Low Speed Timing Belt Break... Need advice
Discussion in '1st Gen Tundras (2000-2006)' started by violinriver, Sep 23, 2023.
  1. Sep 27, 2023 at 7:23 AM
    #61
    Broken valve typically takes other things with it. Sometimes piston heads, sometimes rods with that, sometimes the valve guides, the sealing surface etc. Requires removal of the head to repair, potential resurfacing or re-machining damaged areas. Labor is the killer on engine repairs these days. Cheaper to pull the whole lump and put a new lump in usually.
  2. Sep 27, 2023 at 1:07 PM
    #62
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Personally I would pull the heads off and have a look. It's not a hard thing to do. You can replace the valve if that one is the only bent one. Don't machine the heads. Toyota doesn't recommend it because you can change the valve timing. If the seat is good just install the new valve and clean the heads. Fhe head bolts are torque to yield and need to be replaced.
    dbittle likes this.
  3. Sep 27, 2023 at 5:45 PM
    #63
    violinriver
    violinriver [OP] New Member
    2005 Tundra TRD Double Cab
    That’s not off the table. I have never done that before so need to dig into that and see what it entails. I have a feeling that the damage is limited to the right cam and possibly just that #8.
    shifty` likes this.
  4. Sep 27, 2023 at 6:17 PM
    #64
    Hell yeah. I like this guy! :thumbsup:
    ToyoMafia likes this.
  5. Sep 27, 2023 at 7:27 PM
    #65
    violinriver
    #65
  6. Sep 27, 2023 at 7:33 PM
    #66
    My confidence would be low due to never having done it before.
    That, and after reading the woes in this thread: https://www.tundras.com/threads/multiple-misfires-after-rebuild-fixed.110071/
    Where the timing ended up being the root cause, I know I'd need to dig into the service manual to follow instructions on that one, which is not my normal M.O. (or need)
    I think @Tim Berframe went through something similar on his '06 which would be similar to yours and may be able to give input, I can't recall if he opted to do his own after similar problems hit him when a mechanic sold him a truck that he "redid the head gaskets on" improperly: https://www.tundras.com/threads/head-removal-with-crashed-valves.128931/
    But ... I dunno. I see people on here do things every day at home that impresses me, so ... I'd love to be impressed here too.
  7. Sep 27, 2023 at 7:43 PM
    #67
    violinriver
    The more I look at it the more straightforward it seems. I’m already knee deep in it- at this point I’m thinking I should go all the way. There are also some parts trucks locally with good motors where I could probably just pull the head for pretty cheap and slap her on with some new gaskets and bolts.
    Almost feels simpler than figuring out the logistics of finding the right mechanic, towing the truck, and the waiting game.
    “First time for everything” is how I’ve avoided paying for a mechanic for 20 years I suppose….
  8. Sep 27, 2023 at 8:09 PM
    #68
    EmergencyMaximum
    Your bravery is commendable! I feel positive vibe just visiting this thread!
  9. Sep 27, 2023 at 8:21 PM
    #69
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Wait untill you take it apart. The cam should be fine and if it's just a valve just pop a new one in.
    Get a shop manual.
    #69
  10. Sep 27, 2023 at 8:38 PM
    #70
    If they were all that simple everyone would just fix em. Here’s hoping though.
  11. Sep 28, 2023 at 4:26 AM
    #71
    tvpierce
    tvpierce Formerly New Member
    Maine
    I agree this is a job you should DIY if you have the time to do it and the truck isn't your sole means of transportation. As you say, parts trucks are relatively easy to come by in these parts because the frames and bodies have rusted out so they no longer pass inspection -- rendering them almost valueless. First thing I'd do is take the head off and see what's what in there. Is there valve damage? Is there piston damage? Was there any debris from the collision that scored the cylinder walls. With those questions answered and a parts truck in hand, you can assess whether is best repair your current engine with 280K miles or swap the whole engine from the parts truck.
    dbittle likes this.
  12. Apr 25, 2024 at 4:59 PM
    #72
    violinriver
    I’m going to close the loop on this thread. Found a 4.7 on FB Marketplace with 195k on it for $1000. The seller asked me if I wanted a video of it running as he hadn’t pulled it yet. Long story short after asking- he was willing to swap the motor and replace all of the timing components for an additional $2000. He had it done in two weeks in his spare time. Truck is running like a top again and I couldn’t be happier with how it all worked out. Could have been much worse.
    tvpierce, w666, shifty` and 2 others like this.
  13. Apr 25, 2024 at 6:53 PM
    #73
    Double-check that he routed that crank position wire correctly :rofl:
