Trailer Detected Problem
Discussion in 'Towing & Hauling' started by mike9561, Sep 20, 2023.
  1. Sep 20, 2023 at 10:24 AM
    mike9561
    mike9561 [OP] New Member
    2023 Toyota Tundra
    I towed a trailer for the first time today with my 2023 Tundra. When I unhooked the trailer, I am still getting a "trailer detected" message and the RCTA remains off. I suspect some sort of user error on my part, but cannot figure out how to remedy this. Any thoughts will be very welcome.
  2. Sep 20, 2023 at 11:20 AM
    AZBoatHauler
    So.Arizona
    I doubt user error. Sounds like an electrical / software issue. I’d try pulling the negative terminal and seeing if resetting the ECU helps.
  3. Sep 21, 2023 at 4:18 AM
    mike9561
    2023 Toyota Tundra
    Thanks.....the messages ended up clearing themselves the second time I drove the truck after removing the trailer.
    RovingMedics likes this.
  4. Mar 26, 2025 at 5:36 AM
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Had this issue today. Deselected trailer and RCTA came back on. Selected trailer again and no longer showing “trailer detected”
  5. Mar 26, 2025 at 5:46 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No. That’s how it works. Rear cross traffic alert won’t function properly if it detects something behind it, like something you are towing. So it turns it off.
  6. Mar 26, 2025 at 6:27 AM
    Snert
    Snert New Member
    2021 SR5
    I had a similar issue in my last truck which was an F-150. Turned out water/moisture had gotten in the connector after a car wash. Thoroughly blew it out with compressed air and then slathered a good bit of di-electric grease in it, never happened again.
