S.o.b fabrication “High clearance rear bumper”
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mrf1987, Apr 19, 2022.
  1. May 22, 2023 at 4:52 PM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    definitely the best high clearance rear bumper I’ve come across. What tool did you use to cut the bed? I see alot of people using an angle grinder, but a die grinder with a cut off wheel seems like a better tool to use
    CaptRussia253 likes this.
  2. May 22, 2023 at 4:54 PM
    Mrf1987
    Mrf1987 [OP] New Member
    2020 Trd sport tundra
    I used an angle grinder with a cutoff wheel. The larger wheel helps keep a strait line.
  3. Aug 31, 2023 at 6:54 PM
    Marshen
    Marshen New Member
    Blake
    ‘16 Tundra
    I have one of these bumpers coming in November. Did you get any kind of template to help with cutting?
  4. Aug 31, 2023 at 7:01 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    CaptRussia253 and FrenchToasty like this.
  5. Aug 31, 2023 at 8:54 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Measure 3+ times based off @STravis instructions and you’ll be good. Take your time. Cut slow as the paint will start to get hot and bubble. Be careful with the harness routed behind the fender on both side(I clipped mine on the passenger side). Enjoy some beers afterwards.
  6. Sep 1, 2023 at 8:37 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Is there any way to still run a hitch with this? Looks great.
    STravis and CaptRussia253 like this.
  7. Sep 1, 2023 at 8:45 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Captainrussia still has a hitch and tows.
  8. Sep 1, 2023 at 9:55 AM
    CaptRussia253
    Ruslan
    It’s a hidden hitch behind the license plate. @STravis did a badass job engineering this bumper!
    Talon7, equin, n0rth and 6 others like this.
  9. Sep 1, 2023 at 10:03 AM
    AZBoatHauler
    So.Arizona
    @STravis - what’s the cost and lead time?
  10. Sep 1, 2023 at 10:15 AM
    CaptRussia253
    Ruslan
    I waiting around 10 weeks I think. Well worth the wait.
    AZBoatHauler[QUOTED] and STravis like this.
  11. Sep 1, 2023 at 10:21 AM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    The base bumper is $1,500, dual swingouts are $1,200 and tube bedside protection is $350.
    We're about 12 weeks out currently.
  12. Sep 1, 2023 at 10:23 AM
    CaptRussia253
    Ruslan
    That right there is a discount in my opinion. Best rear bumper out there for the second gens! All the gussets and extra supports welded on makes it robust. :curls:
  13. Sep 1, 2023 at 10:46 AM
    TOYOTARIG
    TOYOTARIG New Member
    Ron
    Albuquerque, NM
    Hey Travis, how about your front bumper what is pricing and lead time on it. Do you accept paypal?
  14. Sep 1, 2023 at 11:11 AM
    STravis
    Travis
    Ruidoso, NM
    We have two versions of our front bumper, a standard replacement and a high clearance. Which are you interested in? Lead time ~12 weeks. We do accept PayPal.
    PXL_20221027_222328485.PORTRAIT.jpg PXL_20221110_235122042.PORTRAIT.jpg PXL_20220826_180100883.PORTRAIT.jpg
    Talon7, chugs, n0rth and 3 others like this.
  15. Sep 1, 2023 at 11:20 AM
    CaptRussia253
    Ruslan
    The front is badass too!
    reywcms, Talon7, chugs and 3 others like this.
  16. Sep 1, 2023 at 11:37 AM
    TOYOTARIG
    Ron
    Albuquerque, NM
    They both look awesome. I assume the high clearance requires trimming the plastic below the headlights? What are the prices on both? Is lead time different for the different versions.
  17. Sep 1, 2023 at 11:44 AM
    STravis
    Travis
    Ruidoso, NM
    Lead times are the same. The high clearance does require trimming a little bit.
    The standard is $1,100 + 125-175 for the mid hoop depending on whether you want 1.75" or 2.25" tube.
    The HC is 1800 and comes standard with the grill guard.
  18. Sep 1, 2023 at 11:47 AM
    TOYOTARIG
    Ron
    Albuquerque, NM
    Is that in raw finish? Do you recommend powder coating or painting?
    STravis likes this.
  19. Sep 1, 2023 at 11:49 AM
    CaptRussia253
    Ruslan
    I did self etching primer and 3 coats of bed liner. It’s holding up well.
    TOYOTARIG[QUOTED] likes this.
  20. Sep 1, 2023 at 12:24 PM
    #50
    STravis
    Travis
    Ruidoso, NM
    It's raw. We don't ship anything powdercoated. I do recommend powdercoat when you receive it though.
  21. Sep 1, 2023 at 12:50 PM
    #51
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    :spending:@STravis in action disguised as a dirty hippy with power tools….
  22. Sep 1, 2023 at 1:47 PM
    #52
    AZBoatHauler
    So.Arizona
    @Incoleherent140 - you ready?
  23. Sep 1, 2023 at 2:04 PM
    #53
    TOYOTARIG
    Ron
    Albuquerque, NM
    I will drive down and pick it up, I am just north of you in ABQ. Do you have a recommendation on a powder coater?
  24. Sep 1, 2023 at 2:47 PM
    #54
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    Travis has a local powder coater, the guy does great work. If you’re picking up the bumper I would recommend using him and having Travis do the install. I’m sure Travis will chime in shortly. Travis and SOB fabrication have a booth at the New Mexico 4x4 rally the weekend of September 22-24 in Ruidoso if folks are interested in checking out his work.image.jpg
  25. Sep 1, 2023 at 3:42 PM
    #55
    TOYOTARIG
    Ron
    Albuquerque, NM
    Thank you!
    n0rth[QUOTED] likes this.
  26. Sep 1, 2023 at 3:56 PM
    #56
    CaptRussia253
    Ruslan
    Damn dirty hippies :rofl:
    STravis, n0rth[QUOTED] and TOYOTARIG like this.
  27. Sep 1, 2023 at 5:03 PM
    #57
    STravis
    Travis
    Ruidoso, NM
    Long hair doesn't make me a hippy! It's all gone now anyways! Haha.
    We have a guy down in Alamo that does a good job.
  28. Sep 1, 2023 at 5:25 PM
    #58
    CaptRussia253
    Ruslan
    That’s exactly what a closet hippy would say..
    n0rth and STravis[QUOTED] like this.
  29. Nov 24, 2023 at 1:44 PM
    #59
    AZBoatHauler
    So.Arizona
    Any Black Friday sales?
    :wave:
  30. Nov 24, 2023 at 3:04 PM
    #60
    STravis
    Travis
    Ruidoso, NM
    Hey man, we actually are this year.
