Rattle sound when turning
Discussion in 'General Tundra Discussion' started by cap50948, Sep 23, 2019.
  1. Sep 23, 2019 at 8:30 AM
    cap50948
    cap50948 [OP] New Member
    2015 MGM Tundra CM 5.7
    TRD Rear Sway Bar ADD Venom front bumper Rough Country LED rear bumper AFE Drop in Filter Husky liners
    I have recently been hearing and feeling a rattling sound when turning sharp at low speeds. Like something is loose. Anybody have similar experience or clue what it could be. No shake at high speed when going down highway.
  2. Sep 23, 2019 at 8:31 AM
    15whtrd
    15whtrd Mr. Blonde
    Are you lifted or do you have different offset wheels and possibly larger tires? It could just be the tire rubbing on the fender liner or anything else in the wheel well.
  3. Sep 23, 2019 at 9:20 AM
    cap50948
    Not lifted, stock suspension, wheels and tires. Doesn't really feel like a rub more of a rattle. I do have after market front and rear bumper.
    15whtrd likes this.
  4. Oct 1, 2019 at 7:48 AM
    cap50948
    Any0ne have any clue as to what this could be. I thought it might be steering column but there's no play in it or rattle or shake at higher speeds. Only seems to happen when I drive under 20 and am turning sharp. Backing out of places and turning on city streets.
  5. Oct 1, 2019 at 8:24 AM
    Splash guard loose? Maybe have someone walk with you can it be heard walking speed? You have a GoPro or someone have one try capture vid where coming from or video it with windows down let us here
  6. Oct 1, 2019 at 8:55 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Perhaps this is the cause.
  7. Oct 1, 2019 at 12:09 PM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Get underneath and check your catalytic converter heat shields. On my 09 Crewmax 2 started to rattle. One, then the other right after. Depending on which one and where it was loose, I might only be able to hear it when turning the wheel a certain way. More pronounced when I just started the truck and everything vibrated more, than less so as it warmed up and they got drowned out by engine and road noise. That's probably the easiest, fastest thing to rule out.
    TokerJoker likes this.
  8. Sep 12, 2023 at 8:52 PM
    Garrett2014
    Garrett2014 New Member
    2014 Black Tundra Limited 4wd
    TRD pro suspension, coachbuilder 1” shims, bumper shims, 3” rear shackles, 1.25” wheel spacers stick wheels 285 75r18
    I have the same Rattle. Did you ever figure it out?
