TRD wheel caps peeling.
Discussion in '3rd Gen Tundras (2022+)' started by Tundraaa3, Sep 1, 2023.
  1. Sep 1, 2023 at 7:10 AM
    Tundraaa3
    Tundraaa3 [OP] New Member
    Peeling on all four TRD wheel caps...
    Opinions of what could cause this and how do you get these caps off?
  2. Sep 1, 2023 at 7:19 AM
    Breathing Borla
    Northern Illinois
    Do you pressure wash your truck and if so how much psi?
    these are cheap to replace at least
  3. Sep 1, 2023 at 7:38 AM
    Tundraaa3
    No pressure washer, it's just peeling on the outside ring. Where do you order the caps from?
  4. Sep 1, 2023 at 7:40 AM
    Breathing Borla
    Northern Illinois
    i got mine right from Toyota parts online at my local dealer
  5. Sep 1, 2023 at 7:48 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Damn, that is some high curbs...:eek2::boink:
  6. Sep 1, 2023 at 8:10 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    You can see where it's "rubbed" in the first pic. That isn't just paint peeling off or a defect.
    Breathing Borla likes this.
  7. Sep 1, 2023 at 8:13 AM
    Tundraaa3
    The rim pokes out further than the center cap and they have zero scratches. All of them are peeling, how would I rub all four?
  8. Sep 1, 2023 at 8:14 AM
    Tundraaa3
    How do you pop them off?
  9. Sep 1, 2023 at 8:14 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I'm not sure, but if you look where the paint is removed, there is significant scuffing and marks. Your lugs are scuffed too.
    Something is rubbing them, it's not just paint falling off.
    Automatic Car wash? May be time to change your reply in that thread. ;)
    Have you gone through a carwash yet?
  10. Sep 1, 2023 at 8:19 AM
    Tundraaa3
    All four of them are like that and the rim pokes out further than the center caps, I have no clue what's going on with them.
  11. Sep 1, 2023 at 8:20 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    They just pop right out. Take the wheel off and pop them out from the inside. You could also use a pick to pull them off from the outside but will probably scratch the wheel in the process.
  12. Sep 1, 2023 at 8:21 AM
    Tundraaa3
    My lug nuts are just dirty, they aren't scratched at all.
  13. Sep 1, 2023 at 8:27 AM
    Tundraaa3
    Thank you
  14. Sep 1, 2023 at 8:59 AM
    Tundraaa3
    I'm going to the carwash to investigate. I just don't understand what would even rub them, nothing grabs the tire or rim.
  15. Oct 12, 2023 at 2:30 PM
    Tundraaa3
    Forgot to update you on this. They chipped and peeled from my brakes getting to hot. It was caused by using the ACC on a two hour road trip and apparently it uses the brakes too much.
