Method wheels center bore
Discussion in 'Wheels & Tires' started by Tom, Sep 27, 2023.
  1. Sep 27, 2023 at 1:46 PM
    Tom
    Tom [OP] New Member
    Is it me or the center bore isn’t matched up? 2022 tundra
    maybe someone from Method wheels or knows something something if they have wheels that fit 3gen tundras without use of rings.
    so I checked method website and now see them list the spec for the hub bore at 106 for 705 wheels. I didn’t get the rings with my order at discount or method didn’t put them in the box. The 3 gen tundra hub bore is 95 said by members here and other place I’ve checked.
  2. Sep 27, 2023 at 1:51 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Older toyotas are 106mm hub bore, 3rd gen is like 97mm or something.
    Tom[OP] likes this.
  3. Sep 27, 2023 at 2:15 PM
    need some rings
  4. Sep 27, 2023 at 2:30 PM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Hub centric rings for 2022+ Tundra
    Aftermarket wheels tend to have bigger bore size to fit multiple vehicle. Need hub centric rings to fill in the gaps. 3rd gen Tundra hub bore size is 95.1mm.
    bulldog93 likes this.
  5. Sep 27, 2023 at 3:32 PM
    Tom
    Tom [OP] New Member
    I feel like discount tire owe me some rings. Got wheels from them. Should the rings be included? I drove 12k already like this. Had tires balanced today and asked them to leave covers off and discovered this.
  6. Sep 27, 2023 at 3:50 PM
    Tom
    Tom [OP] New Member
    I just don’t see a small company like Stealth Wheels can produce a wheel that fits and a big company like Method can’t. That’s unreal
  7. Sep 27, 2023 at 8:05 PM
    Fxclm5
    Fxclm5 New Member
    stealth only makes like toyota and like maybe jeep parts if im mistaken, method does every make and model under the sun and then some...
    also methods ship with the spacers - if you purchased them direct from method, or at least at 1 point they were, but have seem many posts where the new user never mounts them, ppl who say you gotta get rings need to talk to those who arent running rings - majority of the ppl arent is my guess
  8. Sep 27, 2023 at 9:21 PM
    Wood-Dro
    Wood-Dro New Member
    One of the reasons I picked Icon wheels. They have the exact hub size for the new Tundras.
    SoCal_Erik and Sean492 like this.
  9. Sep 27, 2023 at 10:29 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    FN BFDs also have the correct hub bore.
  10. Sep 28, 2023 at 6:04 AM
    TitleFight88
    TitleFight88 New Member
    I talked to Method about this because the rings that came with the wheels don't fit. The said we don't need rings, they are lug centric. You need extended thread lugs with a 60deg chamfer, not the standard ball seat lugs.
    Tire discount mounted and balanced mine. When I hit the highway, I was bouncing all over the place. Turns out, the tech put ball seat lugs on. Changed them out for the ET lugs and it was smooth as butter. I did end up buying the hub rings just in case I still had vibration, but don't. Still plan on putting them on as belt and suspenders, but according to Method, you don't need them.
    Shout out to Method CS, dude was top notch and helped me figure out what was going in like 10 min.
    Tom[OP] likes this.
  11. Sep 28, 2023 at 6:09 AM
    Interesting take if Toyota designed for the hub to carry the weight, then hub centric would be preferred.
  12. Sep 28, 2023 at 6:43 AM
    TitleFight88
    I mean, there are many people on here running aftermarkets without rings. If it were a major issue, we'd hear about it. I am going to put the rings on to be overly cautious, but I think think most will be fine with the et lugs
    Tom[OP] likes this.
  13. Sep 28, 2023 at 6:47 AM
    So we’re all cool with this but everyone will die if they run spacers that aren’t hubcentric. Got it.
  14. Sep 28, 2023 at 6:55 AM
    Wood-Dro
    Wood-Dro New Member
    Rings = Cheap insurance.
  15. Sep 29, 2023 at 6:35 AM
    TitleFight88
    Uh, okay... I'm just reporting what Method engineering informed me about their designs and testings. No opinion on spacers provided here.
    I have rings for cheap insurance because thats what I wanted to do.
    Tom[OP] likes this.
  16. Sep 29, 2023 at 6:39 AM
    I was summarizing every non-hubcentric thread conversation into one sarcastic comment. Wanting to be scientific, here's some information about why the two are different.
    https://www.machinedesign.com/faste...ence-between-lugcentric-and-hubcentric-wheels
    "A problem arises when using a lug-centric wheel on a vehicle and suspension that was originally a hub-centric design. Without the hub’s support, road impacts can deform lugs enough to where the wheel is no longer concentric with the hub, leading to vibrations. This can reduce the clamping force of the wheel to the hub. Road loading conditions can then move the wheel around on the hub, as can be seen by the worn holes in the image below of a lug-centric wheel used on a hub-centric vehicle."
  17. Sep 29, 2023 at 6:44 AM
    Tom
    Tom [OP] New Member
    I don’t off road my truck just use for work hauling heavy loads of water. It’s got 33k on it. How much damage can happen in 12k ? Thanks.
  18. Sep 29, 2023 at 6:48 AM
    Probably very little to none.
  19. Jan 10, 2025 at 7:50 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4, 2016 4Runner
    what was the vote size? 95.1? Just ordered some wheels.
  20. Jan 10, 2025 at 11:28 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
