Black headlights
Discussion in '1st Gen Tundras (2000-2006)' started by Delta57, Sep 20, 2023.
  1. Sep 20, 2023 at 9:31 AM
    Delta57
    Delta57 [OP] New Member
    2006 Red Tundra DC limited
    So I bought these black headlights off ebay that I've been seeing without the amber reflectors cause I love the look of them and I'm curious where people got ones that actually fit properly...mine didn't line up to all 3 mounting holes for the main headlights which I could make work but the corners completely were molded backwards for the socket to twist in...I really want completely blacked out and clear headlights and corners (especially corners cause I wanna do projectors eventually so I can paint the housings whenever I do that) Any links to proper fitting ones would be greatly appreciated and I'll attach some photos of the headlights I bought and will be returning.
    The new ones compared to oem turn signals
    IMG_20230920_105529.jpg IMG_20230920_105601.jpgcould only get 2/3 bolts in at a time I could make it work but with the corners not working I decided I'd be better to just return them
  2. Sep 20, 2023 at 6:44 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  3. Sep 21, 2023 at 7:26 AM
    Delta57
    Damn, yeah I really would like to get rid of the amber reflectors in the side...currently trying to decide If I wanna fuck around and try to make them work or if I wanna just say fuck it and return them :/
  4. Sep 21, 2023 at 4:40 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Do you have an access/regular cab or double? You don’t say, the corner lights aren’t cross compatible. Doesn’t explain the headlights not fitting other than poor quality.
    KNABORES likes this.
  5. Sep 21, 2023 at 4:42 PM
    This
  6. Sep 21, 2023 at 11:13 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I see two light bulbs hanging down in the third picture so that would indicate double cab for OP.
  7. Sep 26, 2023 at 11:33 AM
    Delta57
    Sorry I never got notification of responses I ended up making it work out, the headlights themselves didn't quite line up but I got it to work by putting the top screw in last. But the poor quality that I was talking about with the corner lights is those tabs where flipped around on the new ones I got so when you put the bulb in and twisted it they weren't able to spin. I fixed it by just taking a Dremel and grinding them off the ones that were wrong because I didn't wanna go through the process of returning it.
  8. Sep 26, 2023 at 1:21 PM
    PenderBen
    2003 Tundra AC 4x4
    Let’s see some pics!
  9. Sep 26, 2023 at 2:49 PM
    BigSkyGuy
    BigSkyGuy New Member
    Big Sky Country
    '05 DC Tundra SR5 4x4 TRD V8/tow
    Yes, pictures please! I've been eyeballing those same lights and would love to see how they turned out.
  10. Oct 15, 2023 at 8:30 PM
    Delta57
    I'll make sure to post to this tommorow some pics of them installed
  11. Oct 16, 2023 at 1:23 PM
    itsWarrior
    itsWarrior TEQ_Toothless
    Luke
    North Georgia
    Toothless the 06 Tundra SR5 DC RWD
    Bilstein 4600s, Leveled, LT265/70R17 A/T Tires, Lighting, Cosmetic stuff, Stickers and Morale Patches, Recovery Gear
    It might be a little late but I bought the exact same headlights from AJP Distributors. Fit perfect but just had to very very very lightly file on of the holes for the turn signals. I will send pictures later if you would like them
  12. Oct 16, 2023 at 2:19 PM
    Delta57
    So those are the ones I ordered and yes I ended up just filing down the tabs so I could put the signal bulbs in
  13. Oct 16, 2023 at 2:23 PM
    Delta57
    So these are some pics I just took of the headlights. Also my truck is dirty lmao haven't had a chance to wash it
    20231016_162019.jpg 20231016_162027.jpg 20231016_162035.jpg 20231016_162044.jpg 20231016_162057.jpg
    PenderBen and artsr2002 like this.
