  1. Sep 10, 2023 at 7:48 PM
    :thumbsup:
    Welcome from NY.
    Clackrackem[QUOTED] likes this.
  2. Sep 10, 2023 at 7:53 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Wanted to work on my Sherpa rack. SWMBO had other plans. Spent the day doing yardwork instead.
    Wallygator, RobertD and bulldog93 like this.
  3. Sep 10, 2023 at 7:56 PM
    Ni-Ju-Ni
    Ni-Ju-Ni New Member
    2018 White Tundra Platinum 4x4
    New Slides and a body mount chop by Ryan (IronRyno Fab) @shmellmopwho.
  4. Sep 10, 2023 at 8:27 PM
    SAGE63
    San Diego County
    nooooo not yardwork
    bulldog93 likes this.
  5. Sep 10, 2023 at 8:28 PM
    SAGE63
    San Diego County
    pinch weld too...
  6. Sep 10, 2023 at 8:30 PM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    I scuffed them up with a red scuff pad, 3 coats of rustoleum auto primer and regret it. It went on super grainy and was awful to try and smooth out. Wish I went with another brand. Then 3 coats or Dupli-color Graphite HWP102 wheel paint, then two coats of clear. Not the greatest paint job but I’m happy with it overall.
    Thanks! Been growing more and more on me today.
    BlueRibbon4x4[QUOTED] likes this.
  7. Sep 10, 2023 at 8:55 PM
    Toyotaguy1654
    Toyotaguy1654 New Member
    2018 Tundra 5.7L
    I'm coming up on the 60.000 mile maintenance 2018 tundra crewmax I got it certified pre-owned. Did anyone here buy certified pre-owned and take it to dealer to do that service ?
    Tundrastruck91 likes this.
  8. Sep 10, 2023 at 9:26 PM
    Wallygator
    Started insulating the topper. This stuff is rated R6. Thought that was pretty good for 1" foam insulation and worth a few extra dollars.
    With just the sides done it's 20 degrees cooler in there. Purdy good since it's not even close to being done.
    Cut the top of the sleeping platform and added a piano hinge. Makes it so much easier to access things when I'm stuck inside the topper. Covered the piano hinge with gorilla duct tape to protect the mattress.
    AGTundra, welshmike, myt1 and 15 others like this.
  9. Sep 10, 2023 at 9:36 PM
    Ni-Ju-Ni
    Ni-Ju-Ni New Member
    Oh ya! Ryan hooked it up!
  10. Sep 10, 2023 at 10:20 PM
    Chelly
    Chelly ...
    Mt Hood / PDX OR
    2020 Platinum - Super White
    Elka DSC Suspension, Ray-10s, MaxTrax, Dirt King UCA, 295/70/18 Toyo AT3, TRD Skid + Intake, .25 Bumper Shim, UnderCover UltraFlex Tonneau, RoadActive Suspension, Tuffskinz, etc.
    Nice job on the paint, looks great!
    bulldog93[QUOTED] likes this.
  11. Sep 11, 2023 at 4:28 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Cerakote?! Looks awesome!
  12. Sep 11, 2023 at 4:44 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I spot a TM Nalgene
    :headbang:
  13. Sep 11, 2023 at 5:02 AM
    Not to thread jack, but quick question for you. Where would I get a 2 pin connector to attach wires to the rear sliding window motor for the double cab? I gave up on the parking light issue for now until I am done with this window project.
    mgm16trdpro likes this.
  14. Sep 11, 2023 at 5:03 AM
    Yes Cerakote based on yours. :D I actually found it at Lowes.
  15. Sep 11, 2023 at 5:20 AM
    bfunke
    bfunke Tundra Curmudgeon
    You can purchase connectors from Toyota dealer. Then crimp on the correct pins and insert into connector
  16. Sep 11, 2023 at 5:26 AM
    The part number is what I was needing actually. :)
  17. Sep 11, 2023 at 6:35 AM
    RustyShackle323
    Stewart
    NC
    Excellent! I got mine at Walmart. Really happy with how it turned out on the handles.
    Tundra234[QUOTED] likes this.
  18. Sep 11, 2023 at 8:26 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Use the 2.0 section of the 18-21 EWD to find the connector name. Then look that connector name up in section 6.0 to get the part number (usually starts with 90980-).
    That looks like it might be a sealed-style connector, so I would then take that part number over to https://www.corsa-technic.com/index.php and look it up there to see if they have it for purchase. It will be cheaper than toyota if they do, and will come with the terminals rather than having to buy the pigtails from toyota
  19. Sep 11, 2023 at 8:29 AM
    Thanks Casey. I appreciate your help as always!!
  20. Sep 11, 2023 at 10:34 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Not sure if anyone remembers at this point, but finally getting my windshield replaced today/tomorrow. Ultimately it's going to be covered fully under warranty, and it should be installed & ready for pickup tomorrow.
    The SA said that they have a video of the windshield leaking - apparently it just goes entirely around where the seal should be at the bottom on the driver's side. I'm going to try to follow up and get a copy that I can post here in case anyone else runs into this issue again.
    Just going to be happy to not have to be covering my Tundra every time it rains...
  21. Sep 11, 2023 at 11:13 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
  22. Sep 11, 2023 at 2:16 PM
    Ordered the back window. It will be here tomorrow. Now to find out how much it will be to have it installed.
    Wallygator and bulldog93 like this.
  23. Sep 11, 2023 at 3:13 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Took my CPO (bought at 65k miles) to recommended private shop for 75k mile service.
  24. Sep 11, 2023 at 6:12 PM
    Matt56258
    Matt56258 New Member
    Matthew
    Savannah GA
    2021 Tundra Platinum MGM
    TRD grille, TRD dual exhaust
    Princess steps installed this weekend!! Amp Research Power Steps to be precise. Very straightforward installation.
  25. Sep 11, 2023 at 6:21 PM
    biebs96
    PA
    truck looks great. Minus the chrome lugs…
    order some colorlugs.
  26. Sep 11, 2023 at 6:30 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Nice work! What insulation did you go with?
    Wallygator[QUOTED] likes this.
  27. Sep 11, 2023 at 6:59 PM
    Matt56258
    Matthew
    Savannah GA
    I actually have some black lugs I’ve been debating going to. I like having the little touches of chrome to pay homage to her beginnings. Haha!
  28. Sep 11, 2023 at 7:02 PM
    biebs96
    PA
    ;) If anything just rock a chrome tailpipe tip… that’s old school without question.
    ATV25, bulldog93 and Tripleconpanna like this.
  29. Sep 12, 2023 at 6:14 AM
    brevard828
    brevard828 New Member
    2021 Limited TRD Off Road
    Jumped on the Westcott train this weekend! I've heard great things about their products and their customer service reps answer the phone every time. It's been a while since I've had time to play with the old Tundra. I've had 5100's on the middle setting for about a year and have loved them. I will be using the full 3-1 lift option for the Westcott. They say no BMC and no UCA (I will see what the alignment guys say and will possibly order a UCA depending)
    Also installed Daystar cradles for the airbags that I've had for quite some time as well. Toyo Open Country AT3 295/70r18's are going on Friday when she goes in for an alignment. Bilstein 5160 rears to come soon as well mostly because I cant find 5100 rears anywhere.
  30. Sep 12, 2023 at 6:25 AM
    brevard828
    This is the kind of research i can get behind!
