Good offset for these flares?
Discussion in 'Wheels & Tires' started by Tundraarnie, Sep 6, 2023.
  1. Sep 6, 2023 at 2:46 PM
    Tundraarnie
    Tundraarnie [OP] New Member
    2021 Toyota Tundra TRD Pro (Black)
    Hi was wondering what offset wheels I should get to sit flush or alittle less than flash with these flares? Was planning to run 295 70 18 tires. Also planning on getting SPC UCA just to have, and the Westcott Designs lift kit. Open to suggestions as well. Thanks in advance.
  2. Sep 6, 2023 at 3:42 PM
    I can't tell but those look like the Bushwacker pocket style like I have. I run 295/70's and a 0 offset wheel. My tires are just outside the edge of the flares. I would consider that option if adding a lift as well.
  3. Sep 6, 2023 at 10:10 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    My guess is a +12 to 0 offset with a 9” wide wheel. Depending on tire size, you may need to do some trimming to make them work though!
    Tundraarnie[OP] likes this.
  4. Sep 6, 2023 at 10:28 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This front was +18, they still sat in a little, but they also rubbed in reverse at full lock.
    I ended up returning the wheels because they wouldn't balance.
    As others stated I'd say a O would probably sit about even.
    That's a stock +55 on the rear.
  5. Sep 7, 2023 at 4:51 AM
    295/70/18 18×9 0 offset
    Compress_20230907_074835_5192.jpg Compress_20230907_074835_5375.jpg Compress_20230907_074834_4408.jpg Compress_20230907_074834_4592.jpg Compress_20230907_074834_4166.jpg
  6. Sep 7, 2023 at 5:48 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Method and a few other brands often have +18 offset option.
    I suspect they would be just inside which would be good for keeping rocks and other spray off side of truck.
    I dont have flares. My 18x9 +18 with 295s are slightly outside fenders. I put my tube steps back on just to help keep debris kicked from tires off my doors.
    Keep in mind offsets are stated in millimeter.
    0 vs +18mm is just under 3/4 inch difference. You might not even see that difference from 10 feet back but you will see a difference in the amount of road spray down side of truck if you go in mud or snow.
  7. Sep 7, 2023 at 7:13 PM
    Tundraarnie
    Thanks for all the helpful replies, I now have an idea of where I want to go with offset.
  8. Sep 7, 2023 at 7:14 PM
    Tundraarnie
    thanks, I actually like that idea of a +18. I don’t mind it sitting abit inside the flare, as I would hate to kick rocks and mud/snow onto the side of my truck. And judging by all the pics provided it’ll definitely provide a more aggressive look.
  9. Sep 7, 2023 at 7:18 PM
    Tundraarnie
    that actually looks really good, think I’m going to go with the +18. Is that stock height? I’m planning on going with the Westcott TRD Pro Lift Kit. Tundra (2018-2021): 1.5” (front lift) 1.0″ (rear lift). And 295 70 18 wheels. I assume with my front bumper and the lift I shouldn’t experience rubbing?
  10. Sep 7, 2023 at 10:00 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I have a 2.5 front lift with my 6112s.
    If I had kept the wheels, I probably could have heated up the plastic fender wells and made clearance to stop the rubbing.
