Confirmation of TPMS light status
Discussion in '1st Gen Tundras (2000-2006)' started by ablemob, Sep 10, 2023.
  1. Sep 10, 2023 at 12:41 PM
    ablemob
    ablemob [OP] New Member
    Hi,
    I had one TPMS sensor on my '06 Tundra replaced because of a broken stem and the tire couldn't hold air, and then drove for 2 months with a BLINKING TPMS light on my dash until I had the other 3 sensors replaced on the running tires. Tire guy informs me that the spare sensor is dead also. I fully expected to continue to see a flashing light, but now it's SOLID. I checked all the tires and the pressure is fine. The tire guy is trying to tell me this solid indicator is because of the dead sensor in the spare, but I'm fairly certain he is wrong, and that it should be blinking instead. I'd prefer it blinking; the solid "false positive" light is really annoying. Any ideas besides taking it to Toyota, which I'd prefer not to do? Thanks!
  2. Sep 10, 2023 at 2:15 PM
    shifty` Oh, I have felt Cobain's sarcoma
    The only way to really know what's going on is to attach a code reader/app that lets you tap into the ECU for the TPMS to see what codes are set, and why it's bitching. Your mechanic should have such a tool. I bought my own tool to do it.
    As with most things electronic on these trucks, you want to stick with OEM brand (Toyota/Denso/Aisin). I'm assuming the tire shop probably used generic/3rd party sensors. That may be at the root of the problem.
    But really, the next step for you would be to check what TPMS code is set - which again - is not something your average $30 code reader can do.
  3. Sep 10, 2023 at 3:55 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I replaced all sensors on mine with Denso. The truck does in fact have - sensor in the spare tire.
    5 sensors total
    EmergencyMaximum likes this.
  4. Sep 10, 2023 at 4:36 PM
    Just confirming - mine was same also - sensor in the spare. I used the www.densoautoparts.com website to look up the replacement sensors. Note, they usually have at least 2 part numbers: 1 for steel wheels, 1 for alloy wheels.
  5. Sep 10, 2023 at 4:45 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    shifty` likes this.
  6. Sep 10, 2023 at 4:50 PM
    It's worth mentioning, some wireless OBDII dongles, when paired with smartphone software, **CAN** dig in on TPMS problems.
    Here's how I resolved mine: https://www.tundras.com/threads/obd-thread-pids-apps-dashboards.60459/page-10#post-3132384
    Here's more info on the product I bought - they do have a cheaper product; I opted for the MX+ because of the unlimited support and add-ons, which has helped pay for itself: https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-1640#post-3264002
  7. Sep 11, 2023 at 8:01 PM
    ablemob
    But can anyone confirm that with a dead sensor in the spare, that the light on the dash should be blinking, as opposed to steady?
  8. Sep 12, 2023 at 4:52 AM
    It's my understanding, generically speaking, across multiple manufacturers:
    Solid light = Low tire pressure
    Flashing light = Failure to communicate​
    You have three basic components to the TPMS system:
    • TPMS ECU (actual brains of the operation)
    • TPMS receiver (mounted in roof between dome light and 3rd brake light, hardwired to ECU, catches wireless signal from sensors and sends to ECU)
    • TPMS sensors (in each wheel, broadcasts tire pressure signals indiscriminately from tire)
    "Failure to communicate" can be any number of things. TPMS receiver died. Wiring fault between receiver and ECU. One or more TPMS sensors aren't transmitting (battery dead or physical damage).
    All 5 of my tires have sensors from the factory. You can tell when you look at the valve stem whether or not it's a standard black valve stem or if it has a TPMS sensor, they're silver/alloy colored.
    When I open my TPMS network to debug, I see five tires programmed in. If you're on your original TPMS sensors, yes, it's quite possible that (A) like the other sensors, your spare tire's sensor is dead and (B) that sensor failure is causing the dash light to flash.
    In my case, I have more than 1 sensor failed. I had options:
    1. Ignore the flashing light
    2. Use a tool like Techstream to erase the failed sensor from the ECU so it no longer expects input from that sensor (no sensor to monitor = "no problem")
    3. Use a tool like OBDLink to erase the error code for that sensor out
    4. Replace the bad sensor(s)
    I personally opted for #3, knowing my truck is 17 years old and on its original sensors, and I'd be updating my wheels & tires soon, at which time I'll be doing #4 anyway.
    You have now pretty much exhausted my knowledge of TPMS. But if you still have questions, fire away, maybe someone else can pitch in.
  9. Sep 12, 2023 at 5:38 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Since his is ON, it should indicate low
    pressure, as you mentioned with your “genetically” comment and matches what @jerryallday said.
    from 2006 Owners Manual…
    I suppose it’s easy for me to say, since I don’t have TPMS but personally I’d check air pressure in spare and go from there
    shifty` likes this.
