  1. Sep 7, 2023 at 6:54 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Unboxed my roof rack. Ordered some radio installation parts.
    BlueRibbon4x4, Mater, RobertD and 3 others like this.
  2. Sep 8, 2023 at 4:43 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
  3. Sep 8, 2023 at 5:11 AM
    Rc23
    Rc23 New Member
    Ross
    Chesapeake
    '16 Super White CrewMax
    You may want to zip tie that e-brake cable up off of the leaf spring - it's wearing through the rubber. I had the same issue and I also added an extra piece of rubber hose around it in case.
  4. Sep 8, 2023 at 5:44 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    reywcms[QUOTED] likes this.
  5. Sep 8, 2023 at 5:50 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Good eye!
  6. Sep 8, 2023 at 7:26 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Installed a battery on/off switch (red), to cut power for the winch and second battery in the trunk. Dual battery isolator (black) was installed a few months ago and works great.
  7. Sep 8, 2023 at 7:51 AM
    DowntownApexTundra
    DowntownApexTundra New Member
    2021 DC SR5 4x4 Sport
    3/2 leveling lift kit, pocket style fender flares (best super white color match you'll ever see - painted by my uncle), 1.5" wheel spacers, S&B CAI, TRD Pro headlights, 18" knockoff Ebay TRD Pro Wheels, wildpeak at3w 275/65R18 116t (32/11), gator roll-up tonneau, blacked out interior by AJT and others, pedal commander, blacked out exterior badges, LED everything, RCI neoprene water proof seat covers (removed back middle seat back material to make it work), weather tech floormats, flowmaster flowfx extreme 3.0 exhaust
    Excellent catch - thank you!
    Tripleconpanna and Rc23[QUOTED] like this.
  8. Sep 8, 2023 at 8:15 AM
    WSDMetal
    WSDMetal Motorsports Fabrication & Design
    Huntington Beach
    Fittipaldi Off Road FT102 17x8.5 +0
  9. Sep 8, 2023 at 8:19 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Love the xl linkable on the roof. You make your own mounts for that?
    kingpin3919 likes this.
  10. Sep 8, 2023 at 8:21 AM
    WSDMetal
    Huntington Beach
    Thank you! Yes sir, wasn't happy with anything on the market so I developed my own.
  11. Sep 8, 2023 at 8:22 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    That's a lot of hood glare. I moved my offroad lights to the front bumper, they were blinding me on the roof.
  12. Sep 8, 2023 at 8:22 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I might need this Ahha
  13. Sep 8, 2023 at 8:23 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I’m sure lens pattern plays a role on this.
    BlueRibbon4x4, BiggHertz and WSDMetal like this.
  14. Sep 8, 2023 at 8:40 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Make night pictures.
    WSDMetal likes this.
  15. Sep 8, 2023 at 9:07 AM
    WSDMetal
    Huntington Beach
    Hood glare definitely is a consideration with roof lights.
    Reflector beam patterns will absolutely affect the amount of glare experienced. Spots are best to minimize hood glare, as well as the angle of the lights. Going with a top brand that actually engineers their products for optimum output and performance like @Baja Designs will also help with this.
    RainMan_PNW, BiggHertz and bulldog93 like this.
  16. Sep 8, 2023 at 3:38 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I had the same issue. I was able re-bend the brackets to allow more clearance.
    Tundrastruck91 likes this.
  17. Sep 8, 2023 at 9:43 PM
    Deeberz
    Deeberz New Member
    Dave
    2020 Limited CM Cement Gang
    Bilstein 6112/5100 on the 1.9” setting, sumo springs
    Not sure if I’m doing this right… is this where I post if I’m excited about my new tire/wheel setup? Method 705, 0mm offset, Falken AT3w (285/75r17). Super happy with how the titanium wheels look against the cement.
    edit: Bilstein 6112’s up front on 1.9 setting; 5100’s on the back.
  18. Sep 9, 2023 at 3:49 AM
    TRD4x4Liberty
    TRD4x4Liberty Dog hauler
    NYC area
    Heavy Metal Crown - Black TRD PRO Sequoia
    Original.
    Looks great. Like monochrome colors in a picture…
  19. Sep 9, 2023 at 3:55 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    :yes::thumbsup:
  20. Sep 9, 2023 at 8:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Made $38! :) I was lazy and haven't had 3 alternators separated into copper, aluminum and steel buckets, could have done more.
  21. Sep 9, 2023 at 8:33 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Me too…but…I’m still on fence of a Sherpa Rack with the purpose of throwing a 50” BD onx spot or racer up top…
    RainMan_PNW and reywcms[QUOTED] like this.
  22. Sep 9, 2023 at 9:39 AM
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    I have done quite a bit to my 2018 Tundra, how about a full Mid travel system. Full System Camburg UCA’s, Total Chaos LCA’s, RCV axles, Ikon RXT leaf spring pack, FOX FACTORY 2.5 DSC shocks front and Rear, FOX FACTORY 2.0 rear bump stops with Camburg bolt on bump stop mounts, Dirt King Shackles. Took it to Pismo and Did a little pre-runnin’ definitely ligit. Handled pretty much everything out there. If someone is interested I have had this kit on for 2 months and I love it, but definitely interested in selling the kit, as I’m diggin’ down the Long Travel rabbit hole. What can I say, I gotta a lead foot and love pre-runnin’. I can’t post in classifieds since I don’t have 50 plus posts, but I’m certainly not some bozo scammer. I have receipts for all the equipment and installation from 4WP in San Diego. Listed on Offer Up.
    willy, SoCalTundy, TreeCat and 11 others like this.
  23. Sep 9, 2023 at 3:24 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    No complaints. Bedrug is :thumbsup:
  24. Sep 9, 2023 at 3:57 PM
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Repainted my wheels to graphite. I like it better than the flat black methods I had before, I think they will grow on me.
  25. Sep 9, 2023 at 4:08 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Gettin' a workout in during the install ;)
  26. Sep 9, 2023 at 4:55 PM
    RustyShackle323
    Stewart
    NC
    Excellent! I have a very similar setup with the bed rug plus the molle panel.
    Flyinryank[QUOTED] likes this.
  27. Sep 9, 2023 at 5:23 PM
    seydou
    seydou Distinguished Member
    Do you really run that without a topper or tonneau? With dirt roads, leaves, acorns, dogs, dust, debris and cargo, it would take about a week before it was so filthy it would take me a week to clean. Looks nice though.
  28. Sep 9, 2023 at 5:53 PM
    BeauDacious and bulldog93 like this.
  29. Sep 9, 2023 at 7:01 PM
    Tan-dra
    Tan-dra MUD GANG 2006
    2020 Quicksand SR5
    Bilstein 5100, 35’s on 17” wheels
    Finally got everything done that I wanted to do since I bought this thing. Now I feel like I want 37’s :annoyed:upload_2023-9-9_20-59-10.jpg
    alphaxcrx, Major, Tundra-XP and 23 others like this.
  30. Sep 9, 2023 at 7:52 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Hoping to install my Sherpa tomorrow
    It’ll be a while before a 50” materializes though
    WILLINH and BiggHertz[QUOTED] like this.
