General Supercharger Thread
  1. Sep 7, 2023 at 11:05 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I had to zoom in...haha
  2. Sep 7, 2023 at 12:03 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Over on tacoworld OTT announced a few weeks ago they officially finished a canned tune for the 4runner. I think y'all are all right, and that they've finally collected all of the baselines they needed to roll out finished canned tunes for all the variables they encountered
    Edit: said post. But who know what the real answer is until we hear from the source. https://www.tacomaworld.com/threads...-overland-tailor.759590/page-60#post-29000546
  3. Sep 7, 2023 at 2:43 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    @ViktorG must want you to make him a custom 50mm pulley for his Harrop to spin it to the moon!
  4. Sep 7, 2023 at 3:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    It’s arrived
  5. Sep 7, 2023 at 3:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Quick pull can confirm the boost is there lol. Spike then held 9.3. Time for a tune. She moves for a big girl
  6. Sep 7, 2023 at 3:52 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Where is the IAT sensor for the Whipple?
  7. Sep 7, 2023 at 4:03 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Maf
    Saltyhero13 and ZPhilip[QUOTED] like this.
  8. Sep 7, 2023 at 4:47 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Only monsters run their boost gauge on the right.
    Mdl, CaptRussia253, ZPhilip and 2 others like this.
  9. Sep 7, 2023 at 4:54 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Damnit, I knew it, mines on the left.
    Mdl, Saltyhero13 and reywcms like this.
  10. Sep 7, 2023 at 4:58 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Shit lol
  11. Sep 7, 2023 at 5:58 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
  12. Sep 7, 2023 at 6:22 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    I wish that were true!
    You actually cannot run smaller than a 60mm on the Harrop as it will not clear.
    I am having a hard time preventing belt slip even with the Griptec treatment on mine, might have to go to a bigger pulley :(
    Mdl, ssmokedz, Saltyhero13 and 3 others like this.
  13. Sep 7, 2023 at 6:54 PM
    Silver17
    Eastern PA
    And you are already running the 7” under drive pulley I take it? Just trying to do the math, if you are and had a 60mm I guess that means you’re cranking the Harrop at nearly 20k rpm if you’re running your built motor to 6500rpm? Well, at least 19k.
    Fastlane47 and ViktorG[QUOTED] like this.
  14. Sep 7, 2023 at 9:47 PM
    ViktorG
    Viktor
    Calgary, Canada
    Yeah, you are pretty close.
    It is an 8" lower pulley though, so at 7200 shift RPM it is spinning the blower at around 24K :eek:
    There is no more to be squeezed out of the Harrop.
  15. Sep 8, 2023 at 4:03 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I tried doing some searches, but couldn't find anything definitive. Anyone know what baseline fuel pressure the Harrop modified FRP is set to? What's stock?
    I'm starting to get a baseline tune with DW650's setup and working injector multiplier now and a higher base fuel pressure will affect this a bit.
  16. Sep 8, 2023 at 4:13 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    famous last words.....
    Saltyhero13 and ViktorG[QUOTED] like this.
  17. Sep 8, 2023 at 4:43 AM
    ZPhilip
    Philip
    West Chester, PA
    I called Harrop and they had no answer to the fuel pressure question to their own modified regulator.
    Saltyhero13 and Wynnded like this.
  18. Sep 8, 2023 at 5:42 AM
    Silver17
    Eastern PA
    I still don’t know the definitive answer to this. Maybe ask on the boosted page.
  19. Sep 8, 2023 at 6:06 AM
    VWTim
    Corvallis, OR
    Paging, @Vizsla Not sure what your engine combo is, but I know you have a gauge on the fuel system. What is your setup and baseline pressure?
  20. Sep 8, 2023 at 7:57 AM
    ssmokedz
    Shelton CT
    Wow! Maybe i have missed it and you have covered it before, but what approach have you taken on the cooling system to try and manage all of the heat that blower is creating at that high rpm?
    ViktorG[QUOTED] likes this.
  21. Sep 8, 2023 at 8:07 AM
    ssmokedz
    Shelton CT
    @Silver17 you think we can add ViktorG to our dragy times page? I'm sure he has some cool kills we haven't seen yet.
    ViktorG, Silver17 and Saltyhero13 like this.
  22. Sep 8, 2023 at 9:19 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The basic formula is: base fuel psi + boost psi + pump lose= fuel psi required
    Mines at 43.5+10+5=58.5 regardless of injector size. This was shooting for 600hp.
    I believe prospeed requires to have it at 60psi for starting their tuning.
    Saltyhero13 likes this.
  23. Sep 8, 2023 at 9:22 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    When I installed the Deaschwerks 300, forgetting to dial the FPR back, (from the defective Walbro 450) I had over a hundred for a bit. I'm running at 50 at idle now, I see 60 when driving.
    ssmokedz and VWTim like this.
  24. Sep 8, 2023 at 9:30 AM
    VWTim
    Corvallis, OR
    I'm more looking to see the delta on the Harrop "crush" over stock PSI. I found a few references on FB, but nothing definitive. Toyota spec is 38-43PSI at idle. I've found 43PSI @ idle (boost referenced) for Harrop mentioned, but not confirmed. Either way, it looks like it bumps 11% at absolute most, so I probably will just do a base scale for injector size and see how the closed loop fuel trims look and dial it in from there. Once I get closed loop dialed in, I'll start working on PE tables.
  25. Sep 8, 2023 at 2:35 PM
    ViktorG
    Viktor
    Calgary, Canada
    Upgraded intercooler pump, huge intercooler heat exchanger, 1.25 gallon fluid tank, Killer Chiller.
    What does the nitrous Camaro run in the 1/4 mile?
  26. Sep 8, 2023 at 4:42 PM
    ssmokedz
    Shelton CT
    Nice thats a big tank. Seems like it works well for you. Best has been 11.59@119 on motor. Spray wiped out the input shaft and counter shaft last time so i am not sure what it will do on spray. Sure is fun on the street though!IMG_7431.jpg IMG_7196.png IMG_6489.png
  27. Sep 8, 2023 at 5:15 PM
    ViktorG
    Viktor
    Calgary, Canada
    Damn!
    ssmokedz[QUOTED] and Mdl like this.
  28. Sep 8, 2023 at 6:07 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Man...upstream O2 sensor started acting erratic. Was in boost and looked at my afr and saw it dancing between 10 and 14 then sticking at 18. Got a p0138 code when I got gas. Funny that my rear o2 have Sims on them. Guess when upstream goes out it reverts to using the rear. Hopefully it's just the upstream one passenger side.
    ssmokedz likes this.
  29. Sep 9, 2023 at 10:51 AM
    JustDSM
    JustDSM New Member
    Justin
    This is 100% incorrect and missing a lot of contextual details. We had some very specific instructions and requirements set to ensure you got the absolute best possible calibration possible. But as we were told those steps were not willing to be made, and thus we elected to pass on the work.
    Sorry it didn't work out, but we're not in the business of taking short cuts to make quick buck.
  30. Sep 9, 2023 at 10:57 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Welcome.
    Thanks for doing some rumor control.
