Coil spring isolators pushing out
Discussion in '1st Gen Tundras (2000-2006)' started by Acatlin96, Sep 8, 2023.
  1. Sep 8, 2023 at 8:59 AM
    Acatlin96
    Acatlin96 [OP] amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    Last weekend I installed OME 2884 springs on Bilstein 5100s. I used new KYB top hats and the Energy Suspension isolators.
    They assembled correctly, but now after driving for a week I noticed the Energy Suspension isolators are getting pushed out of place by the springs. Bulging out like the springs are applying too much upward force and stretching the isolators way too much around the springs. Anyone with the same setup encounter this/have any tips?
  2. Sep 8, 2023 at 10:33 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    5100s are meant for stock height coils and lift is gained by clip setting. Those springs are 2 inch lift I think, so they could be too long.
  3. Sep 8, 2023 at 10:36 AM
    5100s with OME 2884, 2885 and 2887 are all combos others have used here on 1st gens with no similar reported issues...
    Elevatorguy and Acatlin96[OP] like this.
  4. Sep 8, 2023 at 10:41 AM
  5. Sep 8, 2023 at 11:16 AM
    Acatlin96
    Austin
    Central Coast, CA
    Knew this was coming, haha! See here:
    no bueno
  6. Sep 8, 2023 at 11:30 AM
    The only energy suspension isolators I see are for Monroe quick struts. Is there another product they make for other springs?
  7. Sep 8, 2023 at 11:32 AM
    Acatlin96
    Austin
    Central Coast, CA
    Yes, others on here have used the 9.6104 universal isolators in combination with the OME coils for lift. That is what I used unsuccessfully
  8. Sep 8, 2023 at 11:46 AM
    5100’s on the bottom clip?
  9. Sep 8, 2023 at 12:09 PM
    Acatlin96
    Austin
    Central Coast, CA
    Yep, bottom clip
  10. Sep 8, 2023 at 11:46 PM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    Yep. Energy suspension poly isolators smushing out? -- check. Happened to me. Twice. Found it happened to lots of folks all over FB groups too. I switched to the KYB rubber isolators and been perfect ever since. Part # KYB SM5413.
  11. Sep 9, 2023 at 12:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    That's the same part number I used with both my Dobinsons springs. One teal just like that
  12. Sep 9, 2023 at 7:48 AM
    Acatlin96
    Austin
    Central Coast, CA
    Well that sucks! Thank you for the reply and for your pics. Looks like I’ll be going back to rubber.
    This is frustrating because I bought new KYB top hats, and threw out the rubber isolators that came with them… and trash pickup just happened yesterday… what a bummer!
    ColoradoTJ likes this.
  13. Sep 9, 2023 at 10:03 AM
    Go figure.
    Kinda like when you drop pizza. It will always land cheese side down. :mad:
    w666 and Acatlin96[QUOTED][OP] like this.
  14. Sep 17, 2023 at 4:39 PM
    Acatlin96
    Austin
    Central Coast, CA
    IMG_0003.jpg Update: got around to addressing this issue today. Swapped the bad Energy Suspension isolators for KYB rubber isolators and all is well in the world again.
    Let this serve as a warning to others who want to use OME coils on their FGT: the frequently recommended Energy Suspension poly isolators may fail very quickly!
