Side mirror connector pinout info
Discussion in 'Lighting' started by NavyMCPO, Jan 19, 2018.
  1. Jan 19, 2018 at 5:07 PM
    NavyMCPO
    NavyMCPO [OP] New Member
    Lindsay
    I am looking to add an LED to my pillars for BSM indicator when I change out my mirrors for tow mirrors. Does anyone have the pin out for this connector by chance?
  2. Jan 19, 2018 at 5:30 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  3. Jan 19, 2018 at 7:13 PM
    mesaboogieman
    mesaboogieman New Member
    Joe
    Black 2014 Toyota CM Limited
    I used this layout when doing the power folding mirror mod on my 2014 Limited. Got it from TundraTalk.net:
    http://www.tundratalk.net/forums/tundra-lighting-electrical/439441-2014-sr5-platinum-power-fold-mirror-install.html
    Pin 1: Heat +
    Pin 2: Heat –
    Pin 3: Signal – (Running Light -)
    Pin 4: Signal +
    Pin 5: Puddle Lamp – (Already wired as common ground, needs rewire to make puddle lamps work)
    Pin 6: Puddle Lamp +
    Pin 7: Mirror Retract (+)
    Pin 8: Mirror Fold (–)
    Pin 9: Running Light +
    Pin 10: Mirror Vert (power)
    Pin 11: Mirror +
    Pin 12: Mirror Horiz (power)
    Pin 13: Auto-Dim –
    Pin 14: Auto-Dim +
    Pin 15-18: Memory Pins
  4. Feb 17, 2019 at 5:20 PM
    Tokyolow81
    Tokyolow81 New Member
    Pete
    2011 Rock Warrior 4wd DC, Mag Grey
    6" ProComp lift, ProComp 20's, 35" Ridge Grapplers, NFab Bars, BaKflip G2, Advent hu with 10" pioneer sub.
    Thanks! This just saved my ass trying to hook up Halo DRLs to the mirror signal Circuit.
    mesaboogieman[QUOTED] likes this.
  5. Feb 21, 2019 at 1:33 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
  6. Feb 21, 2019 at 9:20 AM
    SpeshulED
    I’d love to eventually do this to also add puddle lights, arrow signal lights and power folding
  7. Jul 12, 2019 at 1:21 PM
    08Yiota
    08Yiota New Member
    Do you remember where you got this connector? Ours (on driver side in the door) corroded and needs replaced but I can't find one anywhere. Thanks in advance!
  8. Jul 12, 2019 at 2:24 PM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    Looks like some good info here, if I decide to go ahead and add tow mirrors. Thanks for posting.
  9. Nov 16, 2019 at 12:54 PM
    Tundra-Canuck
    Tundra-Canuck New Member
    Les
    2014 Crewmax
    Bags, command air, flares, light bars, titan tanks
    This is great info guys Thanx. I installed a pair of heated power mirrors and my running/signals were wired opposite. When the running lights were on the driver's side was the top light and the pass side was the bottom. It was an easy wire reversal once I had the stock plug wiring diagram.
  10. Dec 18, 2019 at 4:57 PM
    Meltz
    Meltz New Member
    I just got tow mirrors. Can you guys help me on how to make the tow mirror outer led lights and blinkers work? I have a 17 limited and the BSM and power works. Just the outer LEDs and blinker for the out LEDs do not work. What is the process to fix this? Thanks.
  11. Dec 20, 2019 at 12:25 PM
    Docdanracy
    Docdanracy New Member
    Yes I just installed a set of 1A auto tow mirrors on a 2018 SR5 Sequoia, heat and BSM are functional but mirror clearance light and blinker are non functional currently.
    Besides the plug diagram and the pin out listing, does anyone have the wiring color coding for the plug that is in the door that plugs into the mirror? Thanks
  12. Feb 4, 2020 at 5:11 PM
    Tundra13jr
    Tundra13jr New Member
    concord nc
    2017 Toyota Tundra 4x4 magnetic grey
    Im putting Switch backs on my chevy Style tow mirrors and when I put the wire to the running lights (pin 9) my fuse just keeps popping...any input would be great
  13. Feb 4, 2020 at 5:58 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    MentalBill likes this.
  14. Feb 4, 2020 at 6:01 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    FWIW...
    A super easy to test the pin on the mirror to identify what does what...
    Used the above pin out info to help identify what wires did what with a 9 volt battery.
    you will see the bsm light up
    You will see the auto dim
    Your will see the blinker work
    Puddle lights as well
    And you will hear the motor try to fold and open (battery too weak)
    It’s a backyard way but it works..
  15. Aug 8, 2020 at 6:06 PM
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    Does anyone know what type of wire connect (molex) to use for the pin out on the power fold mirror. I need to insert the male socket into the connector to plug into the mirror connector to get the power fold option to work. I just don't know what type of male terminal to use for the connector
  16. Sep 10, 2023 at 11:11 AM
    Ragand0033
    Ragand0033 New Member
    2015 platnium
    Level, 33” 20x10
    Hi! Same issue here where I need to swap 9 and 18. Can someone show me how to swap the pins. Does the harness open? How? The wires are firmly in the harness so I’m assuming you don’t just pull and plug?
  17. Sep 10, 2023 at 11:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  18. Sep 10, 2023 at 11:23 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
