  1. Sep 12, 2023 at 8:55 PM
    #4351
    Dugnor
    Dugnor New Member
    2022 Tundra 1794 WCP
    4mm[QUOTED] likes this.
  2. Sep 13, 2023 at 3:12 AM
    #4352
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    I have the Tufskinz liners but it's difficult to clean up any accidental spills if you used the adhesive to secure them in place. If you don't use the adhesive, then they fall out whenever you lift the lid.
  3. Sep 13, 2023 at 6:02 PM
    #4353
    Midge
    Midge New Member
    Cindy
    2023 Toyota Tundra 1794 Edition
    Hello, my nickname is Midge. I just purchased my 2023 Toyota Tundra 1794 Edition. Loving it. I joined to get some ideas. I am going to get emblem inserts for front/tailgate and mud flaps. I would like a tonneau cover. Can you get one that doesn't interfere with all of the cameras. I am loving (Blue), My tundra's name. Sounds great, drives great, very smooth ride, and has plenty of power. Thank you.
  4. Sep 13, 2023 at 6:10 PM
    #4354
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Welcome to the club .
  5. Sep 13, 2023 at 6:16 PM
    #4355
    Midge
    Midge New Member
    Cindy
    Thank you
  6. Sep 13, 2023 at 6:19 PM
    #4356
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    I used the MX4 cover and I liked it, but I had issues with fit and metal shards on both of them (the first and the replacement). When folded up against the bed, the rear view camera is not blocked, but the camera to see in the bed is blocked. I switched to the revolver hard roll up and so far I love it. Looks like a hard cover one piece, fits great, and rolls up out of the way with no issues of blocking cameras.
    mayan and Midge[QUOTED] like this.
  7. Sep 13, 2023 at 6:25 PM
    #4357
    Unitdosed
    None, yet
    Welcome. You've come to the right place to look for ideas. There are also plenty of posts on tonneau covers to search through. If you don't want to interfere with the cameras it sounds like a rolling cover will be the way to go.
    Midge[QUOTED] and ziznack like this.
  8. Sep 13, 2023 at 6:27 PM
    #4358
    Midge
    Midge New Member
    Cindy
    I will keep that in mind when I buy one. Really helpful. Thank you
    ziznack[QUOTED] likes this.
  9. Sep 13, 2023 at 8:12 PM
    #4359
    kololas
    kololas New Member
    2023 Tundra Limited
    Just use the small Velcro squares to secure the liners in place. You can get them at any big box.
    Unitdosed[QUOTED] likes this.
  10. Sep 14, 2023 at 5:06 PM
    #4360
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Got my console cover plate today!
    Bye bye sun glare!
  11. Sep 14, 2023 at 6:02 PM
    #4361
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    Started the install of the sPod BantomX 8 Button switch that goes in the in overhead panel in place of the sunglasses holder. got as far as running the wire with a cat5 connector on it through the firewall grommet and now I'm waiting to convince myself of the best way to get a square peg through a smaller round rubber hole.
  12. Sep 14, 2023 at 6:22 PM
    #4362
    99ways2die
    99ways2die New Member
    You already know the answer - cut and re-terminate that (lousy looking) Cat5 cable in the engine bay.
    Better yet (after looking at it closer), replace it with a shielded plenum rated Cat5/6 all together, for both ease of installation and 'better/safer' performance.
    Who strips a Cat5 cable only to put that stupid flex/mesh sleeve on it...and expect the end user to run this with ease through firewalls, rubber grommets, etc?
    Side note:
    $900+ for a switch panel? Damn......
    nodak67 and in_the_mud like this.
  13. Sep 14, 2023 at 6:37 PM
    #4363
    Unitdosed
    None, yet
    I was thinking the same. Had to rerun my search a couple of times to make sure I wasn'tissing something.
    @KiloOps - looking forward to seeing pics of your project when it's complete. Heck, I'd like to see how it looks now!
  14. Sep 14, 2023 at 7:52 PM
    #4364
    KiloOps
    KiloOps New Member
    Dustin
    Yes, I was starting to settle on cutting and reterminating the cat5 in the engine bay, only issue is now confirming the pin configuration, I'm guessing it's a straight through but I've seen weirder things.
    As for the $1,000 switch, it's going to be running about $4,000 in lights at this stage so what's another G?
    I'm still waiting on the CBI front bumper before all the lighting can be installed but I wanted to get the switch system in place and the A-piller lights running while I wait for the bumper to show sometime in mid-october.
    Going to be running all Baja Designs lights with a 30" OnX6 Straight Dual Control LED Light Bar in the center of the bumper, XL80 Dual Driving/Spot in fog light position 1 and Amber S2 SAE fog lights in the outer position. On the SDHQ A-pillar mounts will be another set of XL80's with Spot only lenses. Those lights alone require 4 switches because the OnX6 light bar has one switch for Amber and one for Clear.
    Once I get my Leitner rack installed there will be 4 additional Baja Designs S1's for side and rear work lighting. Will also be installing a roof rack as some point with another light bar.
    Pics below of the switch panel installed overhead and the lights it will be running to start...
  15. Sep 14, 2023 at 8:14 PM
    #4365
    Unitdosed
    None, yet
    This sounds like a fun project.
    Reterminating is easy enough and will be straightforward if your able to manage the wiring for the setup you described. Should be a breeze. You doing the Leitner with the Retrax?
    @99ways2die - I hear you on that crazy cheap looking cat5 cable. I wonder if they supplied that for heat reasons? Sure there are cleaner looking cat5 cables out there, but most applications don't include exposure to extreme heat like what you'd find under the hood.
  16. Sep 14, 2023 at 8:25 PM
    #4366
    KiloOps
    KiloOps New Member
    Dustin
    I haven't totally settled on it but I think I will end up with a Decked system for the bed in conjunction with the Leitner. I'm go back and forth about it because I want to keep room in the bed for my generator when camping and I have a 37" spare mounted to the rail on the back of the cab so that will have to go if I add a cover or Decked system. Looking for an alternative way to mount that spare, possibly on top of the Leitner rack or I guess eventually on a roof rack. I'm waiting for someone to design a rear bumper with a removable swing arm for a spare that I like the looks of, that would be ideal for managing it.
    TucsonTundra1794 likes this.
  17. Sep 14, 2023 at 9:24 PM
    #4367
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Cut it off and reterminate the wires.
  18. Sep 15, 2023 at 12:43 AM
    #4368
    Slimwood Shady
    Slimwood Shady New Member
    Linwood
    San Antonio, TX
    ‘23 TRD Pro, 996 Turbo
    i would use a toner or something to pin out the cat5 before assuming it is a normal through cable. There is a good chance it is just 1-1, 2-2, 3-3, exc…
  19. Sep 15, 2023 at 12:41 PM
    #4369
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    I just keep looking at my phone, waiting on the body shop to let me know I can come pick it up. Tree limbs are the worst.
  20. Sep 15, 2023 at 2:42 PM
    #4370
    KiloOps
    KiloOps New Member
    Dustin
    Got the wire through the extra hole in the firewall gasket and finished the wiring of the sPod BantomX controller. Took a whole 30 seconds after I cut the end off the Cat5 and used a little lube (not sure lube was needed). Nice and clean install.
    IMG_1284.jpg IMG_1288.jpg IMG_1290.jpg IMG_1292.jpg IMG_1294.jpg IMG_1296.jpg IMG_1297.jpg IMG_1298.jpg IMG_1299.jpg
  21. Sep 15, 2023 at 4:25 PM
    #4371
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    Yep, using an RJ45 rated at IP69 is the best solution! No way is that the proper connector for the application. I'd really question the engineering behind that switch pod controller.
  22. Sep 16, 2023 at 6:07 PM
    #4372
    KiloOps
    KiloOps New Member
    Dustin
    Got the Baja Designs XL80 A-Pillar lights installed today on SDHQ mounts. The lights are bright as hell during the day so looking forward to testing them out at night. Setup with Spot lenses so they should project down the road a good distance. Now I know what I'm going to use to flash people when they drive at me with their brights on. :nuclear:
  23. Sep 16, 2023 at 8:14 PM
    #4373
    Unitdosed
    None, yet
    Are you going to be selling these as well?
  24. Sep 17, 2023 at 7:29 AM
    #4374
    jchaps
    jchaps New Member
    Jon
    Indiana
    2022 White Tundra SR5 TRD OR
    If you can't find someone local to print it, send me a message and we'll figure something out. I need to find a cheap shipping and packaging option that doesn't cost more than the part...
  25. Sep 17, 2023 at 7:44 AM
    #4375
    jchaps
    jchaps New Member
    Jon
    Indiana
    Installed the Rave pro grille, still need to figure out the wiring portion. I replaced a TRD grille with red lettering if anyone is interested.
    Quite a bit of fitting was required to center the camera and fit the radar sensor. I'm glad I already had the oem camera bracket, because theirs had a steeper angle that would require a lot more fitting.
    I only broke 2 parts in disassembly, fender flare tab didn't matter much, but I tore off the mounting points for left side of the bumper and had to epoxy it back together.
    I ordered black amber marker lights but got amber on the grille. I didn't really care. After it was installed, I went thru all the wiring bits and found an extra set of black lights in a box. I'm kind of glad because I like the amber.
  26. Sep 17, 2023 at 8:17 AM
    #4376
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    The light bar looks like it belongs there. Even if it’s isn’t wired up, It fills the hole in the grille. It that light bar very heavy? Does the Rave kit come with some brackets for the light bar that connect to the internal structure behind the grille?
  27. Sep 17, 2023 at 8:33 AM
    #4377
    jchaps
    jchaps New Member
    Jon
    Indiana
    It's solid, guessing about 4 lbs. It has 5 screws to mount into the grille, across 20", so the weight is spread out well. No other brackets.
  28. Sep 17, 2023 at 10:11 AM
    #4378
    itundra22
    itundra22 New Member
    2024 MGM Limited Hybrid 4x4
    Looks great!
    I just installed the same TRD Pro grill yesterday however I got a check engine light and a message about the shutters. Did you run into any issues as far as lights coming on?
  29. Sep 17, 2023 at 10:42 AM
    #4379
    jchaps
    jchaps New Member
    Jon
    Indiana
    No issues with check engine lights. I'd double check every plug was replaced. Did you plug in the air damper? (shutters?) The cable is on top, plug under the passenger side bracket, should be easy to check. Plus the two plugs on each side at the top. The radar and camera plugs would be harder to see. I removed the two body color panels as well, which had 2 more sensors.
    itundra22[QUOTED] likes this.
  30. Sep 17, 2023 at 10:52 AM
    #4380
    itundra22
    Getting ready to take it apart and check the connections - thanks! What part of Indiana are you in btw??
