Anybody add aftermarket rear bumper sensors?
Discussion in '2.5 Gen Tundras (2014-2021)' started by brkncly, Sep 20, 2023.
  1. Sep 20, 2023 at 7:39 AM
    brkncly
    brkncly [OP] New Member
    Oregon
    I have a 2020 Tundra and want to add back up sensors. I now that adding factory rear bumper sensor is nearly impossible due to programming it. So I'd like to add an aftermarket rear bumper sensors, has anybody done this? If so please let me know what kit you got and how you like it please.
  2. Sep 20, 2023 at 7:45 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    @RainMan_PNW added the parking sensors to his rig. I think he said the ECU recognized them.
    RainMan_PNW likes this.
  3. Sep 20, 2023 at 7:56 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    I would advise against the aftermarket sensors, to be honest tried them on several of our work trucks. They are hit or miss and not terribly reliable. We used the ones that most RV'ers or bus conversions use. We ended up using a rear facing camera to address our problems.
    brkncly[OP] likes this.
  4. Sep 20, 2023 at 7:57 AM
    marc32
    marc32 New Member
    Mario
    Maryland
    If I recall he used oem sensors.
  5. Sep 20, 2023 at 7:59 AM
    Saltyhero13
    He did. Yes.
  6. Sep 20, 2023 at 5:14 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Yes
    I added OEM parking sonar
    It’s expensive, finicky, and a pain in the ass (compared to BSM that was relatively plug and play except for the added wiring under the truck).
    One truck I’ve installed it in continues to have intermittent issues with the system not working or partially working (no warranties expressed or implied).
    Factory parking sonar requires a separate ECU, a different instrument cluster (and programming that to the correct ODO), new main body wiring harness (or building your own), new switch, installing all six sensors (they daisy chain off each other for signal), new rear bumper wiring harness, and two added short harnesses in the front fenders.
    90% of the time, mine is turned off. I have cameras that give me better visibility than the sonar does.
  7. Sep 20, 2023 at 5:20 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    RainMan_PNW and RobertD like this.
  8. Sep 20, 2023 at 8:20 PM
    AggiePhil
    College Station, TX
    Useless. I leave mine off. Now the BSM and RCTA is another story. Love those.
  9. Sep 20, 2023 at 8:38 PM
    Saltyhero13
    The RCTA scares the crap out of me sometimes when it goes off. It is sensitive to the approaching vehicle's speed so I've had it pick up vehicles nowhere near my vicinity 100+ feet away in another section of the parking lot. 5 seconds later the dipshit rips by, moving way faster than they should be in a parking lot. Thanks RCTA!
    AggiePhil[QUOTED] likes this.
  10. Sep 20, 2023 at 8:40 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes
    Me too
    And a much easier install (but still a bit involved)
