Discussion in '3rd Gen Tundras (2022+)' started by Lilfoot, Sep 27, 2023.
  1. Sep 27, 2023 at 4:09 PM
    Lilfoot
    Lilfoot [OP] New Member
    Lisa
    2022 White Tundra SR5
    Anyone else have an issue when stopped at a red light, when taking off, the brake engaged itself?
    It's like the parking brake is engaging itself.
    I have to put it in neutral and then drive. This has happened several times.
  2. Sep 27, 2023 at 4:12 PM
    It’s an electronic parking brake. May have “hill assist” or “hill braking” type option engaged. Keeps you from rolling backwards when taking off. Can likely be disabled.
    EmergencyMaximum and Lilfoot[OP] like this.
  3. Sep 27, 2023 at 5:07 PM
    Lilfoot
    Lisa
    Thanks I'll check it out
  4. Sep 27, 2023 at 5:24 PM
    smileytn1
    smileytn1 New Member
    Hi lilfoot! It also may have a hold feature that holds the vehicle still at the red light and once you apply the gas it automatically lets it roll. Once you get use to it and remember it is on it is actually pretty good and on the display it will show hold has been turned on and when you stop you can push the brake in at stop or wait for the lag time and the hold will show up on gauge cluster that it is active. Hope that helps. Happy cruising!smileytn1
  5. Sep 27, 2023 at 5:27 PM
    EmergencyMaximum
    If you don't mash brake pedal too hard, it doesnt engage. My venza shpenza has it. Like the gang said, the feature helps from rolling back if stopped on a hill.
    Just easy with the "lilfoot" and you'll never trigger the brake-hold.
  6. Sep 27, 2023 at 5:28 PM
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    Does it flash "BRAKE" on the screens and then slam the breaks on just after you start moving? That's happened to me and you have to turn down the sensitivity on the collision avoidance system.
    That kind of pissed me off when it happened because there was no one in front of me for at least 15 yards and I was barely moving but the BMW behind me damn near ass packed me and he was pissed too.
    In general I hate technology that thinks it knows how to drive better than me.
    KNABORES likes this.
  7. Sep 28, 2023 at 4:42 AM
    Lilfoot
    Lisa
    Thanks, I use the hold button regularly when I'm in town, it's a good feature.
  8. Sep 28, 2023 at 7:58 AM
    Lilfoot
    Lisa
  9. Sep 28, 2023 at 8:00 AM
    Lilfoot
    Lisa
    Hey thanks, this is exactly what it's doing.
    I'll break out the owners manual and figure out out to tweak it.
  10. Sep 28, 2023 at 8:39 AM
    KiloOps
    KiloOps New Member
    Dustin
    Go to the settings screen and hold the OK button down on the PCS option and then change it to the low sensitivity.
    Screenshot 2023-09-28 at 8.37.28 AM.png Screenshot 2023-09-28 at 8.37.37 AM.png
