UCA clearance with 295/70/18
Discussion in 'Wheels & Tires' started by drpheta, Sep 6, 2023.
  1. Sep 6, 2023 at 11:49 AM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    Pretty tight here. This enough clearance? This photo is on the lift with the shock at full extension.
    Here it is on the ground. Seems ok?
  2. Sep 6, 2023 at 2:44 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Must be stock wheels, or some very high offset option. If it never hits, you're good to party! Looks like about 1/2"?
  3. Sep 6, 2023 at 3:12 PM
    drpheta
    Stock TRD wheels (ET 60). Does look like 1/2".
    I'm debating on spacers or new wheels if I ever want to push it out more. Would be a $700 swing.
  4. Sep 6, 2023 at 8:41 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Well, if you like the styling of your OEM wheels, you could go with a 1.25” spacer and end up with the equivalent of a +28mm offset. That would be a nice fitment for about any tire you’re ever likely to install.
  5. Dec 16, 2024 at 3:55 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Which tire brand/model is this ? I currently have 285/75R18 Duratracs and I’m looking to go to 295/70R18.
  6. Dec 16, 2024 at 4:02 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This is what I did. I wasn't comfortable with the small clearnce, especially since I air down quite a bit on the beach. I did just pick up some +25 rims for really cheap, so I'll have some 1.25 Spidertrax spacers for sale cheap after the holidays.
