Console outlets OUT 7.5A Fuse Good
Discussion in 'Electrical' started by texasrho83, Sep 23, 2023.
  1. Sep 23, 2023 at 5:11 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep I've got no juice going to my console outlets (cig). Fuse (7.5A) is good. Kinda thinking I may have left something unplugged when I did the aftermarket HU install....is there something in that bird's nest behind the radio that runs juice to the console?
    If not, the problem is gonna be more fun than I wanna have...
  2. Sep 23, 2023 at 5:23 PM
    I forgot about looking into this when you asked about the fuse a little while back. The connector didn't come off of the outlet did it? I would meter the inside of the connector and see if it reads anything.
  3. Sep 23, 2023 at 5:30 PM
    Azblue
    The Dirty T ( ^_^)_且
    I have the same problem and it happened before I did the HU install. I have checked just about every fuse with a tester and have no clue. At this point, I've given up.
    texasrho83[OP] likes this.
  4. Sep 23, 2023 at 6:50 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did you trace any wiring?
  5. Sep 23, 2023 at 6:52 PM
    Azblue
    I made a point to look at everything I could see when I had the dash and center console apart for the HU install. Didn't see anything wrong.
  6. Sep 23, 2023 at 7:13 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Think I'll pull the ports and have a look at them from behind. Run continuity tests to see where the juice quits going into them.
  7. Sep 23, 2023 at 7:15 PM
    Azblue
    Let me know. All of mine in the console are dead. I have a light strip inside the console and a wireless charger in the lid powered from those wires and they are down too.
  8. Sep 23, 2023 at 7:32 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Wow I'd have run alternate power to all of that by now if I were you.
  9. Sep 23, 2023 at 7:36 PM
    Azblue
    True, but it's been a million degrees and I haven't felt like fucking with it. Maybe this winter.
  10. Sep 23, 2023 at 8:02 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Amen to that. I've been holding off several things because I didn't feel like melting while doing the work.
    Azblue[QUOTED] likes this.
  11. Sep 23, 2023 at 8:21 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    To be clear, the fuse for the console is labeled PANEL right?
  12. Sep 23, 2023 at 8:26 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    This is the 2016 diagram
    15A PWR Outlet
    7.5A 5A AM1
    are the fuses to check
  13. Sep 23, 2023 at 8:32 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks Jeff.
    I was looking at this fuse in particular (it has zero juice going to it). Pulled it and looks good.
  14. Sep 24, 2023 at 8:11 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Are you sure? If this fuse is bad or no power none of the illumination lights on the steering wheel, radio, dash buttons would come on at night when the headlights come on.
  15. Sep 24, 2023 at 8:15 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ok back to the drawing board. Must've been an OOF moment.
    The 15A has power. I'll pull the cig lighter ports and get back to ya. Odd that both don't work though....
  16. Sep 24, 2023 at 8:16 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Take a minute to make sure you are looking at the interior fuse box correctly. It can get confusing.
    Look at the fuses and A rating on each end and match them up with the diagram. I think you have a bad fuse you are just mislabeling it on the diagram.
    You have to carefully count and match up the bad fuse to the diagram on the lid. I have gotten it backwards before.
  17. Sep 24, 2023 at 8:37 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  18. Sep 24, 2023 at 8:38 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just did some reconn and all fuses work. Could there be a bad one under the hood?
  19. Sep 24, 2023 at 8:48 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    According to the diagram the only two fuses are the ones here in red. If not that the relay is next to check. Or voltage at the power port itself. I remeber one guy hooked a mini fridge up to his rear one and it burned the ground wire up.
    He had power at the port still but no good ground connection.
    TRDFerguson likes this.
  20. Sep 24, 2023 at 8:52 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    How are you testing the fuse? Just visually? And it should be the 15A PWR OUTLET fuse I believe, not the PANEL or CIG fuses.
  21. Sep 24, 2023 at 9:19 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Just using a tester light then pulling and visually making sure they're not compromised
  22. Sep 24, 2023 at 9:21 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes those fuses are good
  23. Oct 14, 2023 at 2:19 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    With the weather finally decent, I'm tearing into the console to see what's up with no power to my outlets.
    Anyone know what this is to?
  24. Oct 14, 2023 at 2:32 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Oh so that's what it's for...
  25. Oct 14, 2023 at 2:32 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    And now I have power to my outlets. Easiest fix ever :rofl:
  26. Oct 15, 2023 at 6:02 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    So who unplugged the connector in the console? I assume it being undone was your only problem?
  27. Oct 15, 2023 at 6:09 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I guess I did when I was rigging up my Auxbeam switch panel. Yeah once that was reconnected, I had power to both outlets. Love those quick easy fixes!
    Jeff_5_7[QUOTED] likes this.
  28. Oct 15, 2023 at 7:01 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Just saw this thread and was going to ask if you had disconnected that connector at any point in time...It's connector TJ1 in that diagram that Jeff posted.
    Don't ask me how I know to check that connector...
    :anonymous:
  29. Oct 15, 2023 at 7:08 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Lol. Yep. I won't ask. Something tells me you can empathize.
