Low Profile Rock Sliders
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tan-dra, Sep 16, 2023.
  1. Sep 16, 2023 at 7:43 AM
    Tan-dra
    Tan-dra [OP] MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    Does anyone know if there are any low profile sliders available for 07-21? I don’t like the look of the big step ones with the kick-out, I’d prefer to have something that tucks closer to the body. Pic below of the style I am looking for. These are the N-fab rock rails so they aren’t a true slider. Most of the frame mounted sliders I see are the really wide ones that stick out a ton.
  2. Sep 16, 2023 at 8:20 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Rocky road outfitters? I had some on an older 4Runner that tucked up tight. Mounted to frame, BUT, also mounted to pinch weld( didn’t like that part).
    Tan-dra[OP] and BravoDeltaRomeo like this.
  3. Sep 16, 2023 at 9:05 AM
    Tan-dra
    2020 Quicksand SR5
    Yes I looked at those as well. They look really good but I read mixed things about their quality control and the fact that they’re mounted to pinch welds. I saw that on the Tacoma forums but since these trucks are significantly heavier I can’t imagine they will hold up better
  4. Sep 16, 2023 at 9:06 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Research them for tundras first. I've heard some horror stories. The mounting option was a huge red flag for me.
    Our Rockrails are engineered to mount on the sub-frame as well as along the body seam.
    We opted for RCI as we wanted lockout and top plate (dog friendly).
    There should be some low profile options available, if you are willing to spend, have them shipped and are in USA. Being in Canada, we were limited and still paid a fortune to have them shipped. No regrets in the end.
    Tan-dra[OP] likes this.
  5. Sep 16, 2023 at 9:11 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Demello FTW
    You can see from the photo they don’t stick out very far but do provide a nice step.
  6. Sep 16, 2023 at 9:22 AM
    Tan-dra
    2020 Quicksand SR5
    I looked at RCI and I know their quality is top tier. Maybe they used to have more options but it doesn’t look like they have a non kick-out option at the moment for the 2nd gen
  7. Sep 16, 2023 at 9:24 AM
    Tan-dra
    2020 Quicksand SR5
    This looks good! Do they get in the way or make it awkward when getting in and out of the truck? I know on some trucks it makes it awkward to get in/out because it’s not enough to step on top of but your leg still rubs on it
  8. Sep 16, 2023 at 9:28 AM
    Shanet421
    San Diego,CA
    In and out is far superior to not having a step at all. For the first 8 years of ownership didn’t have a step but wouldn’t hesitate to buy these again in a heartbeat. However standing on the ground reaching into the truck to grab something your leg does rub the slider. Also sticks out enough to prevent door dings and shopping cart bumps as well.
  9. Sep 16, 2023 at 9:29 AM
    Shanet421
    San Diego,CA
  10. Sep 16, 2023 at 9:33 AM
    Tan-dra
    2020 Quicksand SR5
    Do the Demello ones require drilling into the frame? I was looking at Victory4x4 ones but am hesitant because they require drilling into the frame and I am in the rust belt
  11. Sep 16, 2023 at 10:00 AM
    Shanet421
    San Diego,CA
    https://www.demello-offroad.com/download/sample/180
    4 bolts into the frame on each side. 4 bolts drilled up from the bottom for superior strength but not mandatory.
    I ultimately went with Demello because I was close enough to go pickup from their shop. Top notch folks and facility!
  12. Sep 23, 2023 at 9:49 AM
    gordi
    gordi New Member
    Josh
    2020 white limited double cab
    Does anyone make an aluminum slider?
    Had some on my Tacoma that were great for the PNW winters.
  13. Oct 7, 2023 at 11:52 AM
    White TRD 4x4
    White TRD 4x4 New Member
    Does anyone have pics of the N-Fab sliders posted above on their vehicle they can post?
    I am specifically looking for a shot that shows the gap between the body and slider rather than the up-close high angle shots on the websites.
    I am not looking for a frame mounted slider. I want something that bolts to the existing mounts in the body of my 2017 Double Cab that tucks up high enough to hide my bent up pinch weld.
    I will not be doing any hard wheeling in this truck, just camping trips towing an off-road camper where some slight bumps may occur.
    Thanks.
    Ceezurin likes this.
  14. Oct 7, 2023 at 1:39 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    Hopefully this gives you an idea of the gap bet body and “slider.”
    bulldog93 likes this.
  15. Oct 7, 2023 at 3:24 PM
    White TRD 4x4
    It does. Thank you.
  16. Oct 7, 2023 at 4:59 PM
    Ceezurin
    Ceezurin New Member
    Franco
    El Paso, Texas
    2019 Cavalry Blue Limited Crewmax
    Bilstien 5100 all 4 corners, Toytec shackles, mbrp full exhaust single exit, husky liners, diode dynamics interior and exterior lighting
  17. Oct 7, 2023 at 5:10 PM
    White TRD 4x4
    Thank you.
    Does anyone have a picture of these on a double cab? I'll probably order these from the local 4wheel parts store this week as the websites seem more confusing on double cab vs crew max models. At least if they don't fit correctly it will be easier to bring them back.
  18. Feb 2, 2024 at 10:41 AM
    Teamrivers
    Teamrivers New Member
    Brent
    2021 OR 4WD
    List is coming, leaving a heavily modded OR Taco
    Really digging your rear bumper.. Can't find it in any image searches, is it only for 3rd gen? I have a 2021..
  19. Feb 2, 2024 at 10:46 AM
    Tan-dra
    2020 Quicksand SR5
    Teamrivers[QUOTED] likes this.
  20. Feb 6, 2024 at 9:04 AM
    romanlegion
    Roman
    Katy, TX
    My rear bumper is a prototype from Lil B's. I don't know if he makes it for the 2021. Sorry.
  21. Feb 8, 2024 at 8:18 PM
    MTBTANDRA801
    MTBTANDRA801 New Member
    Ben
    2018 Limited DC
    King suspension, TRD Exhaust
    So I thought quicksand was the best color out there, but god damn seeing your blue with the chrome delete and the gold wheels is realllllly making me second-guess my self
    That's a mighty fine, good looking truck sir
    Ceezurin[QUOTED] and Tan-dra[OP] like this.
  22. Feb 9, 2024 at 5:55 AM
    Tan-dra
    2020 Quicksand SR5
    Top 3 colors on the 2.5 gen imo are Lunar Rock, Quicksand, and Cavalry Blue
    MTBTANDRA801[QUOTED] likes this.
  23. Feb 9, 2024 at 6:42 AM
    rvrats2
    rvrats2 Too Often Yankees Overprice This Auto
    Carbondalé, CO
    2011 SR5. Bench Seat!
