Runs like it has a governor?
Discussion in '1st Gen Tundras (2000-2006)' started by Gjoec, Sep 21, 2023.
  1. Sep 21, 2023 at 5:57 PM
    Gjoec
    Gjoec [OP] New Member
    Joe
    2000 4x4 4.7 lifted headers
    Runs fine until I get on the gas to open it up and go and it starts going ba ba ba ba cuts out real bad til I let off on the gas then it's normal again.
    I ve changed the fuel filter no change. I was going to check my fuel pressure but there's no valve on the fuel rail?
  2. Sep 21, 2023 at 5:58 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Check engine light on?
  3. Sep 21, 2023 at 5:59 PM
    Gjoec
    Joe
    No check engine light. There is some codes like the mass air flow and I change that already and o2 sensors codes I changed one that was damaged the rest look fine
  4. Sep 21, 2023 at 6:17 PM
    It’s never the fuel filter!!!
  5. Sep 21, 2023 at 6:17 PM
    In all seriousness, add some details about your truck, mileage, which engine and drive train, cab type, and any recent work or other symptoms.
  6. Sep 21, 2023 at 6:18 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Start with the basics. Clean the throttle body. Rev it up at idle and make sure that the exhaust doesn’t appear to be blocked. Check throttle linkage.
  7. Sep 21, 2023 at 6:21 PM
    These trucks are a little finicky with replacement parts. Use OEM or equivalent (same manufacturer of the original part). MAF would be suspect, what other codes were there? Could be TPS, clogged cats, bad O2 sensors etc. how’s the maintenance history? Timing belt changed?
  8. Sep 21, 2023 at 8:12 PM
    Any codes?
    Have you replaced anything lately? Coils? Plugs?
    What condition are the plugs in/how old are they?
  9. Sep 21, 2023 at 11:19 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Need more details here. What code was it throwing for that? Off brand replacement sensor here can cause issues. Need to go OE Toyota or Hitachi brand sensor from a reliable source.
    KNABORES likes this.
  10. Sep 22, 2023 at 4:08 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Along with the above question about "mass air flow", what damage are you meaning for O2 ?
    Those 2 don't go together unless you mean there is no check engine presently(permanent code stored) and the mass air flow code was temporary(1 trip logic)
    shifty` likes this.
