Helo Wheels with TPMS
Discussion in '2.5 Gen Tundras (2014-2021)' started by Borador, Sep 8, 2023.
  1. Sep 8, 2023 at 6:47 PM
    Borador
    Borador [OP] New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    Is anyone else using Helo wheels and if so, does your TPMS connect or reflect the tire air pressure with an aftermarket radio?
  2. Sep 9, 2023 at 3:14 PM
    ohiowa
    ohiowa Have you tried turning it off and back on again?
    Ohio
    2021 SR5 CM Cavalry Blue
    The manufacturer of a given wheel has little to do with TPMS sensors. Your tire shop can tell you whether they can get sensors compatible with your truck, or if they can reuse the OEM sensors.
    Borador[OP] likes this.
