Any reason to keep stock air box?
Discussion in '2.5 Gen Tundras (2014-2021)' started by mestes1999, Sep 22, 2023.
  1. Sep 22, 2023 at 10:21 AM
    mestes1999
    mestes1999 [OP] New Member
    Marcus
    2020 Tundra SR5 CrewMax
    Just installed the TRD Pro intake, is there any reason for me to keep the OEM stock airbox, filter, and rubber assembly?
    Black@Blue19 and Rykr like this.
  2. Sep 22, 2023 at 10:33 AM
    Rykr
    Rykr New Member
    2023 SR5 TRD Sport 4x4 MGM
    I’m about to make a similar decision but I’m leaning towards just putting the drip in TRD filters in. Everything I’ve read is that Toyota stock boxes are great and just the filter upgrade is sufficient unless you want that “look”.
    To answer your question I see nothing wrong with keeping them just in case. But I have the mindset of if I don’t use something regularly within a 6 month time frame I get rid of it. That doesn’t apply to specialty items/tools of course.
  3. Sep 22, 2023 at 10:37 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I kept my stock box until I was able to donate it to a forum member in need of one.
  4. Sep 22, 2023 at 10:46 AM
    Yes because you wasted $400 on an intake that had 0 gain other than cosmetic appearance.
    Joro43, KOTOC79, Stumpjumper and 9 others like this.
  5. Sep 22, 2023 at 10:58 AM
    coTony
    Tony
    Montrose, CO
    The answer to that question is yes, to save $400
    Joro43, Stumpjumper and Azblue like this.
  6. Sep 22, 2023 at 11:01 AM
    Good answer. That was better than mine lol. :101010:
  7. Sep 22, 2023 at 5:06 PM
    el_conquistador
    el_conquistador New Member
    Kansas City, MO
    2019 Toyota Tundra 1794 Edition
    Just a few
    How boring.
    OO, Yeah I kept mine. My new one sounds way better. Have the old just in case I need it. :)
    BoyHowdy likes this.
  8. Sep 22, 2023 at 6:31 PM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    I just drop a k&n oem filter in and done!:thumbsup:
  9. Sep 24, 2023 at 6:00 AM
    eagleguy
    eagleguy New Member
    I used to use K&N air filters on everything including my classic car. I then read an article that they were actually not that good. They supposedly do not provide the air flow and horsepower improvements listed in their ads as they were actually more restrictive than stock. Also if not properly maintained they do not filter as well. Went back to the NAPA Gold.
  10. Sep 24, 2023 at 6:02 AM
    mestes1999
    Marcus
    I should’ve known better than to ask such a simple question on here.
  11. Sep 24, 2023 at 6:12 AM
    K&N's are not less restrictive than stock. K&N's will pass more particles because of this. A known issue widely discussed here over the years. Efficiency vs airflow. K&N's are oiled cotton gauze. A totally different medium than what OEM and OEM replacement filters use. Pretty much all aftermarket filter makers make dubious claims that in most cases are true if you drive at 5500 to 6500 rpms all the time. Efficiency vs airflow. Apples and oranges. The ideal filter will maximize both.
    excelw and 2mchfun like this.
  12. Sep 24, 2023 at 6:22 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I kept mine for over a year until I got tired of moving it around and looking in the box to see what is in there. Gave it to someone that needed those parts.
    I figured if it has not moved in a year or two I do not need it.
  13. Sep 24, 2023 at 6:23 AM
    It's always best to hang on to your pull offs, unless you never ever plan on selling your truck. Dealers won't give you a penny more for your aftermarket goodies.:thumbsup:
  14. Sep 24, 2023 at 6:28 AM
    Black@Blue19
    Ken
    SE Texas
    Pitch it!!!!! Or try to sell it for what you can get.
    Black Wolf likes this.
  15. Sep 24, 2023 at 6:53 AM
    eagleguy
    eagleguy New Member
    A simple internet search asking if K&N air filters are better than stock provides lots of verified stats for air flow and filtration. Worth a look see.
  16. Sep 24, 2023 at 7:02 AM
    I've done my home work on this as many of us here have. A simple search here on this forum will enlighten you on this as well as what other members here besides myself have actually experienced over the years. Pros and cons. Worth a look see. I bought my first K&N in the eary 70's. You can use your internet "verified" stats. Meanwhile, should the OP keep his air box or do you want to focus on K&N's?
    831Tun likes this.
  17. Sep 24, 2023 at 8:14 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    It was a question that common sense would answer and didn't need to be asked. There's only so many reasons to keep it and they were already given. Did you not like the answers? Were you expecting some obscure, profound reason to keep it that you couldn't think of on your own?
    I would keep it in case you ever want to build a Tundra from scratch. You already have one part in the bag. You could make a modified lawnmower intake, filter your combustion air on your furnace, make a butt plug adapter and use it to filter farts,...I can probably come up with 100 more if the answers already given didn't cut it.
    Skaufma0 and Shanet421 like this.
  18. Sep 24, 2023 at 8:17 AM
    eagleguy
    eagleguy New Member
    Yes he should. If you choose to believe forum post rather than documented facts so be it! I was once believer and have done air cleaners and boxes as well on different vehicles. I never felt any difference and Dyno test never showed any improvement with K&N. If fact in many cases it was just the opposite. We will just have to agree to disagree on this one. Ok?
  19. Sep 24, 2023 at 8:32 AM
    2mchfun
    You paid for it, there is nothing wrong with it, and tossing it only helps destroy the planet. Therefore, you ought to keep it and figure out a way to repurpose it. I could easily craft something out of the material or at least some of the material. For example, maybe a gutter downspout splash diverter, maybe a cool planter with some miniature cactus for the workbench. Endless possibilities!
    Jaypown, RichterScale and 831Tun like this.
  20. Sep 24, 2023 at 8:34 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I think you're both saying that over the counter "upgrade" K&N air boxes and filters are a crock of shit.
    Sooooo, why the arguing?
  21. Sep 24, 2023 at 10:57 AM
    eagleguy
    eagleguy New Member
    Thats what I say. This was going the path of Trans Coolers, Console Safes and Oil Change intervals. It comes down to what the OWNER wants to do. The rest is just opinions. We need to agree to disagree!
  22. Sep 25, 2023 at 5:57 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    Regarding what to do with the original airbox, maybe ebay it. I paid $200 for one with the tube from a 2010 not too long ago because I didn't like the K&N CAI that came with my truck when I bought it. I didn't realize at the time that the air filter is different for the 2010 versus 2020, but it's fine as long as I remember to buy the right one. Point being -- there are ppl out there who want them.
  23. Sep 25, 2023 at 6:08 PM
    blenton
    blenton New Member
    Like THAT ever stopped somebody from asking a question on the forum… what fun would that be? :D
    Also, seems curious that solution number three is a “butt-plug” apparatus. At that point, I’m not really sure I want to hear the other 100 solutions you have. But now I’m morbidly curious… :boink:
    ChesterTundra likes this.
  24. Sep 26, 2023 at 7:57 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Hold on to it if you think you'll want to go back to stock one day for any reason or as a spare for that "what if" situation. If you think you'll keep the new setup long term, then sell the original on marketplace.
  25. Oct 1, 2023 at 8:13 AM
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    I’ll take the stock box if you want to get rid of it.
  26. Oct 1, 2023 at 3:57 PM
    eagleguy
    eagleguy New Member
    Please let us know what if any improvement you see. In the meantime I would keep the OEM stuff!
  27. Oct 1, 2023 at 5:32 PM
    eagleguy
    eagleguy New Member
  28. Oct 16, 2023 at 9:38 AM
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    This is the best reason right here.
    Xcumminsguy likes this.
  29. Apr 26, 2024 at 2:32 PM
    Gump3842k
    Gump3842k New Member
    Richmond, Va
    2023 SR5 Trd Sport
    If anyone still has there stock air boxes I would love to purchase from you. I purchased a used 2023 tundra with an aftermarket AFE Momentum GT air intakes and I would like to take that off and go back to stock.
  30. Apr 26, 2024 at 3:13 PM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Eibach Pro 2R, Dirt King UCA, 285/70/18 Toyo ATIII, Stillen TruPower CAI, OTT
    You'll have better luck looking in the 3rd gen marketplace. This is for 2.5gen :thumbsup:
    But if anybody in So Cal is looking for the stock airbox, I have a spare one that I pulled from a 2018 5.7 part out.
    And to answer OPs original question, as many have said it's definitely best to keep your original parts from your truck. I learned this from my '02 Tacoma by putting a K&N open air intake then many years later throwing an AFE one on there. Which were both big mistakes thinking now that introducing hot engine air is not the best idea. Best intake to have is OEM or at least something completely closed off and sealed. Luckily I saved my stock air box for 20+ years which I'm going to put back in my truck after my engine rebuild.
