Front Bilstein 5100 ordered
Discussion in 'Suspension' started by ShawnTRD, Sep 2, 2023.
  1. Sep 2, 2023 at 11:21 AM
    ShawnTRD
    ShawnTRD [OP] New Member
    Shawn
    Going to have these installed in a week or two. I'll have them set on the top notch. They are going on my 2020 with 55k miles. Should I need anything else? I would think the shock mounts should still be good. Will have the alignment done at the same time.
  2. Sep 2, 2023 at 12:36 PM
    Cement20
    Cement20 New Member
    Landon
    SL,Ut
    2020 Cement Tundra Crewmax Sr5
    -ThrashedOffroad Send-It Suspension -ThrashedOffroad Billet UCA -ThrashedOffroad 6 switch pod -ICON stage 2 leaf springs -Coachbuilder 1” shackles -TimbrenIndustries Bump stops -RocktrixWheels 18x9 RT111 Teardrop matte black wheels -NittoTire 35x12.50r18 RidgeGrapplers -Ironman4x4 RAID Front bumper -Diodedynamics fog,bumper,ditch,chase and rock lights, interior LED Swap -RCIOffroad engine, transmission and cat skid plates -SbFilters Cold air intake -Victory4x4 bed mount Molle -Katzkin Graphite leather -ESPtruck plastic CrewMax storage compartment -ScreenProtech interior screen guards -Tufskin raised 3D Solar octane lettering -JamHandle door assist in orange -Unfocused Offroad Safety orange lighting bumpers
    I ran these for roughly 20k miles. I had the coachbuilder 1” shackles installed at the same time. Just my 2 cents.
  3. Sep 2, 2023 at 12:46 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    As @Cement20 stated I installed Toytec shackles on the 1" setting after my 6112 install.
    5100 on the top setting will have your truck sitting pretty level.
    I had some nanny issues (engine cutting out) on sharp turns so I lifted the rear a little to get some rake back..
    Before rear shackles
    763B91DF-899D-4443-A7EC-B9CE39DA5452_zps_d6996a7c4c346b193c23d63e1851495611ed574d.jpg
    With rear shackles
    91CBAE5D-765D-497E-9830-48F25491821C_zps_fdcb079688fb81d770612c4ff5ed52cb01e5339e.jpg
    Good luck.
  4. Sep 2, 2023 at 12:59 PM
    ShawnTRD
    Shawn
    The engine was cutting out because you were level? Why do you think that was it? Do other people have this problem?
  5. Sep 2, 2023 at 1:10 PM
    biebs96
    PA
    he means the traction control would kick in much easier.
    1lowlife likes this.
  6. Sep 2, 2023 at 1:11 PM
    biebs96
    PA
    My 5100s are set on the middle setting and I felt the truck was dead level. I ended up lifting the rear 1” after a week because I missed the rake.
    Tundrastruck91 and 1lowlife like this.
  7. Sep 2, 2023 at 1:19 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    At least in my 2014, there is a yaw rate sensor sensor under the console that monitors truck roll.
    On fast turns, that's how I drive, it would decrease the engine output (or hit the brakes I can't remember) when it sensed too much roll.
    Probably part of the Vehicle Stability Control system.
    There is a mod somewhere to stick a washer under the rear of it and make it think the truck still had the stock rake.
    I'd drive your truck for a while if you like the level look.
    You might not even experience the issue I had..:thumbsup:
    ShawnTRD[QUOTED][OP] likes this.
  8. Sep 2, 2023 at 1:20 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    ^ What he said..:D
    biebs96[QUOTED] likes this.
  9. Sep 2, 2023 at 1:30 PM
    biebs96
    PA
    Apparently it’s to help avoid loosing control when loaded.
  10. Sep 2, 2023 at 1:36 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    When loaded? :confused:
    The truck or the driver? :cheers:
  11. Sep 2, 2023 at 1:39 PM
    biebs96
    PA
    How about both.. I drive a loaded truck everyday :anonymous:
  12. Sep 2, 2023 at 1:42 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Yes, you do, probably bulkhead door to back door with no daylight coming through until you hit the bulk stops.
    Oh yes, I remember those days...
  13. Sep 2, 2023 at 5:44 PM
    ShawnTRD
    Shawn
    Can the safety sensors be recalibrated for the new frontend ride height?
  14. Sep 2, 2023 at 5:52 PM
    biebs96
    PA
    yes. About 873 members have installed a lift with no issues.
  15. Sep 2, 2023 at 7:16 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I look to put in 5100s fronts in 2 weeks and hope to minimize lift and keep stock height, looks like the lowest setting for me!
    Tundrastruck91 likes this.
  16. Sep 2, 2023 at 7:23 PM
    ShawnTRD
    Shawn
    Then should save some money and stick with the 4600's
  17. Sep 2, 2023 at 7:59 PM
    MedCityMoto
    Nah.
