General Supercharger Thread
  1. Sep 17, 2023 at 11:45 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
  2. Sep 17, 2023 at 12:10 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I bet that White truck hauls it.:) that’ll be a fun ride.
    Mdl and STravis[QUOTED] like this.
  3. Sep 17, 2023 at 12:38 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just call me "behind the curve" I guess :rasta:;).
    I never planned to buy this truck. It all started with a search for a rear disc brake conversion kit for my 1st Gen Taco. Then I was always saying that the Tundra doesn't need a S/C, it has enough power. A chance encounter on Craig's List detoured that weak excuse.:facepalm: I am not in control....:rofl:
    Mdl, Tripleconpanna, Silver17 and 5 others like this.
  4. Sep 17, 2023 at 8:12 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Tunes done and the truck runs like a raped ape. New draggy times to follow. Thanks to @JustDSM with OTT for taking the time today.
    I pieced together the stock box lid to fit for the idling and maf initial items and all worked out well.
    New finding with the vented plate in the wheel well. Seeing cooler iat temps much closer to ambient. My theory is the cooler air from the stillen is staying on the box area better. Coming back from the coast I saw 6* above ambient. Which is a long way from where we started initially with this shit prospeed box.
  5. Sep 17, 2023 at 8:23 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Nice. Lucky you had your stock parts.
    Tripleconpanna likes this.
  6. Sep 17, 2023 at 9:51 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Dyno?
  7. Sep 18, 2023 at 1:47 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Oh I didn’t lol had to find one locally, luckily found a few on offerup and Craigslist.
    Mdl and Saltyhero13[QUOTED] like this.
  8. Sep 18, 2023 at 1:48 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No Dyno numbers but we will see what the draggy time says. Should give a good idea. 7k lbs, 37s etc.
  9. Sep 18, 2023 at 4:43 AM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Looks amazing, great work.
  10. Sep 18, 2023 at 12:32 PM
    1UP
    1UP Truck Gang
    Before this last upgrade your numbers were flirting around the hp that most would go full engine rebuild with right?
    Or were these changes and the switch to Whipple purely for a different power/torque curve?
  11. Sep 18, 2023 at 12:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I was on the stock pulley on the Magnuson blower. Reasoning on the switch was a bigger more efficient design with less maintenance than the maggy. I imagine the truck makes some where in the 620-640+ crank given the weight and times I've seen. Maybe 500+whp with 20% loss and my setup.
    Fastlane47 and 1UP[QUOTED] like this.
  12. Sep 18, 2023 at 1:07 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I know I'm not running the most power/boost here on the stock motor. lol
    Mdl, Fastlane47 and 1UP like this.
  13. Sep 18, 2023 at 2:41 PM
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    Less maintenance than the maggy? These are basically maintenance free. Even the guys at superchargers online say so. Replace the coupler with a heavy duty option and you're set.
    Bigger and more efficient, yes, absolutely. But for what 20 hp over a stock mag? As stated before by @snivilous, they will all blow your stock engine the same.
    Mdl, snivilous[OP] and HulkSmurf14 like this.
  14. Sep 18, 2023 at 2:54 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea I'm not swapping a coupler once a year. Mine had an upgraded coupler from a rebuild and didn't make it a year.. Stock engine also yes. But this won't be a stock motor in the long wrong so planning for that. Hp isn't the full picture when doing builds.
    Mdl and Fastlane47 like this.
  15. Sep 18, 2023 at 5:17 PM
    Land Bruiser
    Land Bruiser New Member
    2018 Lexus 5.7
    Harrop 2650, 285/70r20
    I ordered a 77.5mm as well. I've read thru a bunch of the thread and I'm torn.
    Not a Tundra, but a 3UR here. What is the threshold of safe vs pushing limits of internals, blown engine, or when engine life etc is sacrificed? Not going past 550whp?
    I have a 2018 Lexus LX570 with the Harrop 2650 w/85mm-no tune, 37" tires, stock gearing w/8 speed. I live at 10,000ft. I'm installing either 80mm or 77.5mm pulley, walbro450, 775cc inj, prospeed fuel rail and pump jumper and getting a tune halfway across the country.
    Keeping the intake, headers, exhaust stock and was told that made it okay to run the 77.5mm, but if had intake and headers w/77.5 it would make too much power for the stock internals. Is it pushing it that close to the limits of the engine? Thanks
    Mdl, nobodyintexas, e30cabrio and 3 others like this.
  16. Sep 18, 2023 at 5:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    At your elevation, you have nothing to worry about. I'm at 8,000ft and I'm having to overdrive (smaller pulley) the blower just to get to the stock equivalent HP here.
    Mdl, Saltyhero13, reywcms and 3 others like this.
  17. Sep 18, 2023 at 7:51 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Got any pics of this beast?
    reywcms likes this.
  18. Sep 19, 2023 at 3:13 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    all this elevation talk....I'm at ZERO elevation. LOL
    Damn the torpedos, bring on the 77.5mm.
    Mdl, Tripleconpanna, Silver17 and 4 others like this.
  19. Sep 19, 2023 at 4:47 AM
    Land Bruiser
    2018 Lexus 5.7
    It’s pretty tame actually. Here it is with suspension in low, normal, and then high mode.
    mustang67408, Mdl, Silver17 and 11 others like this.
  20. Sep 19, 2023 at 5:54 AM
    ZPhilip
    Philip
    West Chester, PA
    Damn, that is stuffed! Looks damn good!
  21. Sep 19, 2023 at 7:14 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    God I wish the old lady would let me trade her rig in for one of these
  22. Sep 19, 2023 at 8:27 AM
    ssmokedz
    Shelton CT
    Nice score. That is a sweet little truck!
    Mdl and HulkSmurf14 like this.
  23. Sep 19, 2023 at 10:14 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Thanks, I love it so far.
    Mdl likes this.
  24. Sep 19, 2023 at 11:09 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    e30cabrio, Saltyhero13, Mdl and 4 others like this.
  25. Sep 19, 2023 at 11:33 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Maybe @ViktorG can advise on the safe wheel hp lol. Hopefully its more than any of us are pushing lol
    Saltyhero13, Mdl and ViktorG like this.
  26. Sep 19, 2023 at 11:38 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    my lame excuse for the 77.5 is....I don't use much pedal.
    ~4500rpm's max. I reckon that will keep me under grenade level.
    and I'm still driving a highlander....
    hopefully get the truck back Thursday.
    Saltyhero13, Land Bruiser and Mdl like this.
  27. Sep 19, 2023 at 12:47 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Some blow up at stock boost levels and others put out close to 600 whp with no issues.
    Factors that will affect the outcome include tuning, fuel quality, water/meth injection use, ambient temperature, intercooler system performance, truck weight/load/tire size, towing, how aggressive is your daily driving, how long do you stay at WOT continuously etc etc.
    mustang67408, kos221, nags and 9 others like this.
  28. Sep 19, 2023 at 1:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @ViktorG don't want to go there again...unless ya got that built engine waiting.
    ViktorG, Saltyhero13 and reywcms like this.
  29. Sep 19, 2023 at 1:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Totally agree and what I was thinking.
  30. Sep 19, 2023 at 2:04 PM
    Silver17
    Eastern PA
    What would you rather own out of the warranty period, a supercharged 5.7 or the new TTV6?
