Platinum Custom Vehicle Settings
Discussion in '3rd Gen Tundras (2022+)' started by 23 Platinum, Sep 5, 2023.
  1. Sep 5, 2023 at 9:29 PM
    23 Platinum
    23 Platinum [OP] 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    I want to use the custom settings to set up my AVS, sport and steering modes. When I turn the Drive Mode to Custom, I can't figure out what to do to do next. Anyone have a tutorial link for performing this? With the owners manual around 1,000 pages, I gave up after a few minutes. Thanks in advance for any assistance or suggestions.
  2. Sep 6, 2023 at 2:41 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Sorry. Not sure what you need. Turn the switch till it says custom (while in park). Settings will pop up on the top of the 14” display. Hit it then it’ll go to the menus where you can change your endgame, steering and suspension settings. Then when you go to custom it’ll go to those settings.
  3. Sep 6, 2023 at 5:20 AM
    NWFLATundra
    NWFLATundra New Member
    2023 Magnetic Gray Tundra Platinum
    Diamondback SE
    It's set up exactly as @Ipaddick stated. Watch your 14" display as you switch through the modes, when Custom is selected a settings button will be on the right side of the display, pressing that will take you to the custom settings.
    I have noticed however, that when Custom is selected and the truck is shut off and restarted it reverts to Normal mode. Every other drive mode seems to hold and stays at start up. Not sure if this is a normal software function or a glitch in my truck.
    ryanwgregg and 23 Platinum[OP] like this.
  4. Sep 6, 2023 at 5:34 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Most setting won’t stay (sport/sport+) it’ll usually stay for eco and regular. Not sure about comfort. Oh well, it’s part of my fighter jet start up routine.
    garage door, power, custom, brake hold, radar, radar closest setting, garage door close. Lol.
  5. Sep 6, 2023 at 5:38 AM
    NWFLATundra
    Diamondback SE
    I use ECO and Comfort and they both hold. Wasn't sure about the sport modes since I really haven't used them. Thanks for the clarification on those.
    "Fighter jet startup routine"...awesome.
    23 Platinum[OP] and pwpblue like this.
  6. Sep 6, 2023 at 5:46 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Good to know about comfort.
    I usually use custom. Eco engine, sport steering and comfort suspension. I rarely use anything else. (Besides tow/tow+ if towing)
  7. Sep 6, 2023 at 6:21 AM
    23 Platinum
    California
    Thanks everyone, I found a tutorial on YouTube that shows you have to press and hold ok button, then it opens up the additional options. I'm going to try all that I learned here this morning when I go to work. My goal is comfort setting with the steering set to Sport. I'll check back tonight.
    ryanwgregg and NWFLATundra like this.
  8. Sep 6, 2023 at 4:50 PM
    23 Platinum
    California
    Well, I figured it out. I couldn't do it all through the toggle switch, I had to complete the selections on the main screen. I'm set now on comfort and sport steering. Thanks all for your help.
    NWFLATundra likes this.
