Ideas to remove bed liner spray from bolt head?
Discussion in 'General Tundra Discussion' started by Cruzer, Sep 23, 2023.
  1. Sep 23, 2023 at 10:24 AM
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Anyone have a good trick to remove the liner from the bolt head? Need to remove the bed.
    bulldog93 likes this.
  2. Sep 23, 2023 at 10:30 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    I chisel and hammer was effective for me. It popped off pretty easily.
    bulldog93 and 1lowlife like this.
  3. Sep 23, 2023 at 10:33 AM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    2008 Toyota X-Runner
    TRD S/C, headers, APR X1, T56 Magnum 6 spd, NST pullies, Stptech Big Brake Kit, dropped, leather
    Wire brush on the end of an electric drill or similar rotary device.
    It will clean up pretty easily.
    reywcms, bulldog93 and KNABORES like this.
  4. Sep 23, 2023 at 10:35 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Trying to clean the inside of the torx head so I can get my bit in there.
  5. Sep 23, 2023 at 10:36 AM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    Still going with the wire brush.
    bulldog93 and Cruzer[OP] like this.
  6. Sep 23, 2023 at 10:39 AM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    You could also media blast it, but you are more likely have wire brush and an electric drill as compared to a sand blaster.
  7. Sep 23, 2023 at 10:42 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Place the Torx bit as far in as you can, then whack it with a hammer. Remove bit then clean out the debris with a pick till clean.
  8. Sep 23, 2023 at 10:42 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I’ll try it out
  9. Sep 23, 2023 at 10:47 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Definitely made quick work on the head. At least now I can clearly see what I have to scrape out.
  10. Sep 23, 2023 at 10:54 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Was able to pick out the remnants like little cupcakes. :D
    bulldog93, 1lowlife and KNABORES like this.
  11. Sep 23, 2023 at 10:55 AM
    Coupe
    Coupe New Member
    James
    Houston, Texas
    I like it when the plan comes together..........
    Cruzer[OP] likes this.
  12. Sep 23, 2023 at 11:03 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Thanks brotha!
  13. Sep 23, 2023 at 11:11 AM
    Retired...finally
    That's some tough stuff, isn't it.
  14. Sep 23, 2023 at 11:14 AM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Was that with a wire brush? I'm going to swap out my bed tie downs this weekend when the storm is gone.
  15. Sep 23, 2023 at 11:14 AM
    Morebouldersplease
    Morebouldersplease New Member
    G
    Brushy Creek, Texas
    2017 Super White DC TRD Pro
    WKOR Sliders Valhalla shield front and rear plates Falken AT3W 295's Snugtop Highliner Sport
    I just tapped the Torx bit in with a mini sledge and pulled them all for a Decked install. Easy peasy.
  16. Sep 23, 2023 at 11:37 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    bulldog93, 1lowlife and JMB[QUOTED] like this.
  17. Sep 23, 2023 at 11:41 AM
    White 2.5
    White 2.5 New Member
    Mt P, SC
    2020 White DC
    “Pinch” the head of the bolt/torx with a set of pliers and the liner will come right off. Worked like a charm for installing the Decked system.
  18. Sep 24, 2023 at 6:01 PM
    Kyhokie
    Kyhokie New Member
    2017 toyota tundra SR5 4×4 inferno
    3" lift
    I was going to say the same thing, a pair of channel locks will either pop the bedliner right off of that torx head or enable you to spin it out the old-fashioned way, Lefty loosy
    ZappBrannigan likes this.
  19. Sep 24, 2023 at 6:26 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Men came off from just usage. Something smacked the bolt and the Berliner peeled right off.
