Cargo lights not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigfoot17, Sep 25, 2023.
  1. Sep 25, 2023 at 4:28 AM
    bigfoot17
    bigfoot17 [OP] New Member
    2018 Crewmax TRD Off Road
    So I’ve had my 2018 tundra for about 6 months now since purchasing it from the Toyota dealership. Up until about a month ago my cargo/bed lights worked when I opened the door or if I turned the switch to ‘on’. Then one day I noticed the stopped working no matter what position the switch is in.
    The lights were LED lights which I guessing weren’t the OEM lights because a friend of mine has the same model that is a 2019 version and he has the classic halogen bulbs in his.
    So I checked the fuse and seen it was blown. I put in another fuse with the same amps (7.5) and it blew immediately. Then I put another fuse in again and it blew that one immediately. I like the LED lights personally but wondering if that’s what’s causing the fuse to blow. Any thoughts?
  2. Sep 25, 2023 at 5:19 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Does the fuse only blow when they lights are supposed to be on. As in if the switch is off, you put in a fuse, the fuse doesn't blow immediately, right? If this is the case, i'd start with the bulbs. You have a multimeter? check continuity to ground, pull the bulbs with the switch on and see if you lose continuity.
  3. Sep 25, 2023 at 8:27 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    If the fuse blew immediately after replacing with a new one, you have a short somewhere. I would pull the light housing and inspect the wiring for pinch.
    NewImprovedRon likes this.
  4. Sep 25, 2023 at 10:15 AM
    Check the bulbs also.
