What is more likely?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mhenchen44, Sep 25, 2023.
  1. Sep 25, 2023 at 11:13 AM
    Mhenchen44
    Mhenchen44 [OP] New Member
    2015 Toyota Tundra
    Shop just replaced the third fuel pump control module in 5 weeks. The last one didn't last one day. They said something deeper was likely causing the FPCM to fail but I don't think they ever tested the actual module off the truck.
    What is more likely - A) there is an underlying issue causing my truck to burn out fuel pump control modules or B) the "failed" fuel pump control modules were not actually failing and instead, there was a loose connection somewhere causing it to seem like it was failing?
    Thanks in advance.
  2. Sep 25, 2023 at 11:34 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I don't know but you can bypass the module and just hard wire the pump into the ignition with a relay. Might be a solution to look at.
  3. Sep 25, 2023 at 11:42 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Bingo. This is what I was thinking too.
    To answer the question directly my guess would be B. That said, pulling a pump and tapping it to power you can find out pretty quickly if the pump is actually dead.
    Mike59 likes this.
