The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    26.9%
  2. Alpine ILX-F509
    4 vote(s)
    3.1%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.3%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.5%
  7. No - I was late to the party
    54 vote(s)
    41.5%
  8. No - I didn't need a new head unit
    19 vote(s)
    14.6%
Multiple votes are allowed.
  1. Sep 2, 2023 at 6:22 PM
    #301
    AZTundra
    Paul
    Phoenix, AZ
    Here is a link to the bracket that I used. The rear camera does not come with a bracket, just some 3M double sided tape to stick it somewhere.
    Custom Folded Metal Weatherstrip Bracket for Dash Cam Lens (thedashcamstore.com)
    I went with black to match the weather seal and the short length (1.0").
  2. Sep 2, 2023 at 10:08 PM
    #302
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I noticed the Kenwood doesn't talk to my TPMS sensors but the rest of the ODBII info comes through. Think it might just be a 2016 thing tho
  3. Sep 3, 2023 at 6:03 AM
    #303
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Confirmed this morning; this adapter does work to use the factory gps antenna. I have sworn a blood oath to never again take this dash apart to access the stereo until I remove it. Thanks for researching and posting this adapter- I always prefer to keep factory connections when possible
  4. Sep 3, 2023 at 9:05 AM
    #304
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    I can also confirm that there's 2 (at least in mine) antenna connectors that resemble each other for the GPS and SiriusXM antennas. I had the SXM transmitter plugged in to the white connector (GPS) that went to the left of the dash and it wouldn't work. I about gave up and was going to use the supplied SXM antenna when I finally found the other connector (which is black) nestled among the birds nest of wires to the right of the dash. Hope this helps.
    TRDFerguson and bulldog93 like this.
  5. Sep 3, 2023 at 12:03 PM
    #305
    MedCityMoto
    Ah yes, I had posted about that earlier in the other thread! White's GPS, Black's SXM.
  6. Sep 3, 2023 at 7:17 PM
    #306
    TaquitoBandito
    Joel (AKA Bif)
  7. Sep 3, 2023 at 8:32 PM
    #307
    spiritr
    spiritr New Member
    TPMS comes through in my 2016 on the Alpine
  8. Sep 3, 2023 at 8:59 PM
    #308
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Same with my 2014
  9. Sep 3, 2023 at 9:10 PM
    #309
    MedCityMoto
    Huh. Well I'll look into it more after my new tires and tpms sensors all go on next week!
    RainMan_PNW[OP] likes this.
  10. Sep 4, 2023 at 8:58 AM
    #310
    AZBoatHauler
    So.Arizona
    Can’t get my front camera to get me a picture, just a black screen. Worked on the Kenwood HU I just replaced and all I did was swap the yellow video feed to the new plug. Didn’t mess with 12v power to the camera :notsure:
    bulldog93 likes this.
  11. Sep 4, 2023 at 9:11 AM
    #311
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    what plug did you use on the back of the alpine?
  12. Sep 4, 2023 at 9:18 AM
    #312
    AZBoatHauler
    So.Arizona
    A crutchfield adapter on the front camera input.
  13. Sep 4, 2023 at 9:19 AM
    #313
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    photo?
  14. Sep 4, 2023 at 9:19 AM
    #314
    AZBoatHauler
    So.Arizona
    Incoming. I know it isn’t the adapter because if I plug in the feed from my rear camera I get a picture.
    ToyoMafia likes this.
  15. Sep 4, 2023 at 9:23 AM
    #315
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    sweet…no need for photo then…
    what and where is the power source for the front cam?
  16. Sep 4, 2023 at 9:24 AM
    #316
    AZBoatHauler
    So.Arizona
    Middle pic is front camera bottom is when I flip tot the rear video feed.
  17. Sep 4, 2023 at 9:25 AM
    #317
    AZBoatHauler
    So.Arizona
    I tapped the 12v outlet under the HVAC control. Confirmed that has power.
  18. Sep 4, 2023 at 9:30 AM
    #318
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    what about your ground ?
  19. Sep 4, 2023 at 9:38 AM
    #319
    AZBoatHauler
    So.Arizona
    Same source. That 12v out is working fine. I’m stumped.
  20. Sep 4, 2023 at 9:41 AM
    #320
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Lol if you double checked power and ground, that is tied to cig outlets….have you cycled key off, removed key and then cycled key on?
  21. Sep 4, 2023 at 9:42 AM
    #321
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I don't remember having to activate the front cam input in the settings like you need to do with the backup cam... Let me go poke real quick. Only thing I can think of is maybe a pin is bent where the harness plugs into the HU? Or not seated fully?
    ToyoMafia and BiggHertz like this.
  22. Sep 4, 2023 at 9:54 AM
    #322
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What front camera is it?
  23. Sep 4, 2023 at 10:02 AM
    #323
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Your settings look like this?
    bulldog93, BiggHertz and ToyoMafia like this.
  24. Sep 4, 2023 at 10:19 AM
    #324
    AZBoatHauler
    So.Arizona
    Three hail Mary’s to a couple profanity rants too - still nothing.
    bulldog93 and FrenchToasty like this.
  25. Sep 4, 2023 at 10:20 AM
    #325
    AZBoatHauler
    So.Arizona
    Yep.
  26. Sep 4, 2023 at 10:21 AM
    #326
    AZBoatHauler
    So.Arizona
    NATIKA Backup/Front View Camera: No Distorted Affect Starlight Night Vision HD Waterproof 960H CVBS/720P AHD Hitch Backup/Reverse/Rear Camera License Plate for Cars Pickup Trucks SUV RV Van
    Backup Rear | Front View Camera:... https://www.amazon.com/dp/B09BFBCPB8?ref=ppx_pop_mob_ap_share
  27. Sep 4, 2023 at 10:24 AM
    #327
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you put the backup cam feed on the front cam input do you get anything? That one might be tough as I think the camera only gets power when in reverse and would trigger the backup camera input…
  28. Sep 4, 2023 at 10:25 AM
    #328
    AZBoatHauler
    So.Arizona
    The rest of the story - I had a prior camera (same brand / model) that died. Replaced it but the wiring harness had slightly changed adding a ground. I was somehow able to splice harnesses to make them work on the Kenwood so I don’t have to pull another video cable through the firewall. Maybe the Alpine doesn’t like the wiring situation since it’s custom. Just weird the Kenwood worked fine for 3 years…
    TRDFerguson and ToyoMafia like this.
  29. Sep 4, 2023 at 10:26 AM
    #329
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Can you hook it up around the outside just to test the brand new cable?
  30. Sep 4, 2023 at 10:42 AM
    #330
    AZBoatHauler
    So.Arizona
    The rear camera kicking on when swapped proves everything new works. I’m convinced it’s the camera or the mix/match wiring harnesses causing an issue. I’m ready to turn off the front camera option button it up And wait for cooler weather to run a new wire/camera.
