Rear axle rusted out metal lip around brakes thingy...
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Sep 16, 2023.
  1. Sep 16, 2023 at 2:58 PM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Hey there, in the process of needle scaling everything metal ( ish) and got to the rear drums, just for the needle scaler to go right through a few areas of that lip around the rear of the drum ( not through the actual inside drum brake area, just the lip.
    Correct me if I'm wrong, but it seems replacing this involves replacing the whole axle lol? It doesn't seem to me like it's an actual seal for the brakes or anything, just seems like it goes around the drums? Thoughts?
  2. Sep 16, 2023 at 3:13 PM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4, 2012 Mini cooper clubman S
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels Gofast topper
    It's a backing plate, drum hardware and shoes mount to it.
  3. Sep 16, 2023 at 3:19 PM
    Aaol1
    Sam
    Couple holes on the edges only, no big deal?
  4. Sep 16, 2023 at 3:26 PM
    mthoodbill
    Mt Hood, Oregon
    Looks like it's about $120 for each side. Tread with caution on those rear drums. With mine I ended up replacing a bunch of stuff when I did the bearings. It was all worn out.
  5. Sep 16, 2023 at 3:56 PM
    Aaol1
    Sam
    Link for that 120 a side?
  6. Sep 16, 2023 at 4:04 PM
    mthoodbill
    Mt Hood, Oregon
  7. Sep 16, 2023 at 4:10 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  8. Sep 16, 2023 at 5:45 PM
    Aaol1
    Sam
    perfect, atleast its not a welded part to the axle like i originally thought! might throw this in when I do a rear brake change
  9. Sep 16, 2023 at 6:02 PM
    Change them out whenever you plan to do the rear wheel bearings. You’ll need a 20 ton stand up hydraulic press for that though and a specialized adapter to hold them to get it off or you’ll have to make your own.
    tpope, NickB_01TRD and des2mtn like this.
