Help identify 4WD control module connectors, 2015 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mehnock, Sep 27, 2023.
  1. Sep 27, 2023 at 7:45 AM
    Mehnock
    Mehnock [OP] New Member
    Tundra 2015 SR 2WD
    Leather Seats, leather wrapped steering wheel + audio controls, auto folding mirrors with turn signal, Android auto 10in head unit, working on 2wd to 4wd conversion
    Can someone help identify these two connectors for a 2015 Tundra 4x4, they plugin to the 4WD control module and interface to the truck, 4wd selector switch, transfer case and ADD.
    I need to buy them to help with some wiring I'm working on
  2. Sep 27, 2023 at 9:22 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    You need to buy them, as they are not in your truck anymore?
    Are you trying to add the full 4x4 system? Or?
  3. Sep 28, 2023 at 11:50 AM
    Mehnock
    Tundra 2015 SR 2WD
    Yes, I'm converting my truck to 4WD. Once I get these connectors, I'll create a custom harness to connect the 2WD/4WD HI/LOW switch on the dash and drive the ADD and transfer case.
  4. Sep 28, 2023 at 12:12 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I would rather bypass the 4WD ECU and just have toggles switches for the ADD and 4HI/LO.
  5. Sep 28, 2023 at 12:16 PM
    Mehnock
    Tundra 2015 SR 2WD
    Then I would not have any feedback on whether everything engaged. If I wire everything in then I get status lights on the dash.
  6. Sep 28, 2023 at 12:19 PM
    AZBoatHauler
    So.Arizona
    I’d trust my senses more than a light. It’s pretty easy to hear and feel when 4x4 engages but to each their own.
  7. Sep 28, 2023 at 12:19 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Can use LEDs.
    I've messed around a bunch with the 4WD ECU. That thing is very finicky.
    Mehnock[QUOTED][OP] likes this.
  8. Sep 28, 2023 at 12:25 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    The 4WD ECU has to be connected to the CAN BUS so that it can communicate with a whole bunch of other systems. If it can't talk properly to any one of those systems OR is actually getting a message that the other system has a fault, then it's going to prevent you from shifting to/from 4wd
  9. Sep 28, 2023 at 12:28 PM
    Mehnock
    Tundra 2015 SR 2WD
    Then plan B will be diy switches/lights but I'm going to try factory first. It's not for the looks as I've moved the 2008 Limited interior into my 2015 SR truck and switched from front bench (with the middle seat) to center console... a little cutting and I made it fit.
  10. Sep 28, 2023 at 12:29 PM
    Mehnock
    Tundra 2015 SR 2WD
    Correct, I do plan to wire into the CAN bus, otherwise no dash lights.
  11. Sep 28, 2023 at 12:34 PM
    Mehnock
    Tundra 2015 SR 2WD
    I'll be using the 2015 4WD Control Module... I have everything in the 2008 (bought a limited 2008 4WD with a bad frame for parts) but I compared schematics and the 2015 wiring is lot simpler so I'm buying the parts needed for the 2015 setup but cannot identify these connectors.
    I went to a local dealer last night and they only sell the entire dash harness at $2,700+, no thanks!
