Cable from battery to Fuse Box
Discussion in '2nd Gen Tundras (2007-2013)' started by Cmaccullen, Sep 5, 2023.
  1. Sep 5, 2023 at 7:14 AM
    Cmaccullen
    Cmaccullen [OP] New Member
    2022 Tundra Limited
    This morning my truck died and I noticed the battery connecting the battery to the fuse box broke. My question is that cable easy to replace? I was able to rig it up to work for now but would like to replace the cable as a whole. Thanks!
  2. Sep 5, 2023 at 7:49 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm assuming the cable broke... I think that cable goes down to the alternator, may be wrong, but extends to the starter. Starter is a bitch to get to, I really hope I'm wrong on the starter side. If it's just the connector, just upgrade the connector and move on.
  3. Sep 5, 2023 at 7:55 AM
    Remove the cover from the fuse box. If I recall, the cable is bolted to a terminal strip. I don't see it in the diagrams at Sparks, so you may have to take it to the dealer for a part number.
  4. Sep 5, 2023 at 7:58 AM
    This is what it looks line on the 2.5 gens......attached with a nut onto the stud.
  5. Sep 5, 2023 at 8:11 AM
    Cmaccullen
    2022 Tundra Limited
    See the black cable running perpendicular to the red cable? That is the cable that goes into the fuse box and that's the cable I need to replace. It appears to go under the fuse box and I am not sure where it goes after that. Thank you everyone!
