The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    26.9%
  2. Alpine ILX-F509
    4 vote(s)
    3.1%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.3%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.5%
  7. No - I was late to the party
    54 vote(s)
    41.5%
  8. No - I didn't need a new head unit
    19 vote(s)
    14.6%
Multiple votes are allowed.
  1. Aug 31, 2023 at 6:05 PM
    #271
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If he’s non-JBL there’s already a turn on lead at the factory amp. Otherwise, absolutely yes.
  2. Aug 31, 2023 at 6:08 PM
    #272
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
  3. Aug 31, 2023 at 6:11 PM
    #273
    Azblue
    The Dirty T ( ^_^)_且
    I was going to run a turn on wire when I route my RCAs because I'm currently using auto turn on through speaker level to my current Alpine amp, bur I was just thinking that since I'm using the stock connectors at the amp location, I should be able to just re-pin the amp turn on in the stock connector (I think I actually kept the wires when I de-pinned for the aftermarket amp). That being said, it may just be easier to tape a wire to the RCAs and pull that under the carpet along with them.
  4. Aug 31, 2023 at 6:12 PM
    #274
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    It is a non JBL.
    TRDFerguson[QUOTED] likes this.
  5. Aug 31, 2023 at 6:14 PM
    #275
    RainMan_PNW
    Casey
    Clark County, WA
    There’s a version of the non-JBL that still has an amp under the passenger front seat
    TRDFerguson likes this.
  6. Aug 31, 2023 at 6:17 PM
    #276
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s what I was getting at - it’s pretty rare to see any without an amp at all. I can’t remember which Entune level came without it, but I’m pretty sure most SR5 had the amp.
  7. Aug 31, 2023 at 6:22 PM
    #277
    RainMan_PNW
    Casey
    Clark County, WA
    Probably the SR trim and maybe some bone stock SR5’s
  8. Aug 31, 2023 at 6:26 PM
    #278
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    I have an amp. So it is ok to plug the rcas in to the head unit and run the turn on wire and just leave them not plugged to anything? I can just leave it all under the console for now if that works.
  9. Aug 31, 2023 at 6:29 PM
    #279
    RainMan_PNW
    Casey
    Clark County, WA
    Cap or otherwise cover the ends of them, but yeah. You should be able to disable the amp preouts in the HU settings (should be default) until you need them
    TaquitoBandito and ebpgh[QUOTED] like this.
  10. Aug 31, 2023 at 7:29 PM
    #280
    TaquitoBandito
    Joel (AKA Bif)
    Somebody mentioned an Enfig Mic to put in the OEM location. I'm going to order one for my 4Runner but they only seem to offer it for that vehicle and the Taco. If whomever bought one and if it worked, can you let me know? I'm trying to save on shipping. :)
  11. Aug 31, 2023 at 7:38 PM
    #281
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have it but have not installed it yet. They said it would fit my '13 Sequoia.
  12. Aug 31, 2023 at 7:44 PM
    #282
    TaquitoBandito
    Joel (AKA Bif)
    I wrote them but have heard nothing. I'll try to call them tomorrow.
  13. Aug 31, 2023 at 8:00 PM
    #283
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  14. Aug 31, 2023 at 8:04 PM
    #284
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Finger painting....almost like someone drew this out somewhere....
    If utilizing the Maestro PnP harness w/ "ACC-HU-ALP1"....
  15. Aug 31, 2023 at 9:05 PM
    #285
    RainMan_PNW
    Casey
    Clark County, WA
    Looking at it, it should fit in the spot where the mic is up through 2018 (or 19) in the overhead console. The 20/21 (and maybe 19) had the mic above the driver’s head in a separate grill in the headliner but they left the old opening in the center console.
    I just ordered one to test it out.
  16. Sep 1, 2023 at 1:32 PM
    #286
    jomikepa
    jomikepa New Member
    O-H-I-O
    21 black truck
    I've been going thru these threads and trying to clear things up. I currently have an appt next week to get the Apline 509 installed by BestBuy, using the Metra harness. If I don't use the Maestro RR Module, am I just going to be missing the vehicle guages and settings? I'm okay without that stuff, I'm just looking to make sure I retain all the stuff I currently have...steering wheel controls, USBs, ect. I have a '21 SR5. Thx for any help, this crap is mega confusing to me.
    Here are the 4 parts that BB is installing: Metra dash kit, Metra harness, Metra antenna adapter, Metra camera harness.
  17. Sep 1, 2023 at 2:26 PM
    #287
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    You'll lose the steering wheel controls without the Maestro I believe. No need for the Maestro RR2 unless you really want the Bluetooth, regular RR saves you some coin and takes a single USB cable flash to make work properly. I regret spending the extra on my RR2 Bluetooth because their app was pure junk and I ended up using a hard-line USB anyway, which did admittedly work wonderfully.
  18. Sep 2, 2023 at 11:15 AM
    #288
    Azblue
    It has begun! :eek2:
  19. Sep 2, 2023 at 11:22 AM
    #289
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Azblue[QUOTED] likes this.
  20. Sep 2, 2023 at 11:34 AM
    #290
    AZTundra
    Paul
    Phoenix, AZ
    Began my install as well about an hour ago. @TRDFerguson how does the overhead console come down? I removed the two small screws and the console moves a bit but I can seem to figure out what else is holding it up.
    So far everything has been removed. Installed the usb/hdmi port and the rear dash cam. Working on the front dash cam and microphone now and then will start to connect everything up in the dash last.
  21. Sep 2, 2023 at 12:01 PM
    #291
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    2 screws in sun glass pocket and than 2 screws behind the sunroof switch/useless paper holder insert you need to pop out…
  22. Sep 2, 2023 at 12:13 PM
    #292
    AZTundra
    Paul
    Phoenix, AZ
    Thanks! Got it out and onto the mic install now.
  23. Sep 2, 2023 at 12:21 PM
    #293
    TaquitoBandito
    Joel (AKA Bif)
    I don’t believe you - I see no beer, just your urine bottle.
  24. Sep 2, 2023 at 12:23 PM
    #294
    TaquitoBandito
    Joel (AKA Bif)
    Did the rear camera come with the bracket? I ordered one off of eBay but it won’t be here until next week.
    AZTundra[QUOTED] likes this.
  25. Sep 2, 2023 at 12:26 PM
    #295
    AZTundra
    Paul
    Phoenix, AZ
    No, it doesn't come with a bracket. I brought one from the dashcam store. I'll grab the part number for you shortly. It's a generic bracket, but it works well without any modification. There are two lengths, I went with the short one which was perfect.
  26. Sep 2, 2023 at 12:36 PM
    #296
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    as far as my experience with reinstalling the upper panel. I pull the from the truck, reattach them to the overhead console and then just pop it back in to the truck…
    TaquitoBandito likes this.
  27. Sep 2, 2023 at 3:45 PM
    #297
    AZTundra
    Paul
    Phoenix, AZ
    Well, I quit for today due to running out of time. I did get all of the wiring run up to the dash so hopefully not more than an hour to finish it up later. I installed the rear dash camera and ran the wires up to the head unit. The Alpine microphone is installed in the factory location thanks to the idea from @TRDFerguson. The front dash camera is mounted and the wiring for that along with the microphone was run under the headliner and down the A pilar, then under the dash and over to the radio opening. I removed the FRAC harness since it will no longer be needed. The USB/HDMI outlet was installed as well. All that I need to do now is plug everything back in, but I still need to crimp the terminals on for the dash cam harness and wire up the bypass. I need to look up the wiring for the front camera also. I believe the red wire coming off the RCA plug will now just be connected to the 12V accessory wire to power it up since the FRAC harness is no longer being used.
    Couple more pics.
  28. Sep 2, 2023 at 4:12 PM
    #298
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
  29. Sep 2, 2023 at 5:52 PM
    #299
    Azblue
    Ho Lee Fuk, that was a PITA. Been at it all day and that's way too long. Thing that held me up the most was finding space to run 3 sets of RCAs, there is 0 room in the dash. Took me a few hours (with beer breaks) and I tore most of the dash apart to no avail finally I remembered that little panel above the glove box, popped it off and a clear shot to behind the radio. I still have some trim pieces that don't want to cooperate, but I'll fuck with them tomorrow. In the end, I still need to reinstall my amp, put the seat back, finish running a couple of wires, do the settings. put the rest of the dash and trim back on, put tools away and button up details. BTW, shoving all that shit up there (hehe) sucks, wires and modules everywhere with little room.
    So, in the end, it's in, the truck didn't catch on fire, and I still have more to do. But for now, I'm beat, need a shower (still fucking hot in the garage) and am going to drink many more beers and watch the U of A's season opener.
    20230902_171830.jpg 20230902_171903.jpg 20230902_172416.jpg 20230902_172427.jpg
  30. Sep 2, 2023 at 5:56 PM
    #300
    32 psi? What a heathen!
