No high gears!
Discussion in '2nd Gen Tundras (2007-2013)' started by Simonsaid, Sep 10, 2023.
  1. Sep 10, 2023 at 5:25 PM
    Simonsaid
    Simonsaid [OP] New Member
    2007 Toyota Tundra
    Hey guys, I bought a 2007 Tundra 2wd with a 5.7 about 8 months ago or so. Been great up until a few weeks ago. Did general maintenance, new tires, pads and rotors, serpentine belt, etc... felt good about everything.
    Truck has like 230k btw.
    Cruising to work about 60mph and suddenly my trucks downshifts and my rpms are way up and my dash lights up with warnings. VSC OFF light, traction control off light and check engine light. What the heck. I turned around and drove slowly home.
    I'm getting 3 codes that I've read.
    P0973 shift solenoid A control circuit low
    P0751 shift solenoid A performance/stuck off
    P2714 pressure control solenoid D performance stuck off
    So what did I do next? I checked fluid level on that check plug. Seems good.
    Next I drained the fluid, broke 8 of the 12 pan bolts... nice, and pulled out all the solenoids in there, one at a time. Put power to them, and they all clicked. Darn was hoping to find one bad and be obviously at fault. So I'm like what the heck... maybe they are clicking and moving but still at fault, so I checked with my multimeter. No clue what ohms they should read but the smaller shift solenoids read all the same, and the bigger pressure control solenoids read the same as well.
    So what should I do next??
  2. Sep 10, 2023 at 8:12 PM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Sounds very similar to when my wife's transmission in her 2011 Sequoia went out. Hers went into limp mode the first time. I shut off the engine and restarted, it ran good for about 1 week. I should have taken to a shop immediately. Was on the highway when it finally started really slipping and did almost exactly like you described. Took to a friend/mechanic and he said lots of metal shaving in transmission. He found us a used one from a totaled Tundra (rear ended) with only 7k miles. Ours went out at only 130k miles, bought it with 122k miles. The previous owner must have ran it really hard. Ours is a 2wd with 4.6 Liter. Best of luck getting yours back on the road.
  3. Sep 10, 2023 at 8:15 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I had a D4 solenoid go out with identical symptoms but different but similar code. It cycled fine and measured at the edge of acceptable resistance. Replaced, cleared codes, and its been great for 10K.
    Fwiw, I spent $ on a Toyota solenoid and it was the same OEM brand as the cheap ones on Amazon.
  4. Sep 10, 2023 at 10:58 PM
    blenton
    blenton New Member
    Did you check for bad wiring upstream of the actual shift solenoids? Critter get to them or a pinched/burnt wire?
  5. Sep 10, 2023 at 11:08 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Truck entered 'limp' mode w/the error codes... which is why the dash lights all lit up.
    In addition to the shift solenoids, you can also end up w/bad pins (connectors) within the harnesses and such...
    Definitely not fun to try and chase those types of issues. Like Blenton said, you'll want to check not only in the pan, but connections running to the transmission, and up to the main harness. Terminals on the exterior of the transmission are susceptible to corrosion depending on what part of the country the vehicle spent most of its time in.
  6. Sep 11, 2023 at 7:22 AM
    2007 Toyota Tundra
    I'll check out what the plug looks like in a few days... someone told me maybe it's just bad trans fluid. What came out is pretty nasty. Had some 'silver sludge' on the bottom of the pan by all the magnets but original fluid 230+k miles I figured that would be normal.
    I guess I should check wire continuity from plug to different solenoids.
    Sold my Chevy for this thing, didn't expect trans problems so quick! What I get for buying something pretty high mileage lol
