  1. Sep 16, 2023 at 7:06 AM
    A PC and tow haul are two separate things. They operate differently.
    willy and bulldog93 like this.
  2. Sep 16, 2023 at 7:06 AM
    singletrack_dad
    singletrack_dad New Member
    Ty
    2014 TRD OR CM
    Looks so good. Fwiw I was able to move my whole front inner fender forward a great bit and just re fasten it from the bottom. Leaving the liner intact
  3. Sep 16, 2023 at 7:54 AM
    NoRcptn
    NorCal
    2017 Platinum
    Agreed. One is shift points and one is throttle response from the way I understand it. I don’t have one, but my buddy has the PC were playing around with it and it was pretty lively off the line. Seemed to be a difference using both (maybe not-could just benperception ). Anyway the lag was gone and acceleration seemed to be pretty damn quick. I’d say close to any 3.5 ecoboost for a short duration with a high rpm holding those points longer.
  4. Sep 16, 2023 at 8:31 AM
    Wallygator
    Same thing happens when you press the gas farther initially. That's what the PC does.
  5. Sep 16, 2023 at 9:16 AM
    Florida AF
    Logan
    North Florida
    first you go and send me down a rabbit hole on buying cheaper lights and trying my first retro fit... then you send me down another google session on what are chase lights, followed by what tail lights are different than yours but I could try the same with.... And now you go and post a video and some pics.... back to google again.....
    Side note, my stock tail light is taking on moisture... I think that means new tails right?
  6. Sep 16, 2023 at 9:17 AM
    RobertD
    Robert
    DFW, Texas
    Geno is also incredible at answering pm's with info. I've definitely asked him lots of questions about his mods.
  7. Sep 16, 2023 at 9:18 AM
    Florida AF
    Logan
    North Florida
    Good to know and thank you. I have been holding off on one of those switch ports (not using a brand name on purpose) but feel this would help justify and be useful on the game roads and what not.
  8. Sep 16, 2023 at 9:51 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Thanks for the compliments!!
    For your stock taillight, I would check the rubber grommets where the bulbs are seated. One may be cracked or missing.
  9. Sep 16, 2023 at 9:53 AM
    Florida AF
    Logan
    North Florida
    I like that a lot! You did it clean!
    I will check them when I go to reinstall my dash cam. Thank you for the advise!
    I want the switch port for ease of use, but I also know I am not going to install everything at the same time, plus you found a great way to use that useless spot. I finally started putting my park access cards there just to do something with it.
  10. Sep 16, 2023 at 9:55 AM
    BlueRibbon4x4
    Geno
    Thanks! Right now I’m not using all the switches (buttons). They’re wired to the engine bay, ready for relays and whatever is next.
    RobertD and Florida AF[QUOTED] like this.
  11. Sep 16, 2023 at 10:01 AM
    Florida AF
    Logan
    North Florida
    Another idea I may have to pursue instead. And prewiring them is way better than running each time. During our gap in time here I was looking at making my own distro block setup LOL.
    This forum is the worst sometimes.
    BlueRibbon4x4 and RobertD like this.
  12. Sep 16, 2023 at 10:17 AM
    BlueRibbon4x4
    Geno
    Agreed! But the more ideas, the better. Makes the job much easier with all the options on the table.
    Florida AF[QUOTED] and RobertD like this.
  13. Sep 16, 2023 at 10:19 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
  14. Sep 16, 2023 at 11:22 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    IMG_20230916_121317864_BURST000_COVER_TOP.jpgGot new tires yesterday, rubbed a little on the front so spent a few hours with a heat gun and plastic welder and no more rubbing
  15. Sep 16, 2023 at 11:45 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Looks really good. What did you use for wire? Thinking that since those are no load switches that you could probably get away with cat6 which is 4 pair of 24ga. I think cat5 is 28ga.
  16. Sep 16, 2023 at 12:47 PM
    J&ATundra
    J&ATundra |-|/-\\/\//-\| |
    Texas but from Hawaii
    2018 Cement Toyota Tundra
    20230916_142343.jpg 20230916_142332.jpg Added 1.25 wheel spacers and yellow film for the fogs.
  17. Sep 16, 2023 at 1:43 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I decided to pick a fight with my liberal water nazi neighbors today and actually wash with water :boink:
    WFD473, Skaufma0, hi_rawb and 17 others like this.
  18. Sep 16, 2023 at 2:18 PM
    BlueRibbon4x4
    Geno
    Well, that would have been a good idea :rofl:
    I used individual 22ga., but consolidated the ground and power, of course.
  19. Sep 16, 2023 at 2:44 PM
    AZTundra
    Paul
    Phoenix, AZ
    Installed the Alpine ILX-F511 this afternoon. Also opted for the integrated front and rear dash cams that can be controlled through the head unit. Don't mind the sticker residue on the screen...I haven't peeled off the factory screen protector film yet.
  20. Sep 16, 2023 at 4:08 PM
    CaptRussia253
    Ruslan
    @STravis SOB Fabrication
    TOYOTARIG, STravis and Florida AF like this.
  21. Sep 16, 2023 at 7:36 PM
    Tan-dra
    Tan-dra MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    I (actually my girlfriend) installed this leather steering wheel cover over my plastic wheel. It only took her 5 hours :D
    upload_2023-9-16_21-34-2.jpgupload_2023-9-16_21-34-38.jpgupload_2023-9-16_21-35-17.jpg
  22. Sep 16, 2023 at 7:56 PM
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Did you marry her yet? That 5 hours is more than my wife (almost 20 yrs) has ever spent helping on my truck :(
  23. Sep 16, 2023 at 7:59 PM
    SwitchThrottle
    Tanning booth?
  24. Sep 16, 2023 at 10:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Night runs on the beach at speed are wild.
  25. Sep 16, 2023 at 11:43 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    She's a keeper!
  26. Sep 17, 2023 at 7:54 AM
    ETXGuy1836
    ETXGuy1836 New Member
    2021 Gray Tundra SR5
    no, I’ve done the tow/haul just to see what it will do. I haven’t gotten the PC delivered yet. Install should be in a couple of days. Should have clarified!
  27. Sep 17, 2023 at 8:12 AM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Nice....wrap color matches the truck very good. Shade of color matches well. Awesome job.
    Beckusmc and NewImprovedRon like this.
  28. Sep 17, 2023 at 9:32 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    How’s the clearance from the tire to the UCA with the factory BBS rims and those tires? I’m thinking about upgraded UCA’s but there’s not much room to spare with the factory BBS offset.
  29. Sep 17, 2023 at 9:33 AM
    DowntownApexTundra
    DowntownApexTundra New Member
    2021 DC SR5 4x4 Sport
    3/2 leveling lift kit, pocket style fender flares (best super white color match you'll ever see - painted by my uncle), 1.5" wheel spacers, S&B CAI, TRD Pro headlights, 18" knockoff Ebay TRD Pro Wheels, wildpeak at3w 275/65R18 116t (32/11), gator roll-up tonneau, blacked out interior by AJT and others, pedal commander, blacked out exterior badges, LED everything, RCI neoprene water proof seat covers (removed back middle seat back material to make it work), weather tech floormats, flowmaster flowfx extreme 3.0 exhaust
    Not on my 2021. There is no way I can get that sort of throttle response by mashing the gas. Same for my buddies 2015.
  30. Sep 17, 2023 at 10:36 AM
    centex
    centex New Member
    That’s exactly what it is doing. It’s just opening the throttle sooner. All it’s doing is say at 25% throttle input, it’s opening the throttle body 35%.
    Tundrastruck91 likes this.
