iForce Max Tow mode technical questions
Discussion in '3rd Gen Tundras (2022+)' started by ElectricMan, Sep 6, 2023.
  1. Sep 6, 2023 at 6:50 PM
    ElectricMan
    ElectricMan [OP] New Member
    Brand new Tundra iForce Max owner!! Traded in my Ford F-250 and much happier for it. Here is my question. When I am in Tow or Tow+ mode when pulling my 10,000 GVWR work trailer, I noticed my engine never stops, even when going down hill and foot off the gas pedal AND regardless of the speed I am doing. Does anyone know if that is how the system is set to operate? I haven't found anything online regarding that. Thanks
  2. Sep 6, 2023 at 6:52 PM
    Retired...finally
    It should be well explained in your owners manual.
    Sixty9Four20 likes this.
  3. Sep 6, 2023 at 11:51 PM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    I don’t believe the gas engine is meant to turn off while in Tow/Tow+. My thoughts are that the engine needs to be running to use the engine braking and keep the speeds of the vehicle under load managed, even when going downhill. I do know the battery is still able to charge and regenerate energy from motion when the engine is running, in addition to charging from the engine itself.
  4. Sep 7, 2023 at 7:05 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    Yes, as a fellow hybrid owner I can confirm that is how the system is set to operate.
  5. Sep 7, 2023 at 7:11 PM
    WhiteTundra0013
    WhiteTundra0013 New Member
    2013 white tundra
    Trd rear sway bar, Rims, Goodyear wrangler tires,Topper, Nerf bars
    Thats alot of weight for a 1/2 truck, is your truck rated to pull that much?
  6. Sep 7, 2023 at 7:32 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    It's rated to tow 11450lbs
    ElectricMan[OP] likes this.
  7. Sep 7, 2023 at 7:38 PM
    WhiteTundra0013
    2013 white tundra
    Wow, thats alot of weight, I had no idea the 3rd gen could to that much
  8. Sep 14, 2023 at 10:07 AM
    ElectricMan
    It pulls the trailer great. I find this truck pulls the trailer with ease and has as much squat (1 1/2") as my F-250 had. With that said, I have decided to get a WDH, seeing as the owners manual recommends the use.
    @Retired...finally: I did find it in the owners manual but it is essentially a one sentence statement only. I did read the owners manual but missed that part.
    @WhiteTundra0013: This is the primary reason I decided to switch to the Tundra. my requirement was to be able to pull the work trailer and I needed 4x4 based on where I live. I had planned to buy a new Ford but to get the same bells and whistles, (Lariat +), they wanted almost $7K more. The price of a new truck is already EXPENSIVE (to me).
    Eurodriver likes this.
