Will the Tundra be sufficient for this unit?
Discussion in '3rd Gen Tundras (2022+)' started by Welderdude80, Apr 15, 2023.
  1. Apr 15, 2023 at 3:33 PM
    Welderdude80
    Welderdude80 [OP] New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
  2. Apr 15, 2023 at 3:41 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Yes, nice looking camper. Make sure you have stabilizer bars and brakes hooked up on trailer. Be prepared to slow down ahead of time while towing.
    Welderdude80[OP] likes this.
  3. Apr 15, 2023 at 3:43 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    Just fine as long as you don’t over fill the trailer (and truck) with too much extra weight.
  4. Apr 15, 2023 at 3:46 PM
    Welderdude80
    JP
    Alberta
    working on it
    The thing I like about this trailer is the rear axle is positioned way back so it’s lighter in the front and axle are spaced out more to reduce sway like 42” apart.
  5. Apr 15, 2023 at 4:10 PM
    spigatelli
    spigatelli New Member
    DFW, Texas
    2023 Limited Hybrid CrewMax 6.5 in Army Green
    Yeah, the towing capacity on a new hybrid is like 11,000 lbs. The Hitch weight is the only concern, but I doubt it's terribly high. With a WDH, you'll be fine. My camper is about 6,000 lbs loaded and the hybrid pulls it up hills with no problems. My old 2018 4.6 Tundra struggled with hills.
    SWB Tundra and Welderdude80[OP] like this.
  6. Apr 16, 2023 at 3:49 AM
    kelbro
    kelbro New Member
    2021 1794 CrewMax 4x4 in Wind Chill Pearl
    2̶0̶2̶2̶ ̶1̶7̶9̶4̶ ̶C̶r̶e̶w̶ ̶M̶a̶x̶ ̶4̶x̶4̶ ̶w̶i̶t̶h̶ ̶A̶d̶v̶a̶n̶c̶e̶d̶ ̶P̶a̶c̶k̶a̶g̶e̶
    Should be no problem. At least I hope so :) I have a very similar setup (27' Keystone Elite) that I am currently towing easily with a 2021 Z71 Suburban. My Tundra should be here in a couple of weeks so we will soon find out. Weight distributing hitch and trailer brakes are a must. My only concern is that the Suburban has auto-leveling feature so I'm not sure how much the trailer will 'squat' the Tundra (if at all).
  7. Apr 16, 2023 at 4:07 AM
    wildmank99
    wildmank99 New Member
    Arizona
    22 Tundra Limited
    Here is my limited with the stock rear air. This is a 34ft older trailer that is 8600 and it towed it fine.
  8. Apr 16, 2023 at 4:23 AM
    Tosa
    Tosa New Member
    2014 Platinum Crewmax
    TT is within spec of what truck is rated for, should be good to go. A good weight distribution hitch makes a difference. I run a weigh safe true tow and have been happy with it.
    GMLtund-e69 likes this.
  9. Apr 16, 2023 at 4:27 AM
    kelbro
    kelbro New Member
    What do you mean by 'stock rear air'?
    Thanks
  10. Apr 16, 2023 at 5:50 AM
    RVer
    RVer New Member
    2023 Platinum CrewMax
    Just keep an eye on your payload numbers, it adds up quick for the Tundra. Go to a CAT scale if you can and get a measure of your front axle weight, rear axle weight, and your trailer weight. You may have to tweak your WDH. With the tongue weight and cargo it’s easy to overload the rear axle on the Tundra.
    UATundra and GODZILLA like this.
  11. Apr 16, 2023 at 6:08 AM
    wildmank99
    Arizona
    22 Tundra Limited
    It’s the stock rear air bags that come on the truck. I don’t have coils just air bags
  12. Apr 16, 2023 at 6:51 AM
    Welderdude80
    JP
    Alberta
    working on it
    Limited-time deal: K-Source 3891 Snap-On Towing Mirror With Ratchet Mount - Each https://a.co/d/hUDt4d5 That’s the next step after installing air bags I will definitely need these towing mirrors I know they’re ugly as sin but,,, easy to remove and install.
    Mattedfred likes this.
  13. Apr 16, 2023 at 6:54 AM
    kelbro
    kelbro New Member
    Thanks. Looking at the build sheet for mine (truck is still two weeks away), it doesn't look like it is coming with the air bags.
  14. Apr 16, 2023 at 8:11 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Should tow it just fine with a WDH. Our TT is only about 500# lighter than yours (5500# dry) and the Tundra tows it like a champ.
  15. Apr 16, 2023 at 10:21 AM
    kelbro
    kelbro New Member
    No air suspension?
  16. Apr 16, 2023 at 10:36 AM
    4genRunner
    Southwestern MO
    No air suspension. Truck rides and handles great when loaded up.
    Mattedfred and kelbro like this.
  17. Apr 16, 2023 at 10:48 AM
    kelbro
    kelbro New Member
    Thanks.
  18. Apr 16, 2023 at 11:14 AM
    ToyotaTundraguy
    ToyotaTundraguy New Member
    2022 tundra trd sport
  19. Apr 16, 2023 at 11:17 AM
    ToyotaTundraguy
    I have 22 Trd sport . My trailer is the same weight and size . Pulled with ease it felt I can’t tell the difference from towing 5000lbs or 7000lbs
    However I got airbags as my truck squatted pretty good and I could not stand the site of it ‍♂️
  20. Apr 16, 2023 at 11:20 AM
    Hella Krusty
    Hella Krusty New Member
    I towed a 25' with heavy tongue weight behind my 2012 with a family of 4 in the cab and box loaded with shit...no problem. On highway I would have the electric trailer brakes maxed
  21. Apr 16, 2023 at 12:24 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Put all your crap in the camper not in the bed of the truck. Watch the tongue weight use a good WDH.
    My 2012 tundra was more stable vs the 2018 F150 I just sold and I think my new 2023 platinum will be even better.
    Breathing Borla likes this.
  22. Apr 16, 2023 at 12:27 PM
    4genRunner
    Southwestern MO
    Interesting. Maybe your TT is really tongue heavy? Mine runs about 750# on the tongue when loaded up and the truck sits perfectly level with just the WDH.
  23. Apr 17, 2023 at 2:43 AM
    kelbro
    kelbro New Member
    Which air bags did you buy?
  24. Apr 17, 2023 at 5:16 AM
    dashmer
    dashmer New Member
    I think you should be fine with a WDH and some form of sway control. I use a dual cam WDH system which does both WD and sway control. Have used that system for the last 15 years.
    Bank on 1500-2000 pounds over dry weight once you add batteries, propane, food, equipment (stuff) and if you travel with water in your tank. Be careful with how much weight you carry in your truck as well.
  25. Apr 17, 2023 at 6:11 AM
    ToyotaTundraguy
    My truck is the bigger one with full doors , I would have my generator in box of truck and front trailer cubby full of camping gear
  26. Apr 17, 2023 at 6:16 AM
    nodak67
    nodak67 New Member
    JR
    25 or 50 gal fresh water tank is going to be 200 or 400 lbs added to the trailer.
    most trailer weights are dry weight. so adding water, 2x20gal propane tanks, food, camper gear in storage bins will add up pretty dam fast.
    RVer likes this.
  27. Aug 31, 2023 at 10:57 AM
    4genRunner
    Southwestern MO
    I did not have any problems setting it up, but I have not used the actual backup assist so can't say for sure it is working as expected. I entered the length manually.
  28. Aug 31, 2023 at 11:12 AM
    Breathing Borla
    Northern Illinois
    did you get the advanced package? If so, you have the load leveling air bags, if not , you don’t
    that’s how the platinum and 1794 works through 2023 anyway
    i have them and they are great
    Maharisc likes this.
