  1. Sep 25, 2023 at 7:10 PM
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    I'll have to check that out. That's the one you have to weld yourself right? And then you had it powder coated ?
  2. Sep 25, 2023 at 7:23 PM
    I like that you covered up the lifeguard with a lifeguard.
  3. Sep 25, 2023 at 7:25 PM
    I had it blasted and then I monstalined it along with my fender flares at the same time @RUSTYNUTS
    I heavily modified the corner mount for the swing pivot and the wings for stability
    DJenerated, RUSTYNUTS and oscardog86 like this.
  4. Sep 25, 2023 at 7:50 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Bear with me this is the first time I’ve ever quoted multiple stuff in one response so hopefully the text below isn’t a giant disaster.
    @des2mtn Thanks for the warning on the single leaf. I guess I’ll pass on that. Based on your situation - I suppose I could just get the ATS oem replacement pack then chop up the set I have on the truck now for the added leaves? I’m no fabrication genius but I do at least know my way around an angle grinder. Then I’d be able to semi-customize the lift height. This is an interesting option. Did you get a lift equal to just the thickness of the added leaves or did you get more based on the arc of the bastard ones? And how do you keep them from squeaking without the spacers on the bastard ones?
    @shifty` I don’t pull much now, but I may start more in a year or so - we’re saving up to buy a few acres which would no doubt lead to pulling stuff. On the height - I already had to talk myself down from 3”. I want to clear 275/70/17 toyo open country’s. So I was thinking 2” would be necessary. I’m fine with a diff drop, they’re pretty cheap. And I’m ok with ucas at some point, but would like to be able to put it off a little bit - which it seems is doable at just 2”. I’ll have to think on that one.
    And I too wish I was closer but alas. Has anyone ever tried to ship parts to each other? Or does the freight fee just make it too expensive on larger/heavier stuff?
    @DJenerated Yeah I may be. The wheelers AAL plus the oem leaf pack from ATS still only totals like $460 plus tax and shipping. Not bad I suppose especiallly compared to 1” deaver lift for $1100.
    DJenerated[QUOTED] likes this.
  5. Sep 25, 2023 at 7:58 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    the dirt builds up in the back corners. Look from the back up to the top of the wheel arch. I always fluid film between the fender and the wheel liners since wheel arches always rot on trucks. I also use the hose to flush out the front fenders from the bottom up & from the open door (if you don't have foam blocks). There's always leaves & pine needles in the bottoms of the front fenders & they hold the damp in there.
    Oh - don't forget those cross bars under the bed - those need cleaned out too.
  6. Sep 25, 2023 at 8:25 PM
    Haven't tried; freight would be spendy. Trying to find an adequate box is also difficult. ATS ships their stuff bare, just metal-banded together. FedEx lady made me come pull the part out of the truck. "I can't lift this!!"
    And re: Not pulling anything. Leaf spring torsion will happen carrying loads or hauling stuff. Blocks are just a bad idea, unless you only, singularly, intend to drive on the street.
  7. Sep 25, 2023 at 8:25 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    That's not at all what I expected. That's a neat way to go about it.
    On this note, this crossmember rotting is pretty much what gets everyone a new free frame these days, it did for me. Oddly they didn't change the design at all on the new ones so it's still the same way.
    Here's my original frame.
    bmf4069 likes this.
  8. Sep 25, 2023 at 9:25 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Just wanna throw out a friendly warning with the pizza cutters; pay extra attention to traction in the rain. I ran a set of 35x10.5x17's for a minute, and they were shit on wet pavement. BFG KO2's. They'd spin everytime starting from a stop, I'd have to feather the gas to get moving. I did get them used, so it's possible they were stale, but they weren't cracked so couldn't have been that old. Not trying to scare anyone or talk anyone out of buying them. Just pay attention in wet weather is all. As @shifty` would say; YMMV
  9. Sep 25, 2023 at 9:29 PM
    dirtnsmores
    Southern CA
    Thanks for the heads up. Haven't had that problem
    in heavy rain with mine (Toyo tires) on the Tacoma, granted it's a lot lighter. But I DID have that problem with my 265 ko2s after about 25k miles. Truck pretty much did a 180 getting onto the freeway at a slow speed. Always sliding all over the place when the ground was wet. Never again will I run those.
  10. Sep 25, 2023 at 9:57 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    ive had better luck in the rain with my skinnies than the wide bois.. but tire compound plays a huge role in this.
    and my last 2 sets of KO2s were utter dog shit in rain. the 285s and the 265s on my tacoma
    the coopers have been better by far. but eh.
  11. Sep 25, 2023 at 10:15 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I installed a similar generic kit on a Frontier King Cab that I had prior to my Ferd. Remove the window roll handle, remove the door panel, find the plastic gear that fits around the handle shaft, and install the motor. Its not very difficult to install.
    https://youtu.be/uzMVuTPitxg
  12. Sep 26, 2023 at 3:45 AM
    I've heard quite a few people say ko2s are terrible in the rain. My Coopers did pretty good in the rain.
  13. Sep 26, 2023 at 4:58 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    Another possible option, if you do want to make your own bastard leaf packs, is sweet talk @Mr.bee into selling you some of his stash. He's got several leaf packs lying around and I know some of em have progressive AALs on em.
    It would probably save you a ton and give you an excuse to drive out to the heartland, where the stars at night are big and bright.
  14. Sep 26, 2023 at 5:03 AM
    DJenerated
    Dija
    The Lone Star State
    shifty` likes this.
  15. Sep 26, 2023 at 5:09 AM
    DJenerated
    Dija
    The Lone Star State
    Ko2 was the problem bro :p
    RUSTYNUTS[QUOTED] and KNABORES like this.
  16. Sep 26, 2023 at 5:10 AM
    DJenerated
    Dija
    The Lone Star State
    Ko2's are notoriously bad in rain.
    I'll never understand why they're so popular.
  17. Sep 26, 2023 at 5:12 AM
    DJenerated
    Dija
    The Lone Star State
    I've had the Cooper ATPs and AT3XLTs and they've been great. If Cooper make the ST Max or ST Pros in 35x10.5r17 I'd try them next
  18. Sep 26, 2023 at 5:51 AM
    I'm pretty sure kenda is about the only tire in that size. That or some weird off brands.
  19. Sep 26, 2023 at 6:26 AM
    DJenerated
    Dija
    The Lone Star State
    Rusty said he had ko2's in that size... You liked his post! :facepalm:
    RUSTYNUTS likes this.
  20. Sep 26, 2023 at 8:03 AM
    They don't make them anymore.
    RUSTYNUTS and DJenerated[QUOTED] like this.
  21. Sep 26, 2023 at 8:15 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I'm liking the Toyo m-55's.
  22. Sep 26, 2023 at 8:31 AM
    DJenerated
    Dija
    The Lone Star State
    They should stop making ko2's all together :devil:
    bmf4069[QUOTED] and RUSTYNUTS like this.
  23. Sep 26, 2023 at 8:36 AM
    The time is coming, KO3s were announced.
  24. Sep 26, 2023 at 8:43 AM
    DJenerated
    Dija
    The Lone Star State
    I'd sooner give the KM tires a try than the KO tires
  25. Sep 26, 2023 at 8:51 AM
  26. Sep 26, 2023 at 9:01 AM
    DJenerated
    Dija
    The Lone Star State
    :deadhorse::D
  27. Sep 26, 2023 at 9:25 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'd go with the ATS HD for 1.5 lift and then either an aal or take a leaf from your current leaf pack and add it in.
    DJenerated likes this.
  28. Sep 26, 2023 at 10:07 AM
    Brayblade
    Brayblade New Member
    2003 Tundra SR5 TRD
    Tactical Oil Change
    This was a few days ago now but I just recently put 5100's and new wheels and tires on the truck. Did the work myself and I was pretty surprised with how simple it was to replace the suspension. Got 1.5in of lift on the front with the ring on the 3rd spot on the billies and I think it leveled out the truck nicely! Here's some before and after pics...
    Bonus photo with all the kayaks loaded!
  29. Sep 26, 2023 at 10:07 AM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    My order was cancelled. I phoned them and they said that this part is no longer available.
    des2mtn likes this.
  30. Sep 26, 2023 at 10:20 AM
    Still hasn't been cancelled on mine, but I'm sure it's coming soon enough.
    However, this could also be a case of availability in a region. Maybe they only ship if a dealer within XYZ miles of your house has them, allowing them to cut down on freight. Maybe I'll get lucky, and more local inventory is available in the Atlanta metro area?
    I'll reply to both of us if anything moves on my order.
