Tick when I shift into drive or reverse
Discussion in '1st Gen Tundras (2000-2006)' started by Konah1, Sep 2, 2023.
  1. Sep 2, 2023 at 7:10 PM
    Konah1
    Konah1 [OP] New Member
    Kevin
    New Jersey
    06 tundra 4x4 DC
    It sounds like two drum sticks hit together. Happens only once also when taking off from a start. Everything is greased. Any thoughts
    Reverse is the same one tick and away I go
  2. Sep 2, 2023 at 7:25 PM
    shifty` Animals and insects don't do drugs
    Could be a u-joint. You try propping up your phone under the truck with the camera rolling to see if you can pinpoint what's clicking?
    You're 4WD so the TSB on crossmember failure doesn't apply to you. You're also in NJ, which means rust, have you checked to make sure nothing on the frame is cracked?
  3. Sep 2, 2023 at 7:53 PM
    Konah1
    Kevin
    New Jersey
    06 tundra 4x4 DC
    Frame is clean. I thought u joints made more of a clunk ? This it a tap. Sorry if my description is subpar.
  4. Sep 2, 2023 at 7:56 PM
    Video would help. If you take one, you can drag and drop it into www.imgur.com then copy/paste the URL here for us, it'll show.
  5. Sep 2, 2023 at 8:04 PM
    Konah1
    Kevin
    New Jersey
    06 tundra 4x4 DC
    I’ll get to the video tomorrow. Thank in advance for your help. ✌️
    shifty` likes this.
  6. Sep 3, 2023 at 8:38 AM
    Mr Badwrench
    Mr Badwrench New Member
    There are splines where the front and rear portions of your rear driveshaft mate together. The driveshaft is joined at the center carrier bearing. If you separate the driveshaft there to access the splines and you grease them, I am betting the sound goes away. There is a castle nut that slightly backs off overtime and allows the splines to move very, very slightly but it creates that distinct sound that you have described.
    I've had this same issue with a 2003 Tacoma and my 2001 Tundra. It's pretty easy to fix and it just requires some high pressure grease and about 30 minutes of your time.
    shifty` and Konah1[OP] like this.
  7. Sep 3, 2023 at 8:44 AM
    Konah1
    Kevin
    New Jersey
    06 tundra 4x4 DC
  8. Sep 3, 2023 at 8:50 AM
    Mr Badwrench
    If you remove this flange via the castle nut, you will see the splines. Take the nut off and tap on the flange with a block of wood or something to remove it. Slop some grease on there and you should be good to go.
    Konah1[OP] and des2mtn like this.
  9. Sep 3, 2023 at 8:55 AM
    Konah1
    Kevin
    New Jersey
    06 tundra 4x4 DC
    You Sir are a genius. Thanks again
    I’ll get to it this afternoon. And post updates.
    So f-in excited
    Mr Badwrench likes this.
  10. Sep 3, 2023 at 10:50 AM
    atomicnugget
    atomicnugget My bones hurt
    New Jersey
    2001 V8 Limited Access Cab 4x4 w. TRD package
    If your feeling the extra credit, mind documenting your step by step process either through video or pictures so that any folks with similar issues can just refer to yours in the future?
    Konah1[QUOTED][OP] likes this.
  11. Sep 5, 2023 at 8:44 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    This is just a guess. But if it seems to tick at same speed 8-10mph its your abs "setting". Does it always happen around 5-10 when first driving or backing? If so its normal. It very well could be whats mentioned above also.
  12. Sep 27, 2023 at 4:54 AM
    Konah1
    Kevin
    New Jersey
    06 tundra 4x4 DC
    This was it!! Was able to tighten the castle nut about a quarter turn after all was said and done. Thank you so much. After about a year of ticks I’m pulling away silently, well as silently as a gen1 gets anyway. Cheers
    shifty` and BluegrapeVr6 like this.
