2.5 Gen long travel CV axels
Discussion in '2.5 Gen Tundras (2014-2021)' started by Hammontree306, Sep 25, 2023.
  1. Sep 25, 2023 at 10:46 PM
    Hammontree306
    Hammontree306 [OP] New Member
    Brandon
    Tundra
    Camburg Long travel race kit
    Hey guys I have pretty much exhausted all avenues and figured someone here has either delt with the same thing or knows the fix. I have a Tundra with the Camburg race series long travel kit. (2.5 inches longer than stock) the CV axels broke and Toyota is on national back order for them. (You use the OEM CV’s and remove the shaft and replace it with Camburgs 2.5 extended shaft that utilizes the stock spline, Camburg says it will ONLY work with OEM CV housing due to fitment) I was looking at the RCV but was told by someone they are no good. Looking to see if anyone here has ran into the same problem or if anyone knows of another Toyota CvV axel that uses the same CV housing as the Tundra but the shaft is different? Thanks guys!!!
  2. Sep 26, 2023 at 7:04 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
  3. Sep 26, 2023 at 8:14 AM
    Vizsla
    Vizsla 2 = 2.5
    Not much choice right now, wait it out or grab used ones from EBay or junkyard, they have been back ordered for months. Used to be a few remans out there that might work, but other than the link below(have no experience with this one) they seem to be gone now also.:notsure:
    https://www.amazon.com/Cardone-60-5252-Remanufactured-CV-Axle/dp/B004QKRF44?crid=3CP9LYGNXK3T6&keywords=2008+Tundra+cv+axle&qid=1695739253&replacementKeywords=cv+axle&sprefix=2008+tundra+cv+axle%2Caps%2C146&sr=8-18&vehicle=2008-76-1033------------&vehicleName=2008+Toyota+Tundra
    RCV for sale - AZ Classifieds
    reywcms likes this.
  4. Sep 26, 2023 at 8:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep, backorder issues. Vizla has a set of rcv’s that can hold you over
    Vizsla likes this.
  5. Sep 26, 2023 at 8:33 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Holy shit $800 for the RCV axles? That's a deal!!
    Vizsla[QUOTED] and reywcms like this.
