Nav / Radio loses memory
Discussion in 'Audio & Video' started by Bdk437, Aug 29, 2023.
  1. Aug 29, 2023 at 1:05 PM
    Bdk437
    Bdk437 [OP] New Member
    Bruce
    2019 Tundra SR5 2wd Crew cab
    5000 series Bilstien shocks TRD sway bar
    My battery died when it was 106 degrees outside and after it was replaced the radio doesn’t hold its memory.
    Most of the time at startup it’s on AM static.
    Anybody have this issue?
  2. Aug 29, 2023 at 1:51 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Would help to have a little more info - fill out your user profile with truck year, trim, cab, etc…
    There’s three official gens plus multiple rolling changes to options during specific years as well as different radio options and all of those become possible factors in what the solution might be.
    gosolo likes this.
  3. Aug 29, 2023 at 3:22 PM
    Bdk437
    Bruce
    Sorry…. I filled in profile too but it’s a 2019 SR5 2wd Crew
    No updates from Toyota. XM single cd nav
    Go to start truck and it now lands on am static
    All I did was replace battery under hood
  4. Aug 30, 2023 at 4:47 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Is it resetting every time you start the truck or did it do it just that one time after you replaced the battery?
  5. Aug 30, 2023 at 8:36 AM
    Bdk437
    Bruce
    There wouldn’t be much to complain about if it only did it once. Lol
    Probably 80% of the time it switches to a.m. static. It does surprise me every once in a while and go back to where I was when I shut the truck off last.
  6. Aug 30, 2023 at 8:57 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Yeah that's strange. I wonder if somehow you got a defective battery? Since that's the only thing that's changed, I would have a load put on it and test it out to make sure there's no issues. At least rule that out first since it's free to do.
  7. Aug 30, 2023 at 4:43 PM
    Bdk437
    Bruce
    I responded here but don’t see it. It’s happening 80 percent of the time.
    One other change is when filling up my range would normally say 500 miles now says 580 …
