Is the 5.7L i-Force an LS1?
Discussion in '2.5 Gen Tundras (2014-2021)' started by dt97, Sep 14, 2023.
  1. Sep 14, 2023 at 3:59 PM
    dt97
    dt97 [OP] New Member
    I came across the 3UR-FE about a week or two ago and I'm currently wondering if the 5.7 is just an LS1. Like how the A90 is with BMW, etc. I do notice similarities between the motor such as compression ratio and the bore x stroke size, but I just want to see if my suspicions are right. I have tried researching this question, but I'm always seeing mixed answers. If you can help me out it would be greatly appreciated.
  2. Sep 14, 2023 at 4:11 PM
    xc_tc
    xc_tc New Member
    All you have to do is look at the block to know that the engines are completely different.
    3UR
    LS1
    3UR is an overhead cam engine whereas LS1 is a pushrod engine. This makes the block architecture completely different. You can see the LS1 has a cavity above the bores. This cavity is where the lifters and pushrods go.
  3. Sep 14, 2023 at 4:14 PM
    dt97
    Alright thank you
  4. Sep 14, 2023 at 4:22 PM
    Definitely not a LS1.
  5. Sep 14, 2023 at 5:54 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Fun fact, the 3UR has a longer stroke than a 454
    I still have guys at work trying to convince me the Toyota has a Chevy V8. Not worth the argument anymore
    Wynnded and Leek128 like this.
  6. Sep 14, 2023 at 6:13 PM
    thorconstr
    thorconstr New Member
    Thorsten
    2008 Tundra
    Doesn’t even come close to looking like an LS1. Being an OH cam engine I think they could rework the computer and fuel system and get some serious HP out of this engine and still have decent fuel economy with performance.
  7. Sep 14, 2023 at 6:22 PM
    dt97
    Thank you very much
  8. Sep 14, 2023 at 6:23 PM
    dt97
    This was the main thing that I was confused about. Because I saw people saying it was the block, or how chevy designed it and handed it off which didn't make any sense, but I greatly appreciate you guys
  9. Sep 14, 2023 at 6:24 PM
    dt97
    Yea I probably should've looked at the block and the cam setup first, but thanks anyway
  10. Sep 14, 2023 at 8:04 PM
    Heavy_Guns
    Heavy_Guns New Member
    If it was related to a GM motor it would be the 1990-1995 LT5 ZR1 engine. Both are DOHC engines and produce similar HP.
    But its not.
    tsinajinii likes this.
  11. Sep 14, 2023 at 8:15 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm pretty sure it might possibly be...one!!! :cool:
    HulkSmurf14 likes this.
  12. Sep 14, 2023 at 8:46 PM
    tsinajinii
    tsinajinii Black Streak Wood People | Free Folk have no King
    Jamin
    AZ
    Tundra - Crewmax TRD Sport; Tacoma - DCLB TRD Sport
    Based some evidence I've seen, I was thinking the same thing.
    Here is some of that hearsay evidence:
    And here is a fun video that talks about the history of the LT5 in the ZR1 C4 Corvette:
    https://youtu.be/6Vs2tdR-9C8?feature=shared
  13. Sep 14, 2023 at 9:18 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Yeah… but that’s not a GM engine. That’s a Lotus designed, Mercury Marine built mill.
  14. Sep 15, 2023 at 2:10 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Yamaha,,,,,,,, Japan
    LS1,,,,,American
    Is not a match
  15. Sep 15, 2023 at 2:34 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    The ls1 is basically a cathedral port SBF.
  16. Sep 15, 2023 at 9:37 AM
    tsinajinii
    Jamin
    AZ
    According to the video I posted earlier, General Motors LS engines were actually designed as a response to the Lotus built 350 LT5 Corvette engine.
    Here is where it is mentioned in the video:
    https://youtu.be/6Vs2tdR-9C8?feature=shared&t=908
    ColoradoTJ and Black@Blue19 like this.
  17. Sep 15, 2023 at 10:54 AM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    That was amusing end to that video. I enjoyed it thoroughly thank you.
    LS3 and tsinajinii like this.
  18. Sep 15, 2023 at 8:40 PM
    Heavy_Guns
    Split hairs much?
  19. Sep 15, 2023 at 8:43 PM
    Heavy_Guns
    I've never seen that facebook screenshot before, seems outlandish.
    The video however is favorite of mine when people ask "how come it took so long for this to happen" because you weren't ready for it the first time.
    Retired...finally likes this.
  20. Sep 17, 2023 at 3:50 PM
    72GTS
    72GTS New Member
    Ontario, Canada
    2021 MGM Tundra DC TRD Sport Premium
    It seems that people still get confused when different engines have the same displacement. The 3UR is obviously not remotely related to a Chevrolet LS1, which is completely different in design. FWIW, at one time GM produced 4 different 5.7 Liter or 350 engines, a Chevrolet , Pontiac, Oldsmobile and Buick V8. Other than displacement, they shared almost nothing else in common.
    https://youtu.be/ixbQuTyV7iQ?si=-CpRZ4QGNaN_DA74
    That above quote is complete garbage information. Again there is no relation between Toyotas 3UR 5.7 L and the Chevrolet LT5, other than both are 5.7L DOHC V8s.
    The LT5 didn't fail because Americans didn't like the high revving engine. It failed because you had to buy the highly expensive Corvette ZR1 to get it. Then Chevrolet increased the power and performance of the base engine with the Gen II LT1 engine, making the ZR1 seem very expensive for not much more performance. It was also costly to manufacture. The LS V8s essentially replaced both the old SBC and the LT5. The Gen III LS engines were smaller, lighter and cheaper and eventually produced more power and performance.
    Here is an accurate history on the LT5. It also explains the relationship with Lotus, which GM had an interest in at that time.
    https://www.curbsideclassic.com/aut...dohc-v8-a-british-heart-for-an-american-icon/
    Tripleconpanna and ZappBrannigan like this.
  21. Sep 17, 2023 at 3:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Here is a question from an idiot. (Me)
    why are there so many engine designs for the same application? Wouldn’t it make sense that as things are discovered as far as making power efficiently and reliability, wouldnt all designs naturally end up in almost the same place?
    For example, all half ton trucks have similar room under the hood, so why at a time would the NA V8 desings from brand to brand differ so radically?
  22. Sep 17, 2023 at 4:53 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Competition, need a compelling product to entice a sale
    Fabrication expertise, established manufacturing techniques in a company are more consistent and less expensive
    Patents and trade secrets
    And the fact it's not an easy task to make an engine and bring it to market
  23. Sep 17, 2023 at 6:28 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    LOL, no. Not even remotely close.
    Tripleconpanna likes this.
  24. Sep 19, 2023 at 8:43 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    This is the biggest horsesh1t I've heard, typical patent in US lasts 20yrs, no one in their right mind is going to buy a 19yr old patent, and most likely expired already since if a product is introduced in 1989 it usually means a patent application was filed 2-3 years prior.
    costs, supply chain, leadership.
    1UZ, aka LS400 was the basis for all Toyota V8, so it makes sense to take that knowledge, expertise, experience to derive from that.
    GM V8 derived from their pushrod design because they have "perfected" in a sense, its small, compact, and they've been doing it for 50 years.
    Ford likes to try new things, so you get pushrod, SOHC, DOHC, twinturbo, etc, some were good, some aren't.
  25. Sep 19, 2023 at 11:22 AM
    tsinajinii
    Jamin
    AZ
    Just to clarify:
    • I was agreeing with @Heavy_Guns that if it were related to a Chevy engine, it would be the LT5... BUT IT'S NOT
    • The Screenshot is from Quora, not Facebook
    • I did purposely label it as "hearsay evidence" in order to bring its credibility into question.
    . -I don't believe hardly anything on the internet, but I thought this was some interesting BS related to the topic.
    • The curbsideclassic.com article was good, and covered a lot of the same information as the video did... I didn't see the two being in hardly any conflict
    72GTS[QUOTED] and ZappBrannigan like this.
  26. Sep 19, 2023 at 3:50 PM
    Downytide
    GTA
    Oh, not pointing finger at you, just the guy who made the claim.
    Reminds me of a story of how someone's grandfather used to post on earlier car forums, the old man would post false statements and watch people argue, until the grandson pointed out to him: "grampa, that's a troll, you are a troll"
