Home Made Cat-Back
Discussion in '3rd Gen Tundras (2022+)' started by Hadelson, Sep 2, 2023.
  1. Sep 2, 2023 at 5:26 PM
    Hadelson
    Hadelson [OP] New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    I've had many different CAT-BACK systems. Learned one key point. It's a V-6 and not going to have the V-8 sound. Moving past this, decided to build my own.
    1. Using same diameter pipes
    2. Borla Universal Resonator # 401339 just after Y-Pipe
    3. Magnaflow set into Magna Flow Universal Offset #12589
    4. Took Helmholtz Tube from Dirty Deed and installed on TRD Tale Pipe Section.
    IMO opinion, best sound yet. Better Throttle response, No NVH/resonation. Slight noise increase normal throttle and under heavy throttle, you definitely know it's there. Cabin Noise-none-Wife didn't even notice it.
    Pictures attached.
    Yaboy, Warreng, 22whatwedo and 3 others like this.
  2. Sep 2, 2023 at 5:37 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    We need to hear it!
    Durtywrench and Blufin like this.
  3. Sep 2, 2023 at 6:04 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    thought about similar - using the MagnaFlow universal but putting the oem resonator from the tail pipe section behind the magnaflow muffler (took the oem tail pipe off and put on the TRD Dual). How did much effort was the mandrel work for the section connecting into the rear flange? Picks of it? Sound clips please.
    pwpblue likes this.
  4. Sep 3, 2023 at 5:34 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Definitely need a sound bite....
    I got inpatient, before my truck arrived I purchased Magna Flow Street series cat back that was night and day difference.
  5. Sep 3, 2023 at 5:49 AM
    Hadelson
    I will do some recordings today and post tonight :)
    303Gen3 and Blufin like this.
  6. Sep 3, 2023 at 6:49 AM
    303Gen3
    Golden Colorado
    I've seen this on the web - Sound clip would be nice. Does this have the resonator behind the muffler or only the muffler? dimensions of the muffler (4x9 or 5x11)? would be nice too along with install pics too. TIA.
  7. Sep 3, 2023 at 7:32 AM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    Like mentioned above I’d like to hear some clips too . Everything that I’ve seen being made sounds stupid and way over priced . It’s a v6 and won’t sound right regardless .it just blows my mind to spend a 1000 on something that reminds me of a ricer
  8. Sep 3, 2023 at 9:35 AM
    Breathing Borla
    Northern Illinois
    you ever think about dyno testing to see what it does ? I guess it’s too late maybe since stock base wasn’t done
    The best one I’ve heard so far was Keith’s system , let’s hear a sound clip
  9. Sep 3, 2023 at 11:17 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    We need sound clips gents!!
  10. Sep 3, 2023 at 3:37 PM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    No resonator just piped off of each cat to Y pipe then to the muffler,then single exit that extends over the rear end then Y's off to duels single side (drivers side).
    *Note the OEM muffler weighed 16.5 pounds more,so just a FYI.
    I too am aware It's not an V8 just a 6 banger with a good set of balls and overall more than pleased with it just wanted to modify the exhaust and found the Magna flow had the best sound for sure.
    When playing sound bites on a phone,computer or a TV all have different speakers so on and so forth it's not a bad reference point but actually hearing it in person will seal the deal,well it did for me that's why I bought it before my truck arrived.
    303Gen3[QUOTED] likes this.
  11. Sep 4, 2023 at 6:45 AM
    303Gen3
    Golden Colorado
    Thanks for the information and pics! Sharp looking Truck - nice taste on mods!
  12. Sep 4, 2023 at 6:55 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So what about fuel efficiency - did it improve around town and/or highway? (I mean that is the real purpose of all this, right?)
  13. Sep 4, 2023 at 7:04 AM
    Breathing Borla
    Northern Illinois
    There isn’t much of a purpose at all besides sound exhaust note change
    1lowlife and 303Gen3 like this.
  14. Sep 4, 2023 at 8:43 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Definitely not for fuel economy for sure and as mentioned it's purely for acoustics and personal preference,maybe a very slight HP increase (slight if any) just like for drop in's or CAI with out additional modifications such as charge pipes and tuning there won't be much gains.
    Thanks 303Gen3 for the props on my Rig it's been fun for sure getting done what I want done as you know the list continues to grow.
  15. Sep 4, 2023 at 10:01 AM
    Breathing Borla
    Northern Illinois
    you have to be careful you don’t lose low end torque as well , that happens often and then you gain 3-5 hp up top, but who cares about that , low end grunt rules in trucks
  16. Sep 4, 2023 at 10:49 AM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Looks good! Be careful with getting water in that resonator. I had the same one from dirty deeds and got water in it. The tone definitely changed when there was more water in the resonator. I drilled a small but probably too large of a hole. That created a bit of noise. So I put on a band clamp with a little rubber to block it.
