  1. Sep 17, 2023 at 12:18 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Returned order to the universe of steering wheel controls
  2. Sep 17, 2023 at 12:27 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    So, howz the feel of the new hardware??
    I was a bit skeptical about the circuit board replacement and such leaving it not feeling like an OE control, so I thought I'd wait on your 'professional' opinion.... ;)
  3. Sep 17, 2023 at 1:05 PM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    now we need someone to wire the rear window to the steering wheel
    Translucent, welshmike and biebs96 like this.
  4. Sep 17, 2023 at 1:25 PM
    Wallygator
    YMMV. I run tow/haul in S mode 24/7. It goes well enough and I feel it's the way the truck should be stock. It goes better if I press the gas farther. PC will burn more gas just like pressing the gas farther will. IMO it's dumb to pay that much money for something that presses the gas more with less pedal effort. It provides no more power than the engine has stock. Again, YMMV.
    Tundrastruck91 likes this.
  5. Sep 17, 2023 at 1:59 PM
    LJOHNS
    LJOHNS New Member
    Did the front turn signal light recall mod today. Much brighter/safer now!
    bulldog93 likes this.
  6. Sep 17, 2023 at 2:15 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Looks good! I'm thinking about doing the same type of methods. Any chance you could get a picture from the front/back to show tire poke please? That's the one thing I've been having trouble finding pictures of!
  7. Sep 17, 2023 at 2:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Can't tell the difference from OEM to new. Seriously, the only things swapped are the outer button and the PCB - the little rubber contact pad (which provides the "feel" of the buttons when pressed) is all factory. In theory, you could leave the outer button as factory, but the icons would be wrong...
  8. Sep 17, 2023 at 4:51 PM
    Tripleconpanna
    Sold :spending:
  9. Sep 17, 2023 at 5:51 PM
    Installed the motor for my rear window power conversion. Yes, the entire window has to be changed, not just the center slider.
    Jcmf52, wackyhacky, 16MagSR5 and 6 others like this.
  10. Sep 17, 2023 at 6:27 PM
    centex
    centex New Member
    Top table is tow//haul and bottom is normal. Top row is accelerator pedal position and the colored boxes are throttle body degrees. The larger the number in the colored box, the quicker the throttle comes on. This is exactly what all of these pedal commanders are doing. They are manipulating the signal going to the ecm to trick it. Nothing more, nothing less.
  11. Sep 17, 2023 at 8:15 PM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    Busy weekend. relocated the rear diff breather, removed the old spare, installed bed stiffeners, installed the hypertech/rough country speedo adjustment harness, and installed the FRAC harness and front facing camera. Used the yotaleds mounting plate for a clean install.
  12. Sep 17, 2023 at 8:48 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    Is there a walkthrough on how to add this?
  13. Sep 17, 2023 at 8:54 PM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Did my first oil change since I've had the truck. Used the MotivX kit. I folded up some cardboard to funnel the oil from the plug opening into the oil pan and still had a bit of splash. Luckily I put down a huge piece of cardboard on the ground.
    Installed a Jowett canister with EZ Drain valve. Also replaced the oil plug with another EZ Drain valve. Future oil changes will be easy. I love the MotivX funnel!
  14. Sep 17, 2023 at 10:53 PM
    Deathstar1520
    Deathstar1520 New Member
    BRENNAN
    2017 CM SR5 TRD 4X4
    6 inch lift, 35 inch tires and 20 inch wheels, and amp power steps
    getting truck ready for October
    follow my Instagram artic_tundra_ to see strobe light feature using switch pro IMG_20230917_194301_549.jpg IMG_20230917_194304_383.jpg IMG_20230917_194311_798.jpgScreenshot_20230917_225133_Instagram.jpg
  15. Sep 17, 2023 at 11:10 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Shit, this is awesome. Need to make sure my wife doesn’t see this or she’ll be asking me to install ditch lights on her Wrangler so she can have ditch-o-lanterns, lol
  16. Sep 17, 2023 at 11:11 PM
    RobertD
    Robert
    DFW, Texas
  17. Sep 18, 2023 at 3:45 AM
    I'm in the process of creating it. It will roughly cost about $1K for the conversion. :thumbsup:
    bulldog93 and rmorse[QUOTED] like this.
  18. Sep 18, 2023 at 4:39 AM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    That’s not hateful tbh
  19. Sep 18, 2023 at 6:11 AM
    NaturalState4x4
    NaturalState4x4 New Member
    Josh
    2021 Black Crewmax
    3" lift, TRD PRO wheels, 35x11.50 Falken RTs
    I'd say a 1/2"-3/4" or so. But, I have the JBA uppers on my truck. Not sure on the clearance difference between those and factory.
  20. Sep 18, 2023 at 8:52 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Thanks
    That's why I was asking. The 35x11.5 is close in size to a 295/70R18 (that I'm running) and have about 1/2" of clearance. Upgrading the UCA's is on my list, but I've seen a few people that upgraded to different UCAs and didn't have enough clearance for factory offset rims.
  21. Sep 18, 2023 at 9:52 AM
    PKFan
    2018 Inferno! DC SR5 4x4
    I've found that a 5 gal bucket works better than a traditional oil drain pan. No splashing.
  22. Sep 18, 2023 at 11:23 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I'd thought about upgrading UCAs, but didn't for this reason. There are several 'factory offset' measurements, and after a little research I couldn't get a read on whether the BBS wheels were +50 or +60. The TSS wheels I have on mine are +50, and my tires are 285's, so if they'd fit a +60 with 295's, I'm probably good.
  23. Sep 18, 2023 at 11:39 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Such a nice clean look!
    Beckusmc likes this.
  24. Sep 18, 2023 at 1:05 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
    Spent the afternoon taking my rusty sliders off. Going to look into getting them stripped and re-coated. Not gonna lie though, I like how clean it looks without them on. Kids have a little more trouble getting in though :rofl:
  25. Sep 18, 2023 at 1:16 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    You definitely put them thru some winter’s Torrey! Getting them redone be like new!!
    Tripleconpanna likes this.
  26. Sep 18, 2023 at 2:58 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    We hit the 10k mark, and it looks like it's time for an interior cleaning. I didn't realize it was that dusty until I uploaded the pic. :oops:
  27. Sep 18, 2023 at 3:35 PM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    Man, I thought I was low mileage. I’m at 2 years 16k miles!
    Dawoofles likes this.
  28. Sep 18, 2023 at 3:38 PM
    Be very careful. That lens will scratch easily. That's why I put a screen protector on mine.
    Tundrastruck91 and bulldog93 like this.
  29. Sep 18, 2023 at 3:43 PM
    WSDMetal
    WSDMetal Motorsports Fabrication & Design
    Huntington Beach
    Imagine this with a roof light bar...;)
  30. Sep 18, 2023 at 3:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I was thinking this during my run. Going fast at night def needs way more lightning.
    WSDMetal[QUOTED] and coTony like this.
