2013 Tundra no battery light. charging system faulty
Discussion in '2nd Gen Tundras (2007-2013)' started by sacred4s, Feb 24, 2023.
  1. Mar 19, 2023 at 8:27 PM
    #61
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Did you clear the code, drive the truck and see if it comes back?
    It’s a code for rough idle.
    Could have been a “glitch” from running the truck on low voltage with no charging.
    If it comes back cleaning the throttle body would be a good start
  2. Mar 20, 2023 at 9:37 AM
    #62
    sacred4s
    sacred4s [OP] New Member
    Sacred
    2013 tundra 4.6L 2x crew cab brown
    No battery light on when ignition is turned on. Good alternator, good battery , fuse under dash LH-IG good , still not charging . C1241 reads low and high voltage also pointing at skid control faulty. Dash battery symbol is at yellow when key is turn-on position before start up engine.
    All right Jeff. You a good help walking me thru tundra diagnos process … I learned a lot . The abs and skid light never came back on. I just deleted the P1605 code. We shall see what it spits out later. Thanks again. We use the truck last night to gathering . Came back good no trouble. Now I just delete the one code. We shall see what it tell us later, if it comes back. I bet not. I’m underdog fixer now. Graduate from tundra university .
    Jeff_5_7[QUOTED] likes this.
  3. Sep 17, 2023 at 9:08 AM
    #63
    DirtRider525
    DirtRider525 New Member
    Adrian
    17 tundra trd pro
    I've been getting similar issues to the OP. I've tested the 4 pin connecter ignition off, on, and with engine running. My black wire (pin 4) has 0v the entire time. I cannot figure out where this traces back to. I tried to look on that link with the diagrams and apparently I'm not using it correctly because I cannot find any diagrams for the charging system. I have a 2017 5.7 tundra
  4. Sep 17, 2023 at 10:58 AM
    #64
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Pin4 black is the control for the battery light on the instrument cluster. If yours is 0v that would be your light is on, on the dash.
    Is the truck charging when running? What is the voltage across the battery terminals as it’s running.
  5. Sep 21, 2023 at 8:37 PM
    #65
    DirtRider525
    Adrian
    17 tundra trd pro
    Break in the black/yellow wire was my issue. thank you very much for all the useful info in this thread Jeff_5_7 you helped me solve my issue.
    Jeff_5_7 likes this.
  6. Sep 21, 2023 at 8:44 PM
    #66
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    All good and charging now? First time I have seen the Black/Yellow wire fail like that.
  7. Oct 9, 2023 at 4:12 PM
    #67
    jerryh311
    jerryh311 New Member
    Can I piggyback onto this thread too. Similar issue. Just put in a new alternator. No output. B/Y and G/Y both show 12+ with key on. R and B show 0V. Is the Red wire an output to the ECM? I'm thinking I just got a bad alternator but want to make sure before doing that PITA job again.
