2024 Control Arm TRD Pro ?
Discussion in '3rd Gen Tundras (2022+)' started by Steelhant, Sep 24, 2023.
  1. Sep 24, 2023 at 11:16 AM
    Steelhant
    Steelhant [OP] New Member
    TRD- Pro
    none...new
    Any info out there that the function is better or just cosmetics. my 2023 was built 8/10/23... I figured if there was a problem it would of been changed then....but not sure !! Been reading tire wear issues on TRD Pros.
    Thanks,
    Chuck
  2. Sep 25, 2023 at 7:15 AM
    FLKX
    FLKX New Member
    Would like to know as well!
  3. Sep 25, 2023 at 7:59 AM
    Steelhant
    TRD- Pro
    none...new
    Thank for the reply...my TRD Pro built 08/10/ 2023 should be ok ??
    Thanks Again,Chuck
  4. Sep 25, 2023 at 8:11 AM
    22TXAG
    22TXAG New Member
    Does this change the alignment specs that are on the install sheet for the TRD lift?
