1.25in spacers
Discussion in 'Wheels & Tires' started by Abdul98, Jan 23, 2021.
  1. Aug 23, 2023 at 6:27 PM
    #61
    WiscoWalleye
    WiscoWalleye New Member
    How did you fix the sway bar issue. I rub on the passenger side sway bar only at full lock. But it’s not much.
  2. Aug 31, 2023 at 1:50 AM
    #62
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
    .75 !?!?! I want those! Did you have to trim the studs?
    Badknees[QUOTED] likes this.
  3. Aug 31, 2023 at 5:47 AM
    #63
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Rock Warrior wheels with Bora 1.25 spacers
  4. Sep 1, 2023 at 11:47 AM
    #64
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    The studs protrude about 1/8" beyond the spacers on the rear. No need to trim if you run stock wheels or others with the "pockets" between the mount holes. Edit - my spacers are 1.0" and not 0.75" Bora Wheel Spacer 1.jpg
    AggiePhil, Drootz and WFD473 like this.
  5. Sep 1, 2023 at 3:25 PM
    #65
    Drootz
    Drootz Beer me!
    NorCal
    2021 Tundra MGM Platinum 4x4
    TRDPro Fox Suspension, TRD Black Chrome Exhaust, TRD Pro Wheels, TRD Skid Plate, TRD Rear Sway Bar, TRD Air Filter, TRD Flow accelerator, Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added, TRD Shift knob, Remote Tailgate Lock, TRD Parts Added: Fox Suspension, Black Chrome Exhaust, BBS Pro Wheels, Skid Plate, Rear Sway Bar, Air Filter, Flow accelerator, & Shift Knob Other additions: Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added. Wanted list: Color matched exterior handles
    I really like the look of your truck above and I have a Platinum with TRD PRO Suspension and TRD PRO Wheels also.
    I am curious though do you only have the .75 spacers in the front or where you able to fit them in back as well? I have seen it mentioned that the back wheels won't fit the .75" spacers and need something slightly bigger.
    I also noticed your profile lists them as 1" bora spacers and since I like the look with the 295/70 you have on there I want to make sure I get the right size spacers and wanted to confirm if they are .75 all around. Thanks
  6. Sep 1, 2023 at 6:40 PM
    #66
    Badknees
    Badknees New Member
    Sorry, I was in a hurry and had a brain fart - I blame old age. My spacers are 1.0" and not 0.75". I remember the 0.75" spacers would require some stud trimming. I have the 1.0" spacers mounted on the front and rear. The studs do protrude about 1/8" on the rear spacers.
    Drootz[QUOTED] likes this.
