Skid plate for 2.5 gen tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Psv, Aug 31, 2023.
  1. Aug 31, 2023 at 8:29 AM
    Psv
    Psv [OP] New Member
    Chicago
    2019 Tundra Sr5
    Did anyone have any good luck with a skid plate offered for sale on Amazon? It's offered for sale by HECASA at much cheaper price than oem toyota trd skid. No reviews on it yet on Amazon so I'm a little hesitant to pull the trigger on it
  2. Aug 31, 2023 at 8:31 AM
  3. Aug 31, 2023 at 8:52 AM
    Psv
    Psv [OP] New Member
    Chicago
    2019 Tundra Sr5
  4. Aug 31, 2023 at 9:36 AM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    No experience with it, but I wouldn't do it. As painful as it is to spend the money for a proven one like RCI or the others, you get what you pay for.
    If you're just getting one for looks, go for it and let us know how it is. If you want actual protection and what it's designed for, spend once and cry once.
    Tundra234 and BravoDeltaRomeo like this.
  5. Aug 31, 2023 at 9:57 AM
    Psv
    Psv [OP] New Member
    Chicago
    2019 Tundra Sr5
    It's more for looks and oil filter access than anything else. I was hoping that it would do the trick for what I intend to use it for. I have the valhalla cat plates already in the rear and taking the original splash shield off every 5k miles is a little bit more time consuming since i change the oil filter every time
  6. Aug 31, 2023 at 10:26 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    RCI for the win.
    Tundra234 likes this.
  7. Aug 31, 2023 at 11:03 AM
    Skaufma0
    Rock Hill, SC
    2018 MBM Limited CM
    Yeah if it's just for looks then give it a shot. Looks like a knock-off TRD skid plate.
    The RCI in 10ga steel and powder coated is only a little over 100 bucks more though.
  8. Aug 31, 2023 at 2:09 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Do it! do it! do it! I'm curious too!
  9. Aug 31, 2023 at 2:24 PM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I was in the same boat a while back, I saw the diy mods to add doors or cutouts to the thin stock skid plate and considered that, looked at the trd skid plate, and the RCI. Ultimately decided to go with an aluminum 1/4 RCI skid plate for the winter salt conditions here in northern IL and the fact that it will clear larger tires.
    The RCI skid plate bolts up great with the cat shields
  10. Aug 31, 2023 at 2:28 PM
    2mchfun
    You really should not block the view of everything with a skid plate during oil changes. I'd buy it, but also drop it for proper maintenance. That said, I only change the oil in the fall and spring so I would not be hot or cold while wrenching. Sometimes the TRD version pops up on craigslist or marketplace for about the same price too.
    Gene_in_FL likes this.
  11. Aug 31, 2023 at 8:48 PM
    seydou
    seydou Distinguished Member
    The "looks" of a skid plate? I will never undestand that, along with a couple dozen other aesthetic things people do to their trucks. Who the fucj is going to see or notice your skid plate? Virtually no one. And you won't either unless you are outside of your truck and bent over.
    Spend the bucks and get a well made plate. Or don't and just waste your money.
    timlovestacos and HulkSmurf14 like this.
  12. Sep 2, 2023 at 5:51 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Will those bolt up to an SR5?
  13. Sep 2, 2023 at 6:13 AM
    HulkSmurf14
    2014 Tundra Limited
    Yes they will!! So as long as you're rocking the 5.7!
    2mchfun and Gene_in_FL like this.
  14. Sep 2, 2023 at 6:15 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    HulkSmurf14 likes this.
  15. Sep 2, 2023 at 6:35 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    If I remember correctly, a lot of folks have to repaint these. So get the raw and coat them yourselves. I forget what product folks were swearing by. I'm sure someone will chime in.
  16. Sep 2, 2023 at 6:59 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Yes
    Gene_in_FL[QUOTED] and 2mchfun like this.
  17. Sep 2, 2023 at 8:25 AM
    Probably Raptor liner is what you are referring to. I'm in FL and have had my RCI for almost 3 years and no issue with the powdercoat.
    1UP[QUOTED] likes this.
  18. Sep 5, 2023 at 7:19 AM
    TundraMidwesterner
    Northern Illinois
    I think a lot of people prefer to diy paint skid plates if they are actually going to use them as skid plates so they can do touch ups at home with a rattle can, same with sliders. Steel is easier to reform but with OP and my winter weather in northern IL and the salty roads, aluminum is going to be the better bet unless this is going to be built up as a trail rig.
  19. Sep 5, 2023 at 7:27 AM
    Talon2006
    Talon2006 New Member Vendor
    jeffw6236 likes this.
  20. Sep 5, 2023 at 7:51 AM
    Psv
    Psv [OP] New Member
    Chicago
    2019 Tundra Sr5
    I was considering talon skid but not sure if it would work with valhalla cat shields. I already have them on my truck and was looking to get an aluminum skid. I know rci is a good option
  21. Sep 5, 2023 at 12:48 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I’d bet the talon shield would mate easily to the valhala shield.
    Very similar design.
